Has anyone dressed axle cones using a hand drill and sandpaper?
I have a front hub with some light pitting on the bearing surface area of both cones. I see posts on here about people using a lathe and a special bit to get rid of the pitting. Has anyone done this by chucking the cone in a hand drill and using sandpaper? I would think it would work. I have every grade of sandpaper under the sun up to 2000 grit, Simichrome, and 4 grades of steel wool, I'm just not sure what grades of to start and end with.
Any tips would be greatly appreciated.
More than sandpaper.... (have you tried your Idea yet, how did it work ?)
how it has been done ... 2 drill motors 1 has a cone shaped, grindstone bit, the other spins the cone on an axle..
don't let the heat of doing it take the temper out of the steel .. keep or cool, dipped in water often
Quoted: 7348 Post(s)
Liked 2,474 Times
I don't think this is practical. Good cones are hardened very hard. If you make any progress at all, it will be with huge amounts of materials and labor, and they would exceed the cost of replacement cones. And you might not get anywhere. Or if you get somewhere, you might go through the hardened layer and end up with a soft outer layer, and that's no good. I have never heard of anyone succeeding at this, though I've heard the idea over the years.
Quoted: 1074 Post(s)
Liked 295 Times
I’ve ground a number of cones using a drill press and a Dremel. Or a drill press and a sand paper rolled around a screwdriver blade. Doing it with a hand drill seems tedious, but not impossible. Cone survival after grinding has not been a problem.
Don’t rightly remember which grits I’ve used. With the Dremel, I finish with a polishing stone that leaves near enough a mirror finish. With the sand paper, it’s a fine wet sanding one.
I’ve spoken to friends in the automotive business, and w/o taking a cone to the lab, their best guesstimate, based on truck transmission manufacturing, it that pieces of that size are most likely to end through-hardened.
Likes For dabac:
Liked 2,474 Times
OK now I've heard of one person succeeding at it. I'm glad to know I'm wrong.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Likes For dedhed:
Quoted: 811 Post(s)
Liked 1,024 Times
With only light pitting the technique that i use is to clean out the race of any grease and debris, clean the bearings and cone. Then repack the race with lapping compound. Re-assemble with the old ball bearings, assuming they were good. Then connect a drill motor to the axle and hold onto the hub. Run the drill for a few minutes in both forward and reverse. Then dis-assemble and throw away the ball bearings. Clean everything real good and re-assemble with new ball bearings.
The technique described in the original post would be for for more serious pitting. I don't see why it wouldn't work, This diameter of the grinding tool must be real close to the diameter of the balls. It might be good to follow up with the lapping compound afterward.
Let us know how it goes. With pictures please.
Likes For Velo Mule:
Quoted: 1372 Post(s)
Liked 1,752 Times
All that said, I have dressed bearing races and/or cups but only if a proper replacement set, in good shape, was not available at the time. And, I stayed close to home on any such steed. And, I never sold a bicycle with damaged bearings, just in case anyone is wondering.
Bikes: Forty of them
Quoted: 99 Post(s)
Liked 33 Times
I've re-cut several Campy cones using a toolpost grinder on a lathe, but can't speak to the relative success of any other method. I tend to avoid messing with cones from other brands except in times of desperation.
Thanks for the advice so far folks. I'm going to give it a go, but it might be a couple days before I can get my "redneck lathe" set up. My plan is using a 3/16 drill bit for a block, start with 1000, then go to 1500, then 2000 (all with water), then 0000 steel wool with simichrome as the final polish.
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
[QUOTE=dedhed;20813017]https://www.hemmings.com/magazine/hs...e/1282111.html
"But the advantages to Cherry Red compound are that it's not a cyanide-based compound"
A good thing, helps with repeat sales.
I thought I would bump this old thread:
I came across this page on the web:
https://bicycleobsession.wordpress.c...ted-hub-cones/
And tried the technique with a pair of cones that were only slightly less pitted than the ones shown on the website, using a slightly simplified (and totally low budget dirtbag) setup:
Even so, I was amazed at how well it worked. The only other thing I did was to spin them against this 3M metal polishing cloth I have. I wish I had taken "before" pictures, but they weren't really very old cones, just abused, with some mild pitting. Are they slightly out of round now? Possibly, but the reassembled wheel seems to spin quite smoothly. Not new-wheel-smoothly, but good enough so that, giving the axle the "hand test" now, I wouldn't feel the need to repack the bearings. Anyway, I'm really psyched to know about this, thanks.
WGB
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times
Headpost
Very impressive work!
Perhaps you should add to the "Hints and Tricks" thread on the mechanics forum. Might encourage someone else to try and save an irreplaceable part, especially during covid.
Quoted: 1106 Post(s)
Liked 1,328 Times
The race surface has a larger radius than that of the balls, but how much larger does not (within limits) matter, except that larger is marginally better [1]
What matters is that that the line between the points of contact on each side of the balls both
a) runs on a hard smooth surface; and
b) is at an angle correct for the kind of load expected. All you have to do is grind so that line is in the same relative position.
[1] Larger is marginally better because the balls do not make a perfect point contact, there is some elastic deformation, and so there is "skidding" of the parts in contact at the edges of the line of contact; this skidding is the source of wear, and a flatter base reduces the width of the line and the resultant wear.
