ultegra brifter only shifts up
GATC
I found out midway through my morning commute today that the outer lever (that moves the rear derailer inward) does not work. One time I caught it and it shifted in 2 cogs but mostly it just floats free, no resistance.
Is there anything I can do for this or does it need replacing? It is ~20 years old.
Thanks in advance.
Thanks in advance.
Licensed Bike Geek
You can peel the hoods back, spray WD40 liberally on the shifter bits, blow out with compressed air then some good lube like TriFlow applied. It will be messy while you’re doing all this but this often fixes dead Shimano shifters.
GATC
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I would spray it with White Lightning as a cleaner and then Boesheild T9 for lube.
Bikes: Litespeed, O'Brien, Specialized, Fuji
Quoted: 18 Post(s)
Liked 15 Times
I don't even bother to peel the hoods, just work the levers and blow Triflow or the like liberally into the mechanism. Enough to dribble down the levers, work the levers, then do it again in a day. I wipe up what I can and wait a few days for more dribble to wipe up. I put these buckets on until the dribble stops.
Of course, you might actually have a broken mechanism. Plenty of other threads about this problem with Shimano brifters.
Quoted: 2952 Post(s)
Liked 3,106 Times
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
Here's what I usually find when the downshifting starts to deteriorate. 6600 Ultegra 10S
cable frayed at shifter won't allow the cable to release.
Quoted: 1364 Post(s)
Liked 1,676 Times
