Flat bar conversion on an Ironman?
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,084 Times
My wife has a city bike with a 3 speed Nexus IGH that has proved a challenge to ride around our new hillier hometown. I put a bigger cog and smaller chain ring to help out but still tough to get up the routine hills here. She’s asked for a more hill friendly bike. So I’ve been scanning the local co-op and CL and seeing mostly overpriced MTB or junk bikes but this Ironman has lingered and finally drifted down into the < $100 price range.
It’s currently fitted with Shimano 600 but I’m thinking triple crank, flat bar with a 7 speed trigger shifter that I have. Fenders might be problematic on this one. Anyone done this to an Ironman before? What size tires have people put on these?
Quoted: 1946 Post(s)
Liked 2,004 Times
Easy room for 28s on my 86 IM but not on my 87. Over on the IM thread, somebody did a 650b transformation to an 87 with long reach Tektros. If thevcity bike has swept back bars, the flat bars might be a stretch but a triple has often been done. Easy way for low gears is a compact with a 28 on the back.
Bikes: Numerous
Liked 3,084 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
@TXsailor recently put a triple on an Ironman.
I've just put smaller chainrings on my double -- Vuelta 50/39. A 38T small ring is available in 130 BCD.
Combined with a 13-26 freewheel, that helps my mediocre climbing ability. I also have a 13-28 but haven't put it on the Ironman yet.
If you go beyond the standard 13-24 freewheel, be sure the chain is long enough to avoid stressing and damaging the short cage rear derailleur. It'll take a few adjustments to get smooth shifting across a 13-28. Initially I was doubtful it could work but it does. I like the SunRace MFR30 13-25 and MFM30 13-28 chromed freewheels -- the teeth are shaped for smoother shifter and quieter running than the original Suntour. Some SunRace freewheels have spotty quality control, but so far those two specific models have been fine for me.
To me, flat bars seem initially comfortable and convenient, but only for rides up to around 20 continuous miles without a break. They're really designed more for manuverability, not comfort. OTOH, some of my riding friends ride flat bar fixies all day, including a Bianchi road bike converted to fixie with flat bar. And I find flat bars a bit awkward for standing to pedal. I prefer to have my hands aligned as they would be riding the hoods.
A swept bar like a Nitto albatross or North Roads would be more versatile. That's what I have on my Univega, and am considering for another Ironman frame if I can find one, which would be about 5 lbs lighter than my Univega. With Shimano bar end shifters it's convenient and comfortable for all day rides. I can shift with the base of my palm and lift up with a pinky, while keeping my hands on the grips and ready to brake if necessary. Great city bike setup. Definitely on my to-do list soon. I like the idea of a lightweight city bike in the sub-25 lb range that rides like a classic steel road bike.
The original drop bar can be set up much more comfortably than the original setup shown in catalogs and ads. I just tip the bar up slightly so the bottom of the drops aren't quite parallel with the ground. Then slide the brake levers up about 1/2"-1". A shorter 90mm stem (courtesy of @RobbieTunes) completed the comfort adjustments to suit my cranky neck and shoulders (old car wreck injuries). Much better than the original long 120mm or 130mm stem, which was better suited to getting low and stretched out for time trials, 1960s-1980s style. I've posted some pix of my setup. It's not radical or goofy looking -- not like the flipped drops I see on pawn shop beer bikes around the neighborhood. It's actually pretty close to how some road racers set up their drops in the 1960s-'70s for stages other than time trials -- more for comfort over those 3-week races.
And you can switch to brifters for convenient shifting with drop bars. I did that with my early '90s Trekenstein 5900, their early monocoque carbon fiber bike. A friend inadvertently bought a set of 7-speed MicroShift brifters years ago and by the time he was ready to install them he realized they were the wrong set and it was too late to return 'em. So now I'm using 'em on the Trek. My first experienced with brifters and they're great. Took a whole 15 minute test ride to get used to them. Now I can shift while standing to climb, just by pausing the pedal stroke for a split second. Very convenient. Also the MicroShift brifter braking is super light, yet positive. Makes my Ironman's Suntour GPX brakes feel a bit gritty and stiff in comparison. Although the Shimano 600 brake levers had a nicer feel than the GPX, despite looking nearly identical. Part of that is due to the stiff GPX caliper internal springs, which are darned difficult to adjust so I won't bother.
For tires, I really like the cheap but good Continental Ultra Sport II in 700x25. I'm not sure 700x28 will fit, but 700x25 at around 90 psi rear, 75-80 psi front, tames even our rough chipseal roads. I weigh 150 lbs and have never pinch flatted running tires softer than specs call for.
If the budget can handle it, there are some nice semi-gravel friendly 700x25 tires with just enough tread to give a little more confidence than the slicks I usually ride. But the Contis have worked fine for me, even when I've been caught in the rain.
Liked 2,004 Times
as others have stated, the issue will be tire size...28s are pushing it w/ newer models as their forks have less clearance, but as you probably know, not all 28s are alike. I had the best luck with the older "flat crown" Centurion foks...
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
IDK, but if you put flat bar, triple, 28mm, fenders = you are gonna spoil bigtime the image of this bike as America's hardcore racer for Everyman.
The hardest part of putting a triple on a Ironman was finding a derailleur and that wasn't very hard. I have actually done it to two. The first was mine and I used a new FD 5703 and it works fine. The second one got a Exage that I took off another bike. It was for my Granddaughter and it works good too. The bottom bracket you need will depend on what crank you use.
Quoted: 3241 Post(s)
Liked 2,512 Times
I need to mention that some time in it's past, the serial number was ground off. When I acquired it, it was set up as a Hobo fixie.
nazran
22
01-29-12 07:22 AM
fbagatelleblack
9
06-30-11 09:05 PM
