Need help with bike computer (Bryton reading incorrect speed)
My Bryton computer has been reading my speed slower than I’m actually moving. Anyone have an idea of how to fix this?
I had a feeling it was the case, so I compared it to my Garmin watch, and the computer is indeed consistently slow.
The Bryton will be slower by a couple of miles an hour on even short rides. I noticed sometime I’ll be cruising at 22-23 on the watch while the bike computer is stuck at 14-15 mph.
Quoted: 6194 Post(s)
Liked 4,810 Times
Are you using a speed sensor? If so, then maybe you entered the wrong wheel size. Have you made sure you got the latest software update for your device?
Likes For Iride01:
I tested it out somewhere with more open space and it seems to be working better that way. The trouble is when I ride my regular loop at the heavily-treed nature center.
wheel size was and software was up to date.
Likes For trailangel:
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
Want to be accurate and consistent on speed data? If speed sensor for a wheel is an option it is the only way to go
Quoted: 18883 Post(s)
Liked 10,646 Times
anyone have an idea on how to pair a speed sensor to a Bryton Rider 330?
Are they fairly universal?
I’m new to this, so all help is appreciated. I’d like to go ahead and pair the computer with a speed sensor. I’d normally get some help from the local shop, but I bought this one at a shop a little ways away where I got my bike.
Liked 10,646 Times
Here are instructions on pairing a speed and cadence sensor. There are speed sensors you can buy independently (no cadence bundle) but these communicate differently and may not work with your computer, so go ahead and buy the bundle to play it safe even if cadence isn't important to you.
https://www.manualslib.com/manual/11...page=41#manual
Is it too late to return the Bryton or seek warranty coverage? Although GPS is imperfect for speed and distance, a functioning receiver should not be capable of as much error as you're seeing.
Witterings
General Cycling Discussion
12
05-02-18 10:29 PM
Mastermind77
12
05-16-13 07:44 AM
