Cinelli 1A stem and or Cinelli Giro d’Italia bar toast?
“Senior” Member
This bar and stem are off my Bruce Gordon and I have no reason to believe they are not original.
The bar came to me with an indent or impression from the stem being tightened.
It all holds OK when I’m on relaxing solo rides but on a group ride which will be a more aggressive ride the bar slips—out of saddle or hard braking. Pretty unsettling.
Opinions please on whether the bar is definitely toast or are there tricks to keep it in place?
Also included pics of the inside of the stem to see if anyone thinks it is toast too?
“Senior” Member
Both mic to 26.4 but the bar mics a tad ovalized 26.4 one side to 26.2 the other
the bummer is I bought a new issue giro d Italia for 10 bucks from a DC co-op but found out it mics to 26.2 no matter how I measure it on the center and 26.1 on the plain sleeve. So I’m thinking it really may be a 26.0???
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
I'm thinkin' you could shim the bar so it doesn't slip. You probably want to use a solid piece of thin metal shim, but a "liquid metal" might also work, maybe even better.
52psi
Quoted: 790 Post(s)
Liked 802 Times
I'd feel confident using the stem with what I can see from here. Bars? Not so much. I just don't think that's an area where I want to chance things.
“Senior” Member
I’m feeling better about the stem as it mics to 26.4 every angle. No confidence in bars because of that impression mark and that it mics different left to right — think it’s experienced too much stress.
The last question for the advisors: using a shim for 26.0 new giro bar (it’s an Never installed bar) to my ancient 26.4 stem. I read pro and con advices on other forums. Even read a Sapporo 22oz beer can give you a 0.2 shim so you could bridge the gap in one layer. Others say never shim. Thoughts?
But a cosmetic downside to using old stem is I polished it out since the original ano was all scratched up. So the new bar is milky silver ano (not near as pretty as the original “pearly silver” of the original components) against a shiny stem. The artist in me wants to just spring for a new stem for a better matched look. Then I wonder if getting the never installed bar to match a new cinelli 1a stem well is still a crap shoot as there may be variances in the ano styles?
Having full confidence in the security of my bar/stem combinations is high on my list of "must have".
I have Cinelli bars & stems that have been in service for decades w/o any hint of a problem, all 1A stem and #64x40 bars.
These were the go-to standard "back when" for road racing and I've never seen a failure in service, although I have seen crash damage.
Buying old hardware w/o knowing it's provenance and possible ham-handed install, lack of maintenance, crash damage or abuse is somewhat of a crap shoot, even if it's well known for reliability and long service life. Whatever happened to those bars took some doing, or not-doing, to get in that condition. I'd bin them and having determined that the stem specs out replace w/ another set of 26.4 Cinelli (after close inspection) and test ride to absolutely be sure they are safe.
As far as "shimming"?
Of course not, unless the shimming recommend-er wants to risk his/her teeth and clavicles on a vigorous series of tests involving high speed descents on rough roads, max braking, full-on sprinting, hitting pot holes at speed and standing in big gears on steep hills to get some skin, bone and dental work in the game.
-Bandera
-Bandera
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
I guess shims, (basically, fixing anything worn) is just a non starter for some folks - Particularly those who grew up after "MacGuyver". (Which just happens to coincide with the end of the friction DT shifting/ toe clip era.). Coincidence... I think not*
It's pretty early in the season to be getting irritated by the (slow) fancy kit / carbon go-fast bike weenies. A whole summer ahead...
