what does 700cx28 mean?
need to go out and ride..
Bikes: 2011 Scott Addict R1, 2014 Redline Conquest Team, 2015 BMC TMR02
Quoted: 19 Post(s)
on a 700c x 28, would it be possible for me to put a 700c x 25 road tires on my sirrus?
Ride to remember
Bikes: 02 Giant OCR 3, 95 Kona Cinder Cone, 83 Norco Monterey
The specs for your bike shows: RIMS Alex DA-16, 700c, alloy double wall, machined sidewalls
Norco produced their CRD-3 road bike with Alex DA-16 rims and 700 x 23 tires last year.
Center of the Universe
Bikes: Bianchi San Remo, Norvara Intrepid MTB , Softride Solo 700
Matthew 6
Matthew 6
Quoted: 1572 Post(s)
Liked 643 Times
28 refers to the theoretical mounted and inflated width of the tire in millimeters.
c is supposed to be a measure of rim width as in a, b, c, d like in shoes, but in real life it has a stronger relationship to the rim diameter.
All of those measurements (except bead diameter) have a liberal amount of wiggle room. For example you can easily eyeball the differrence in width of many 700c rims. You can make minor changes in tire width, but I'd never try to use a tire that was narrower than the rim.
Clydesdale, for now.
Bikes: Giant Escape M2
My Sirrus took 700c x 23 without complaint.
Fat man trying to reform. slowly. :)
START 330lbs
NOW 286lbs
TARGET 168lbs
START 330lbs
NOW 286lbs
TARGET 168lbs
Quoted: 19 Post(s)
did you notice any difference on your sirrus when you put the 700 x 23 on the bike? did it make the ride rougher or faster? what kind of 700 x 23 tires did you have on there?
Rougher and faster.
Not sure which ones to be honest..... armadillos again?
START 330lbs
NOW 286lbs
TARGET 168lbs
START 330lbs
NOW 286lbs
TARGET 168lbs
Quoted: 19 Post(s)
Rougher and faster.
Liked 643 Times
You're only talking about 2mm difference in width, that's not very much, so I wouldn't expect a hugh change in ride quality just from that. Much bigger differences will result from using more air pressure and from the construction of the tires.
Armadillos are nearly bullet proof, but their stiff sidewalls are a detriment to both rolling resistance and comfort. They're heavy too. I have them on a couple of my bikes, but I use them only selectively.
Quoted: 19 Post(s)
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
i saw some 700 x 23 from Continental and they had pretty good tire threading too. can't remember what it was. but those look nice too. perhaps i should go back to REI to get the model name.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Quoted: 19 Post(s)
Originally Posted by khuon
I run Continental GP3000 in 700Cx23. They roll really nice and handle most weather conditions well. They also seem pretty flat resistant... not as good as a true heavy-duty commuter tyre but pretty good for a racing tyre. The only downside is that they're pricey at around $45 each.
these looks and felt pretty good when i was in the store. the tires was very smooth. plus with kevlar, it almost looks flat proof. plus it's $33 which isn't that bad. have you ever experience with these?
DEADBEEF
Liked 6 Times
aaaa-ha! found it.. these were the continental tires i saw at REI. Continental Ultra Gatorskin
Quoted: 19 Post(s)
Nope. Not personally but I have ridden with people who use them and well... They were getting flats when I wasn't. However, I think the majority of the flats were due to a bad batch of tubes but at least one was genuine. They're probably still good tyres but I wouldn't count on them being totally impervious to flats.
