Poll: Do you talc your tires/tubes?
I've always talc'd my tires/tubes. Felt it made the ride a bit more supple.
Do you talc? If so, why?
Keep on climbing
I've done it to help in mounting tires; seems to help make things a little slipperier, less chance of pinching the tube during mounting, etc.
I don't know how it could be making your ride "more supple" though. You've (generously) got 0.01" of talc on your inner tube, and nothing is moving anywhere once your inner tube is at full pressure.
Portland Fred
Heck no. Most flats are in the rain. I can't imagine the talc being helpful...
Bikes: CAAD10
Huh? Please explain as I haven't heard of this. I am aware of a white powder inside tubes - are you applying it to the exterior as well?
Road, MTB and SS Rider
Bikes: Trek 5200, Yeti Kokopelli, Clockwork
have only used talc when putting tubes into zip lock bags so they don't stick and are easier to unfold. Other than that the talc doesn't do anything.
Bikes: 2010 Tarmac SL, 2013 Fairdale Weekender, 2013 Fairdale Coaster, 1995 Specialized M2 Pro, 1972 Schwinn Heavy Duty, 2014 Surley Long Haul Trucker
Always.
I talc mine most of the time. There is no difference in ride or in the number of flats. But it keeps the tube from sticking to the tire which makes for easier tube changes on the road.
Quoted: 3370 Post(s)
Liked 5,488 Times
Bikes: 2007 Orbea Onix, 2007 Windsor The Hour, 2008 Kona Jake
I also sometimes need a little talc after doing a lot of pulling and tugging.
Legs; OK! Lungs; not!
Bikes: ''09 Motobecane Immortal Pro (Yellow), '02 Diamondback Hybrid, '09 Lamborghini Viaggio, ''11 Cervelo P2
Liked 9 Times
I don't even talc my balls!
Bikes: Litespeed Firenze / GT Avalanche
Here is the reason I do it:
Under hard braking, especially on fast descents, the tire slips on the rim just a tiny tiny bit. Without talc, the tube sticks to the tire and moves with it. As the tube moves, and the stem can't, it can rip the stem out of the tube. As most of the braking force in on the front, this where you are likely to have a blowout. Right where you don't want it!
The talc lets the tire slip on the rim without taking the tube with it.
It happens on MTBs more often because of the lower pressure. I did have it happen to me at 35MPH on a MTB. I damned sure never want it to happen on the road.
I've used "shower to shower". The only reason for that in particular is that that's what I've had on hand.
Recently I've been experimenting with Armor-All. Has a similar smoothing effect. Plus I'm hoping that this will help with tire lifespan and corrosion of the wheel.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4334 Post(s)
Liked 2,977 Times
The idea that the tire would rotate on the rim without taking the tube with it is nonsense - what force keeps the tube from rotating? If the tire slips on the rim then the tube comes with it, talc or not. I'm not saying you won't experience a valve-rippage blowout; I'm saying talc won't prevent it.
I put a little baby powder in a new tire or a new tube, and I put a little in with my spare tubes in the seat bag - it helps with mounting but that's all.
raodmaster shaman
This "slipping" will never happen on a properly inflated tire, as far as i see it.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
yes.
Bikes: 2007 Pergoretti Marcelo
Visit my blog -->MyOrangeBike
"There is love and there is work, and we only have one heart." Edgar Degas
