Under $500 on-line MTB for a 6'3" 275 lb Clydesdale
I've been lurking around here trying to learn more and have decided I need to take the plunge sooner than later and buy a MTB. I've already got a hybrid but I'm afraid because I've gained so much weight the spokes on the rear wheel won't handle me anymore.
I've got a few questions about buying a MTB online through a place like Bikes Direct. I'm mainly concerned with durability of the wheels and spokes and really don't care about how fast or heavy the bike is. I just want to pedal my way to a healthier and fitter me.
Is it possible to buy a bike online that is comfortable to ride and fits me within reason? Because of my weight do I really need 36 spokes on the rear wheel VS 32 spokes ?
Here's four I'm currently looking at.
https://www.bikesdirect.com/products/...cane/400ds.htm
https://www.bikesdirect.com/products/..._ghost6300.htm
https://www.bikesdirect.com/products/..._ghost6700.htm
https://www.bikesdirect.com/products/..._ghost6900.htm
In your opinion would any of these choices be rugged enough for my large body? I realize you sometimes get what you pay for but money is really tight now and I'd really like to start bettering myself ASAP. Thanks for your time !!
I am the Snail~!
I'm a newbie, so not much help - but a couple of thoughts?
26 inch wheels are stronger than 700 wheels if everything else is equal. My LBS convinced me to try a Giant Suede DX (bout $400 bucks) with 26 inch wheels, and swears I won't tear up the wheels at *my* weight. Only time will tell, but with 20yrs at the same location, Sam isn't going anywhere, so will be there if I do encounter wheel issues.
Just a thought...
Just a thought...
Guest
Posts: n/a
Quoted: Post(s)
I'd suggest going used or a clearance model. At 275 for a mountain bike you don't need a 36 spoke wheel if the stock wheel is well-made.
BTW, my bike shop, a Trek dealer, suggested their one up from the bottom of the line MTB for a Clyde of your height.... and an additional 125 pounds.
The Bikes Direct bikes are OK, but they don't come with a bike shop. When you buy through a bike shop, you buy the shop, in a sense, as well. If you are difficult to fit, have special requirements, etc, then I suggest steering clear of online bicycles.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
None of the bikes you linked to are good choices. You want a hardtail like this one.
https://www.bikesdirect.com/products/...ne_600HT07.htm
Thanks for all the replies everybody.
I'm the same height/weight as you and I just got a Raleigh Sport road bike. I used to ride a Schwinn hybrid when I was a little heavier. I've never had problems with the wheels on either bike. As long as the bike is well made, I wouldn't worry about your weight as far as the wheels are concerned.
I would guess the hardtail would be better for heavier riders because it doesn't have rear suspension, which for most people our size, would probably be bottomed out most of the time.
Downtown Spanky Brown
Bikes: Motobecane Phantom Cross Pro Kona Lana'I
Squishy (dual suspension) bikes are not ideal for anyone in the sub $500 price bracket. If you are looking for a decent dual suspension bike you will need to raise your budget into the $1500 price range. Here's why: as a larger rider pedals the force of his pedal stroke is partially absorbed by the suspension in the bike. Ever notice the front suspension bobbing when someone stands and pedals? On a dual suspension bike you have extra moving parts, and an additional shock which will bob. The suspension on any of those bikes will likely be next to useless under the weight of the rider. Not to turn you off to them in general, just saying. This is why hard tails are recommended so much. Get one with a fork that has the ability to lock out. Disc brakes vs. Rim brakes should not be your selling point. Discs are cool, but really mechanical discs don’t have much stopping power over a good set of V’s*
You know, for $500 dollars you might be able to score a left over 4300 disc, Wahoo Disc, or Rock Hopper. Any of those bikes would be great and much better than buying from bikes direct.
*when the braking surface of the rim is clean
If you do buy online, you will either need to know a bit about bike mechanics and have some tools or you'll need to pay your LBS to assemble and adjust the bike.
[FONT=Verdana] This is why hard tails are recommended so much. Get one with a fork that has the ability to lock out.
I'll check out the local dealers and see if I can find any of your suggestions that are last years leftovers. Thanks for the ideas.
I've read in reviews the generic manuals bikesdirect sends with the bikes leave a LOT to be desired. I'm pretty sure I've got enough tools and know how to get everything together correctly. I'm pretty much only concerned with buying the correct bike that fits me properly.
Lock out fork ? Is that the ability to keep the suspension from working?
As for assembling and adjusting, it isn't too bad but wanted to make sure you factored that in. Many would not feel comfortable doing their own wrenching. I'm in the process of building a bike out of a box (NOS '92 Diamond Back Ascent EX) and it just takes a little patience to go through everything and make sure it is right.
You are correct on the lock out. It eliminates the suspension.
The main thing to remember is that your first bike, if you really get hooked, will serve the primary purpose of moving you on to your next bike. Cycling can be a very positive addiction and you might be surprised where you find yourself a year down the road. I know I was.
You never know unless you try. If you are comfortable doing some wrenching, used can be the way to go. When I returned to cycling 2 1/2 years ago, it was on a $40 Craig's List MTB. It needed work but was basically sound. A few hours of work (hadn't wrenched on a bike since I was a kid over 30 years ago but managed) and $40 in tires and grips and I was on the road. Logged 1,000 trouble-free miles on that MTB before moving on to road bikes (first was rescued from a dumpster but that's another story).
I'll check CL later on today and see if I can find something in good shape with a large enough frame to fit me. Thanks for the suggestion !!
I'm not against getting a second hand bike and I'm pretty confident I could fix pretty much anything except spokes on it. Were you heavy when you bought that CL bike for $40 ? The whole reason I want a MTB and not a road bike is because I want the strength the MTB wheels and spokes have over a road bike. I just want something I can wheel out of the garage 4-5 times a week and take off for a hour or so.
Why not just buy a new rear wheel for the hybrid you have? As others have noted, dual suspension isn't great for big clydes. If the hybrid is otherwise fine, then get a new handbuilt rear wheel. Should cost $200 or so.
Bikes: Peugeot Hybrid, Minelli Hybrid
Spend $60 on a Park tensiometer and $8 on a spoke wrench, then check that the spoke tension on the drive side of the real wheel is even all around at about 105 kg, and on the non-drive side is enough to keep the wheel midway between the brakes. Read more about it on the Sheldon Brown website. If you have 35 mm wide tires, you may be able to fit 38 mm ones. Check for clearance between your current tires and the frame.
With the down economy, there are some leftover 09's to be had. Try to find a steel hardtail. At $ 500 your probably not going to find a disk version. I'm 235 and would strongly recommend a 36 hole rim. Try kona, they have worked for me.
I'm the same exact height and weight as you and I just bought a Raleigh Sport road bike and I love it. You're not too big to not be able to get a road bike if that's what you're really interested in. My brother, who is a couple inches shorter and a few pounds heavier than us just got a Fuji Newest 4.0 and he has absolutely no problems with that as well. Your weight is perfectly fine on a road bike as long as you're not looking into a CF bike with CF wheels and like, 12 spokes.
Cantankerous Old Fart
Location: On the Tundra of Northern NY State, almost Canada eh?
Bikes: TBD
Quoted: 20 Post(s)
Here's the bike I am considering, I'm not as tall as you, but a bit heavier. The bike has an adjustable shock for dampening & rebound. It comes in a 21" frame for your hieght. I'll get a 19" frame for my 5'10" hieght.
https://www.bikes4families.com/cadill...bike-p-94.html
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I think you should buy the dual sus. you are looking at (sometimes you just need to get what you want cause you want it!). In a few weeks when the suspension is whacked, then go buy a new rear wheel and the fattest tire that will fit on your hybrid and ride it till you can't or until you save up enough for the bike you want. The 1st year I got back into biking I rode a 19" beach cruiser with ashtabula cranks, wobbly wheels and coaster brakes. 6'1" 238 at the time. Once I decided I liked riding and was going to stick with it I upgraded to a new bike. Seriously, if I wanted a cheap dual sus and didn't want to buy used I'd go to Walmart. Quality will probably be the same, and you can ride it till the wheels fall off and not feel guilty when they do.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Quoted: 366 Post(s)
Liked 457 Times
https://www.konaworld.com/bike.cfm?content=humu
Or try this. I have one and love it. ($425) I eventually put a nexus 8 premium hub on the read. Love it. 2.35" tires are like having suspension.
https://www.balloonbikes.com/en/startseite/
For us larger guys, Balloonbikes has good info.
