Stack and Reach question.
I just found out about and read up on Stack and Reach. So I measure my 3 road bikes to compare.
Bike 1 Stack = 61.1cm, Reach = 39.4cm
Bike 2 Stack = 58.5cm, Reach = 37.5cm
Bike 3 Stack = 55.0cm, Reach = 40cm
I find all 3 bikes comfortable, and all 3 are set up with same seat height, handlebar to seat tube, etc.
Are these differences a big difference?
Should all 3 feel comfortable?
Which is more important, Stack or Reach? or are they just 2 more measurements to help you find the right size bike?
Bike 1 is a 2016 Cannondale Synapse, size 58
Bike 2 is a 1984 Trek 720 size 22.5 inch
Bike 3 is a 2000 Mercier Aquilla, size 58
Last edited by Bolo Grubb; 07-29-16 at 09:50 PM. Reason: typo on Bike 1 measurements, should be correct now
Quoted: 5791 Post(s)
Liked 2,581 Times
First of all, you're the victim of the "I just measured something, and things are off" plague. I hear variations on this theme every time someone starts measuring stuff for the 1st time.
That said, 17cm difference in reach seems like an awful lot, so I'd make sure I measured bike 1 correctly. 2-3cm difference isn't rare and is easily enough made up with the stem. Likewise, the various head tube stack heights can be made up with spacers and stem angle.
IMO- frame dimensions are the coarse adjustment which gets you to the right ballpark, then fit is fine tuned with adjustments to the saddle position and changes to stem length, angle and spacer stack.
FB
Chain-L site
FB
Chain-L site
Liked 2,581 Times
All within a tight band that can be fine tuned to the same fit if that's your goal.
FB
Chain-L site
FB
Chain-L site
and I have them pretty well fined tuned now. The only real difference between them all is the handlebars sit higher on the cannondale giving me a more upright position that I am pretty comfortable with.
I guess I was expecting the stack to be closer then it is, but so far I am comfortable on all of them. The Cannondale does have a much longer head tube then the other two. It puts the handlebar at the same level as the saddle, on the other 2 bikes the handlebar is slightly lower then the saddle.
vinuneuro
Road Cycling
16
02-28-16 03:54 PM
Sullalto
Fitting Your Bike
1
06-14-14 07:44 AM
milkbaby
Road Cycling
3
12-07-12 03:49 PM
