Can cycling and aspirin be the cause of my ED?
Casually Deliberate
I didn't see anything from the OP saying he was having problems with numbness which if that were the case might be attributed to the saddle. Given he's talking about ED and lack of libido I'd start by getting a good blood panel done so anything physical can be ruled out.
just another gosling
Quoted: 3895 Post(s)
Liked 1,944 Times
If ED for you means a numb dick, then it's a saddle issue. It's certainly a fact that cycling with the wrong saddle for you can and often will cause a numb dick. Those who say otherwise haven't had the problem. Usually, getting the right saddle with a cutout mostly solves the numb dick problem. It's not true that a cutout saddle always makes the problem worse. A small minority need a noseless saddle, but for most the right cutout saddle works fine. I ride with randonneurs who do 1200k rides with a variety of saddles. There's not one right answer in terms of saddles. It's also true that getting out of the saddle for about 1 minute out of every 10 is a very good idea, no matter what saddle one rides.
If the ED is not from a numb dick, then usually it's a circulation issue, i.e. cardiovascular. The study you found linking ED to aspirin found correlation, but not causation. There seem to be more people who think taking aspirin helped their ED because it can be a cardiovascular issue. I'd ignore the aspirin issue for now and focus on saddle (if appropriate) and cardiovascular issues. You could try taking 3g of citrulline malate 3 X day. That's been reputed to help circulatory problems of this sort. https://examine.com/supplements/citrulline/
Having your T checked is also a good idea.
Results matter
Results matter
Average Idiot
Bikes: 88 Davidson Impulse, 90 Specialized Hard Rock, 09 Specialized Allez, 17 Specialized Diverge
Quoted: 18 Post(s)
Before we over think this, too high a training load kills libido. You may just need a break to catch up.
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Quoted: 67 Post(s)
Liked 7 Times
You guys know who Jens Voight is, right? The former 35,000 mile a year pro with seven kids and a perfectly fitted bike?
At 20,000 miles a year back in the day, all my teammates have not had an issue based on the kid count.
My guess is this is a fitting issue putting too much pressure "down there" and pointing the seat down is not the answer.
Suggestion I already saw was give it a rest for a while, get your fit checked, and make sure you have a good pair/pairs of bike shorts.
Thirty miles a day is not a lot of miles, although it is above the typical average for recreational cyclists.
Casually Deliberate
I agree it's ridiculous but doctors are sometimes sloppy or in a hurry. I once had my physician of several years ask if I was making any progress quitting smoking. I reminded her that I had never smoked and offered to give her a few minutes to review my chart before we went any further. It happens...
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Thirty-six posts and no one said "just HTFU." It is a civilized forum after all.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4339 Post(s)
Liked 2,982 Times
Quoted: 32 Post(s)
Liked 5 Times
First, make sure you stand or at least lift your butt off the saddle every couple of miles. Next, be certain you have the right position/adjustment for the saddle. It should be relatively level with a slight bend in your knees and most of your weight over your sit bones. Lastly if those two don’t work, experiment with different saddles.
He didn't toss it off. I went through a battery of tests first with the VA, then my private doctor. My follow up was to today and told me to lay off the asprin because my tests came back and said I was salicylate intoxicated at the time of my tests.
Quoted: 18382 Post(s)
Liked 4,515 Times
Well, I'm glad you're following up on this.
I have wondered a bit if pain meds are addictive, and perhaps one can learn to deal with the pain without the meds. Even over the counter meds like Aspirin.
I've had achy knees for a few years, but have discovered that the more I ride, the less the knees ache. I also have changed my sleeping which has improved the back. Oddly, sleeping in a chair seems to have essentially cured a low level back ache that I have had for decades, to the point where I can sleep almost anywhere now, and wake up pain free.
NO BELTS!!!
NO BELTS!!!
Quoted: 20810 Post(s)
Liked 9,456 Times
NYC
Quoted: 1169 Post(s)
Liked 107 Times
With that much T, I'd expect near instantaneous penile reflexes.
At least until one of my nuts blew up and had to be removed.
NYC
Liked 107 Times
I think of a "numbness problem" as being that I had to wiggle or stand for 15 seconds to get the blood moving.
I can't even conceptualize someone just letting it be numb for 6 hours and just assuming it would still work fine the next day.
Does he ignore the oil light in his car too?
Quoted: 32 Post(s)
Liked 5 Times
That was probably a year back and the numbness didn't start until after I got a half-assed biking fitting. The erection thing started a few months back.
Liked 9,456 Times
Holy bajeezus, Batman! That's insane!
Liked 1,944 Times
Numbness sneaks up on you on a long ride. It doesn't hurt, seems OK, but it you reach into your shorts, you can easily feel you have a problem. Without that, you don't really know. If you have enough numbies, you wind up with ED. The little damages accumulate. The OP sounds like a poster child for cycling-related ED.
Results matter
Results matter
Bikes: Trek Emonda SLR, Colnago CX1 EVO
Quoted: 23 Post(s)
So much misinformation so little time. First 30 miles isn't a long enough ride that you should have any issues. Numbness, ED and lowered libido are three separate but inter-related things. Numbness is a nerve issue, ED a blood vessel issue. The average sports medicine doc is either orthopedically or family medicine trained and doesn't know much about any of these, a urologist(like me) is who you should be seeing. Unlikeliy its a Testosterone issue given your age but easy to check. A one time problem can occur with anyone, you don't say whether its ongoing on not. See a urologist.
Quoted: 174 Post(s)
Good advice here. I agree completely. Classic example of medical advice on a bicycle discussion forum. I'd be amazed if the OP's problem was saddle-related.
Liked 4,515 Times
I don't see notes whether anybody has asked...
Is the OP wearing padded bike shorts or bibs?
The padded shorts can make a seat much more comfortable.
Casually Deliberate
