Shimano crank recall
#51
For aesthetics I prefer the Csmpy Record of the 80’s, but 7410 is pretty nice. Looking at these failures, I feel good with my affection for cold forged, solid, square taper cranks.
#52
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,449 Times
Likes For Polaris OBark:
#53
So, how often can you go for an inspection? ..
Imo, the product lines are faulty by design and prone to delaminating. Thus, by not replacing every single crank they create a need for regular inspections of every non-replaced crank in the affected series.
Likes For Racing Dan:
#54
Quoted: 4425 Post(s)
Liked 4,876 Times
If Shimano end up having to replace 760,000 cranks in the US alone, perhaps millions worldwide, then we can expect future Shimano supply issues.
#55
Du you even trust your local dealer to accurately diagnose defects by eye? Who is liable if the crank breaks after the LBS deemed it good? Shimano, LBS or YOU?
#56
I got the email from my bike shop last week, brought my 2017 Domane with 14,000 miles on it for the inspection. The next day they called back, their inspection, and theoretically Trek looking at photos, showed no delamination, etc. The claim is that the vast majority of the 1% of cranksets that failed did so within the first few years.
Definitely not clear what happens if it fails from here. The frame and fork have a lifetime warranty against manufacturing defects. With a recall out, I'll bet that will be true for these cranksets. But, having one fail while riding is something I'd rather avoid.
#57
Liked 4,876 Times
Sure. So what? By not replacing every affected crack, they are not solving the safety problem, unless they implement a routine inspection of every crank, for the life of the products. It appears they didn't outside of one initial inspection. Honestly its BS, leaving the customer in limbo, as soon he/she has had the one scheduled inspection.
In an ideal world it would be nice if they could just send out 760,000 new cranks, but I’m guessing that’s simply not an option.
#58
Liked 4,876 Times
#59
Bikes: SL8 Pro, TCR beater
Quoted: 990 Post(s)
Liked 586 Times
Good thing the 12sp aren't part of this recall.
If I am not mistaken, they are also hollowtech. Does someone know what's different between the 12sp and 11sp?
#60
Liked 3,449 Times
#61
Quoted: 3241 Post(s)
Liked 2,512 Times
I agree. Unless they found something specifically defective such as adhesive, it goes back to a faulty design. The current approach is not increasing confidence on the consumer side.
#62
I would hope that longer term, once they have the replacement cranks manufactured in quantity, that Shimano would offer a discounted replacement for affected cranks - ie, even if your crank isn't delaminating, you can take it in to your LBS, who will replace it for $100 with a (supposedly) safe crank. For anybody who's concerned it would offer peace of mind, and it would earn Shimano some goodwill amongst all of us that spent solid money on Ultegra and Dura Ace. Honestly, the best goodwill is to build something with bulletproof reliability in the first place, but I digress.
Considering I've been told what to look for, I'm ok with riding my cranks for now, but if Shimano doesn't:
a) take care of their customers
b) doesn't clarify what structural changes were made between late R-code cranks and later builds (including R71xx, R81xx, and R92xx cranks)
I can see a lot of people losing trust in the Ultegra and Dura-Ace brand names. I hadn't been planning on a new performance road bike, but given the newfound lack of trust, I'm entertaining the idea of getting something SRAM Red or Campy Chorus (or Record?) equipped in the next few months.
#63
Quoted: 2490 Post(s)
Liked 2,961 Times
In one of the other threads on the crank recall, someone reported that since Shimano's factories are apparently no longer set up to produce 11-speed cranks, they're going to use different spacers to retrofit their 12-speed cranks as 11-speed.
#64
Quoted: 990 Post(s)
Liked 586 Times
Read that too. From what I understand, 12sp have the ''Hollowtech II'' technology. I hope they figured out how to better bond their components. For what it's worth, I never had any issues with the 2 bikes I owned that were equiped with 11sp Ultegra.
#65
Liked 4,876 Times
They have all been named “Hollowtech II” since around 2004 when they went to external BB bearings.
#66
Quoted: 990 Post(s)
Liked 586 Times
Oh, OK! Well, this confuses me even more as to what changed between the 11sp and 12sp Ultegra and DA that makes the 12spd not part of the recall. I thought they were manufacturing them differently now. May-be they're too recent or something.
#67
Klaatu..Verata..Necktie?
Quoted: 10445 Post(s)
Liked 11,929 Times
It's not just 12 speed cranks that aren't part of the recall. It's also 11 speed made after July 2019, which seems awfully specific, which suggests they made a change in manufacturing technique during the run.
Likes For genejockey:
#68
Liked 4,876 Times
I would imagine Shimano were well aware of this manufacturing issue with some of their 11-speed cranks when 12-speed was designed. So I presume they tweaked the process to avoid the issue. Time will tell.
#69
Bikes: yes, i have one
Quoted: 1141 Post(s)
Liked 1,182 Times
my crank is not in the recall group (yet), but regardless i'd like to know what a failing inspected crank (that was otherwise considered ok by the user) looks like just so i can look out for any signs.
Likes For spelger:
#70
Dave
#71
Quoted: 1200 Post(s)
Liked 1,356 Times
I've got DA 9000 on my Bianchi. I inspected it myself but ill have to keep an eye on it from now on.
Likes For malcala622:
#72
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
Investigating Shimano’s snapping cranksets:
What happened, unanswered questions and an engineer's report
https://road.cc/content/feature/inve...anksets-304173
#73
Liked 1,356 Times
Alot of the pictures I've been seeing of snapped cranksets I've noticed a few things.
1. The chainrings are super worn out.
2. There's some extensive shoe rub on the crank arms.
Both these would contribute to fatigue in cranksets. Just my observation and in no way am I saying shimano is in the clear.
#74
Quoted: 682 Post(s)
Liked 453 Times
Both these would contribute to fatigue in cranksets. Just my observation and in no way am I saying shimano isn't in the clear.
#75
I took my bike in last week, 6800 series groupset. No visual problems, but neither of us wanted to leave the bike at the shop during prime fall riding season.
We're traveling in December and it is often too cold and wet to ride anyway. I'll have them do the full deal when they do my seasonal refresh.
