Hydraulic brake pull distance
Liked 2,981 Times
I probably already know my answer, but figured I'd ask here just in case.
For hydraulic brifters, the reach adjustment is always set to obtain the longest reach as my meathooks dont have an issue gripping & pulling the lever.
What I'd like to know is if that adjustment hinders bleeding the brakes?
Can that adjustment feature be repurposed to better enhance applied braking with some kind of modification?
-Oh Hey!
-Oh Hey!
Quoted: 6199 Post(s)
Liked 4,816 Times
Actually there are two different adjustments. One is for brake lever reach. And the other is for how much the levers travel before they engage. So be sure which you actually have.
Liked 2,981 Times
I'll have to look, but I only have identified a reach adjustment.
The unused reach dead space would be nice to repurpose for allowing pad tolerances to change.
-Oh Hey!
-Oh Hey!
Klaatu..Verata..Necktie?
Quoted: 10445 Post(s)
Liked 11,929 Times
The previous (11 speed) version of the disc brake brifters, Dura Ace and Ultegra had both reach and "free stroke" (travel before pads touch) adjustment, but 105 had only reach. I don't know about the new 12 speed generation of levers.
Likes For genejockey:
There is no magical way to increase pad retraction. I have the opposite problem where I have to set the levers as close to the bars as possible, without the levers bottoming out on the bars. My SRAM Force AXS levers have contact adjustment, but all it does is add dead band, so it has no value for me. The default position with the adjuster turned fully CCW is used when bleeding and never needs to be turned CW.
Quoted: 4423 Post(s)
Liked 4,876 Times
