Does size matter?
Bikes: Cervelo Soloist, Giant TCR Advanced, Co-Motion Americano Co-Pilot
Does size matter?
I am outfitting a touring bike and am close to the pedal decision point. Given my shoe choice (Shimano M162L Mountain Bike shoe), it will be a two hole/SPD/Crank Bros choice. At this point I am indifferent to the cleat/pedal and am "sizing up" the pedal options.
My road bike history is hot-spots with Speedplays at 80miles...but excellent experience (cross country in '07) with Look Keo's.
Here's my question: Does the size of the pedal make a difference? Assuming the soles of the shoes actually make contact with the pedal, this could mean that a larger pedal distributes pedaling force over a wider pedal surface area...a good thing, I think...should minimze my hot spots.
Any insights on whether most mountain bike shoes will actually make contact with these pedals outside of area in which the cleat engages the pedal??
My research into MB pedals tells me that some have relatively small platforms (like Speedplay or Eggbeaters) and others (such as Crank Bros. Candy or many of the Shimano MB pedals) have much larger platforms. Can I infer that the bigger pedals will be more comfortable?
If so, what's the trade off?
Thank you!
Bob
Thank you!
Bob
To some extent the stiffness of the sole will affect that. If the sole of the shoe is very stiff, the pedal size will matter a lot less. So I go with stiff soled shoes and small SPD pedals. That may or may not work for you but might be something to consider.
I got most comfortable for my really long tours, by leaving the clipless pedals off ..
toe clip and strap pedals
then my shoes with a loose fit worked well..
shoes for the performance oriented fit tight, its required,
so your feet dont pull out of your shoes..
Obviously YMMV..
Better.. Blood flow and no nerve compression .. I found my favorite insoles,too ..
4 month tour NL to BE, F, UK , N,DK,PL,CZ, As, DE, F, BE. & NL..
9 month tour SW Ireland To NE Scotland
Obviously YMMV..
Bob, I wear a semi flexible mountain bike shoe with some Richey SPD style mountain bike pedals (Similar to Shimano.) because of the walking tourista moments. I have some very stiff soled road shoes which are very good for riding, but less than ideal for walking.
My back up touring bike has platforms. They're the first non SPD pedals for me in the last twenty years and keeping in mind it's a recent build with few miles under me, a platform pedal can also work with a touring bike. They do feel a little strange right now.
Brad
Brad
I managed to get hotspots with carbon fiber road shoes and Speedplay pedals...stiff sole + small pedal= hot spots (for me). No need for me to re-test this theory.
I think I want an SPD or Crank Bros. clipless pedal which offers the greatest contact area with my (pretty stiff) Shimano MTB shoe.
As I look at pedals, the designs all have a central "cleat engagement device" (either SPD or Crank Bros.) and this is usually surrounded by a more traditional pedal mechanism. What I don't understand is how much of the MTB shoe's sole (other than the cleat) will actually engage with this pedal mechanism and thereby transmit pedaling force to the cranks. Or, does all of the pedaling force transmit through the cleat/pedal interface?
Said another way...all these Shimano SPD pedals (just to pick one manufacturer)have very different pedal designs, other than the SPD part itself. Why bother?
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
I use Look Quartz MTB pedals, which are discontinued but can be had for a steal at Nashbar. With this pedal, you shim the cleat to a depth that lets the shoe rubber engage the plastic or carbon sides of the pedal. I have never had any hot spot issues, and have seen shoe rubber wear out at about similar timing to the cleat, so I know that the rubber is engaged. I have used them with Specialized MTB shoes, LG shoes, and Northwave shoes, and through use of the included shims, have been able to get identical fit every time.
rainycamp
16
02-07-11 10:15 AM
