26" tires?
Quoted: 541 Post(s)
Liked 466 Times
26" tires?
What are some light fast 2" to 2.2" X26 " light gravel-sand tires currently available? I just bought a really light Marin all aluminum 3X9 with 26" wheels. I put some 2.1's on it and it is super light and fun ride. I might grind some local dirt roads and I want to keep it as light as possible. I might go Compass but not sure if 2.3's will fit without rubbing on a hard flex.
Rat Trap Pass is labeled 2.3" because Panaracer uses the same silicon bladder as their 2.3" MTB knobbies in the tire mold, and they didn't want to get it mixed up in manufacturing. They're actually around 2.1", unless you mount them on fatbike rims.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
There's a good thread going in C&V: https://www.bikeforums.net/classic-v...el-thread.html
The Rat Trap Pass is not a full 2.3". Their own website admits that it maxes out around 2.15" if you do the math.
Quoted: 541 Post(s)
Liked 466 Times
Sold as a BMX tire, but Maxis DTH comes in 26x2.10 and 26x2.30. There are others such as the Schwalbe Billy Bonkers
The two I know of that are sold as a gravel tire are the Rene Herse Humptulips Ridge (previously mentioned) and Panaracer Gravelking. You can also look at XC or touring tires.
Quoted: 541 Post(s)
Liked 466 Times
on your lawn
WTB All Terrain are light and fast, but I haven't been able to find them in 26" lately.
Panaracer Gravelking SK in 25x2.1. Enough float and low rolling resistance while still being being grippy in gravel.
Likes For commo_soulja:
René Herse Rat Trap Pass are wonderful tires. I’ve ridden them on day and bikepacking rides on mixed surfaces for >5 years, and I’ve built up bikes for friends with them who have done the same. They truly transform a 26” MTB frame. I find them suitable for pretty much anything but single track. The new René Herse Humptulips will be better if your riding includes a mix of road and loose dirt.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 275 Post(s)
Liked 244 Times
Quoted: 541 Post(s)
Liked 466 Times
I am putting the RTP's on an all aluminum Marin Novato I just bought for $100 off craigslist. It is a surprisingly light, nimble ride set up 9 speed Deore. The V brakes are better than my mechanical discs and the bike has been very fun to ride. I actually bought 2 of them for $100 each so I have 2 sets of wheels that can be changed in about 1 minuet. The bikes came with good 26" X 38mm tires which I have never seen before and I threw a set of 2.1" knobby tires on to try. They transformed the bike into a very fun grinder, but they weigh nearly 800grams and are mounted with Walmart green slime filled tubes no less. LOL. Can't hardly wait to try out the RTP's.
I've set them up both/all ways: tubeless with Stan's tubeless rims; tubeless with a Velocity Dyad rim (which I think Velocity says are not tubeless-ready, but which has worked for me with Stan's tubeless tape & sealant; note that I've only done this with a *rear* wheel, including because the downside risk of front wheel failure seems much higher); and with tubes, including standard butyl and Tubolito. I run them around 30 PSI / 2 bar.
I'm pretty sure all my RTPs have had the Extra Light casing, and neither I nor my friends who I set up with these tires have had any issues, even with bikepacking bags on fairly rough terrain. (Notwithstanding how versatile the RTPs are and how much I like them, I'd advise against using them - or other slicks - on singletrack.) But I plan to try the Endurance casing when it's time to replace my current tires.
Liked 2,571 Times
I'll be interested to hear how you like the RTPs... as much as I enjoy the smaller Naches Pass, I didn't want to guarantee anything since you had mentioned "sand" in the OP. I don't deliberately ride in sand.
Quoted: 541 Post(s)
Liked 466 Times
Me either. Didn't mean to throw anyone off. That was more of an old guy way to describe possible road conditions. I didn't mean that I was looking for sand specific tires. I don't ride anything very aggressively, just fast enough for fun without too much risk.
Likes For RH Clark:
