Rear light bracket for my Brooks B-17 saddle
I'm looking for a rear light bracket for my Brooks B-17 saddle. My rack has a steady light attached, but I'd like to add a blinking light for additional safety. I have Bontrager, CatEye, Nite Ize and other lights that I can use. My rack bag doesn't have a rear loop (WHY???) so that won't help plus I don't always use my rack bag anyway.
Thank you.
Thank you.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 160 Post(s)
Liked 134 Times
I must be missing something: why not use one of the many lights that attach to the seat post?
Quoted: 3465 Post(s)
Liked 1,470 Times
This mounts on the saddle rails, but it is specific to the German taillights that have 50mm spaced bolt holes.
https://www.perennialcycle.com/busch...ail-mount.html
And the B17 saddle has a very short length adjustment range for saddle rails so if your saddle was unusually far forward, this might not work.
Quoted: 2609 Post(s)
Liked 1,945 Times
If that's the O.P.'s setup as well, I used a cargo net to hold the racktop load. That made it possible to use a clip-on light, which would normally be clipped onto a jersey pocket, clipped on the cargo net at the rear of the bike. Alternatively, clipping the light onto a saddle bag with a loop at the rear might be high enough to clear the racktop load.
Quoted: 160 Post(s)
Liked 134 Times
Ah-ha!
Liked 1,470 Times
Not the OP, but seatpost mounted lights are often invisible on my bike with a tent or sleeping pad on the rack behind them.
I only use taillights mounted on a rack, seatpost or seat stay so that I can carefully aim them towards where the drivers behind me are.
Liked 1,945 Times
I used to commute through a college campus to and from work. And even in winter there were a lot of bicyclists. In November through January when it was after sunset on my drive home I often saw bicyclists with blinkers attached to backpacks, or strapped to a small saddle bag, or some other piece of fabric that prevented them from carefully aiming the taillights. And they were often worthless because they shined towards the sky or pavement. Typically when I saw these blinkers, it was when I was only a few tens of feet behind them. Or, perhaps they were worse than worthless because the riders may have had a false sense of security thinking that they were actually seen.
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1093 Post(s)
Liked 1,840 Times
I hear you. Instead of questioning your motives or basically calling you dumb, I'll tell you what I made for my own B-17 using parts from a local co-op.
My co-op has bins upon bins of kickstands and kickstand parts.
I used two of the top part, the part that sits over the chain-stays, and bent a little bracket, ran a bolt/nut though there and it works great, providing light over my rack and the occasional 6-pack strapped to it.
Hope that was helpful.
"Leave the gun. Take the Colnagos."
Quoted: 977 Post(s)
Liked 1,638 Times
Anyway, send me some specs and I'll give it a try.
Likes For zandoval:
Liked 1,470 Times
This looks like a fun 3D Printer Project. There are plenty out there and finding one could be tedious. Note that bikeforums.net does not have a specific area for proven bicycle related 3D printer links YET... Go Figure...
Likes For Tourist in MSN:
I like cats.
This is such a great idea! I recently got a CNC-ready Taig mini-mill, still struggling to get everything playing together but nonetheless excited for the day when I'm cadding and camming my little heart away.
Likes For ericoseveins:
My bad. I left out the fact that it's for a Brompton so attaching a light to the seat post or putting a bag under the seat would interfere with the fold. The light attached to my rack is the Brompton light which doesn't blink per some/many European standards. Hence, an attachment to the B-17 rails is what I'm looking for.
The round mount above won't work for my tail lights, but the zip tie idea should work if I can keep the light fairly perpendicular to the ground.
Liked 1,470 Times
If you try this, put some tension on the rubber when you wrap it around the rack tubing to make the rubber grip the tubing better so it does not move later. I used a bit of tape on the rubber when done wrapping it so that it stayed there for the minute it took to deal with the seat stay bracket.
When touring, I like two lights in back. One is usually a spare, the other is flashing. The light on the left has a very narrow tight light beam straight back, but on a winding and hilly road I use the light on the right instead that has a wider beam.
Likes For Pratt:
Palmer
Quoted: 1671 Post(s)
Liked 1,832 Times
I got one of these (example, several sources):
https://www.ebay.com/itm/335048283793
And used one of these to mount a CatEye taillamp:
https://www.cateye.com/intl/products/parts/5445620/
CatEye offers a direct rack-mount taillamp, too.
https://www.cateye.com/intl/products...hts/TL-LD580G/
Bob's your uncle:
Bob's your uncle:
Palmer
Liked 1,832 Times
Palmer
Liked 1,832 Times
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
I have a 3D printer, a couple of brooks and have already made a light to rear mount bracket. Give me a better description of how you want to mount and I’ll give it a go. Are you wanting to mount the light to the bag tabs at the rear of the brooks, the saddle rails, or…?
ignominious poltroon
Quoted: 2252 Post(s)
Liked 3,459 Times
Then there is this: https://buplabs.com/
Palmer
Liked 1,832 Times
