Is there any way to look up
Bikes: 2012 Fuji Cross 2.0, 2015 GT Grade 105/Ultegra
whatspecs mean? For example:Wheelset- Alex ACE18 alloy double-wall/eyeletted rims,700c,36H, Ritchey Road Comp hubs, Double butted 14-15g stainles steel spokes.
Whats the difference between 32H & 36H?
Double butted vs single? etc,etc,etc
TIA
TIA
32h = 32 holes in the rim = 32 spokes
36h = 36 holes in the rim = 36 spokes
700c is the size of the wheel.
Butted spokes get smaller in the center to save weight.
Eyeletted rims have a small eyelet around the hole, they are said to be a little stronger.
Hope that helps
Hope that helps
Bikes: 2010 Tarmac SL, 2013 Fairdale Weekender, 2013 Fairdale Coaster, 1995 Specialized M2 Pro, 1972 Schwinn Heavy Duty, 2014 Surley Long Haul Trucker
Obviously, the more spokes you have, the stronger the wheel will be... assuming the spoke tension is correct. If you're overweight or just a heavy dude, I'd recommend 36 spokes. The "typical" bike has 32 in the back at least. A radial laced wheel will typically have 28.
Time for a change.
Liked 5 Times
Exception comes about when you start looking at quality wheels and they are made with less spokes but lighter rims and lighter hubs contibute to the weight loss aswell. You do also have a problem in that although that quality wheel will be strong- break one spoke out of the 16 fitted and you have an unridable wheel till it is fixed. Lose one spoke on a 36 and although it may go out of true- you can still get home on the thing.
Spike Milligan
Spike Milligan
