Max Tire Pressure Label (700 x 32)
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Pressure is esoteric. What works for one is not assured to work for you.
If it says 70 on the sidewall then try not to inflate it to 140. All things have a safety factor involved.
Keep in mind I still put 100 psi into dry rotted hookless Schwinn tires that roll in here on a daily basis.
Also keep in mind 70 on that big of a tire is most likely too high for your weight.
Have fun on your journey.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
I'm a fat dude way over your weight. I run GP4000 32mm on my road/gravel bike. I run 60-80 in rear and 40-60 in front. (start at high pressure and add air when lower pressure is reached) never had any problems with flats. 70psi and below is where you want it. Might as well run 28mm tires if you run any higher pressure.
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,531 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
That can't be answered with one number, of course.
RUSA #7498
Originally Posted by noglider
Quoted: 20810 Post(s)
Liked 9,456 Times
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
I'm personally more interested in quantifiable, verifiable, and replicable studies than I am in "I like to ride at X PSI." Subjective anecdotes are just that.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 18883 Post(s)
Liked 10,646 Times
Yeah, there's no one right answer. A lot of things come together to figure out the best pressure, like how heavy you are, how you distribute your weight over the front vs rear wheel, the surfaces you ride on, and how you want your bike to feel. But most people think the lowest pressure you can get away with and be happy with is the right answer.
Likes For Seattle Forrest:
Quoted: 427 Post(s)
Liked 699 Times
Most tires will perform a bit better at less than their max limit. Here's an article I found informative: https://www.roadbikerider.com/the-ti...-jan-heine-d1/
Likes For freeranger:
Bikes: Bianchi Oltre XR4 Celeste, De Rosa SK Pininfarina, Giant TCR SL, Giant Revolt Advanced Revolt 0 Gravel Bike, Trek Madone SLR, Cervelo R5 Disk
Quoted: 376 Post(s)
Liked 124 Times
I’m around 150-lbs and put 65/60 psi in my 32mm Conti 5000 TL’s.
Likes For Noctilux.95:
Administrator
Quoted: 11960 Post(s)
Liked 6,629 Times
Nice job with the closeup photography, nice clear pictures, well lighted and in-focus, a rarity in these parts.
Likes For BillyD:
Quoted: 4717 Post(s)
Liked 1,882 Times
The OP can probably benefit more from someone about his size, that rides a similar bike(a Domane), with similar tires, on the same roads. I have over 90k miles of experience riding the roads in his area, so I have a pretty good idea of what will work well.
Likes For noodle soup:
I think the 15% drop method used by many online calculators to determine tire pressure is a good starting point for tubed tires.
I'm guessing a smaller tire has less room for error because 85% of a 25mm tire for suspension isn't much.
A stiffer tire casing may work well with less pressure, And if you don't plan on climbing curbs, we might get away with less pressure too.
That said I try to keep close to the min and max pressure range printed on the tire. Those numbers are there for a reason.
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 923 Times
You know, it doesn't cost anything to experiment with different pressures to find out what works best for you.
Likes For TakingMyTime:
The articles with data can explain how the various parameters affect performance so riders can dial in the behavior the think is best for them. Only someone with a very limited outlook would think their personal preferences would apply universally or that their solution for how to get to that point is the only one.
Likes For asgelle:
Liked 1,882 Times
If you spent the amount of time I have on these roads(and worked in a few Phoenix area shops), you'd have a far better understanding of what works, and what doesn't(for riders with different needs). It's not just what works for me, but for riders that I deal with on a daily basis.
Imo you should not exceed the max pressure recommended by the manufacturer, but other than that, its highly subjective what pressure is "right". Just take note of the pump gauge and try out different pressures for yourself.
Likes For Racing Dan:
Liked 10,646 Times
The folks that write user manuals do not manufacture tires. Heck, they may not even ride bikes.
Stick to the numbers on the tire, the manufacturer knows the safety standards. I don't know who
makes the tires for Bontrager. My LBS sticks to whatever is on the tire. Ditto for your car tires.
My 700 x 32 has on the side of the tire 50lbs psi minimum, 85lbs psi max, I'm riding on 80 lbs psi, think I'll drop to 70 and see how that works. Interesting thread here, and destroyed my thinking, which was, higher the psi the less resistance the more efficient the bicycle.
Likes For bikerbill2:
I have no idea how all of yourun such low pressures. I’m only 160 pounds and if I’m not within 5 PSI of the side wall recommendation, my rims are practically rubbing the ground.
I'm 160 as well, so I'll see what 70lbs psi does coming off my 80lbs with the 85lbs psi max. I know that at 80lbs psi riding on a wet pavement I can see only a very small wet imprint on the front tire, which means a small tire contact patch with the pavement.
