Any real benefits of 11 speed over 10 speed?
#51
Vain, But Lacking Talent
I've got 5700 10 speed on my Crockett and DA9000 11 speed on my Domane. Honestly, aside from the extra cog and the front end shift being super smooth and easy on the longer arm of the DA9000 front mech, I barely notice any real performance difference. I still want to upgrade the Crockett to 11 speed.
#53
No. I mean 12x142 spacing that lots of road bikes with thru axles use. It was mainly designed for disk brakes, but it also has some advantages when using a wider cassette, as it allows to move the cassette outwards together with the DS spokes, thus making the wheel stronger.
#54
Quoted: 1975 Post(s)
Liked 232 Times
#55
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
12 speed is already here and eventually Shimano will catch up with SRAM and Campy. The trend with 12 speed is to increase range, not the decrease the spacing between sprockets. The sprocket spacing on the new Campy 11-34 is 11-12-13-14-15-16-17-19-22-25-29-34. It retains all of the close spacing, up to the 19T, before increasing the percentage of change between the sprockets. The tightest spacing 11-29 is the same, up to the 19, then it's 21-23-26-29. Some users are whining that there is no 11-27 that includes an 18T. I've never opted to have a cassette with an 18T sprocket.
As for the rear wheel dish, it's been the same for Campy since 9 speed in 1997. Campy solves the spoke tension issue by using half as many spokes on the nondrive side as seen in the Fulcrum 2:1 pattern or with groups of three spokes - two for the drive side and one for the nondrive side. The current Zonda wheels are very reasonably priced. They use 16 spokes on the front, radially laced and 21 spokes in the rear - 7 groups of 3 spokes.
#56
Advocatus Diaboli
Quoted: 4734 Post(s)
Liked 1,532 Times
I think I'm missing the good ol' 10 speed days. I'm riding fewer miles now than ever before but it sure seems like I'm going through a lot of 11 speed chains. I know more is almost always better but other than slightly tighter ratios between each gear are there really any benefits to 11 speeds?
Likes For Sy Reene:
#57
however, if you did not stack up the parts , it is not easy to find components and make the drive train that is the best for you, particularly using Shimano parts that are scarce and last around 40% of the campy parts life span, again, based on my experience...
nothing is simple in BF's....
#58
Comparing the life and quality of an HG40 vs a CM9100 is not apples to apples.
Likes For u235:
#59
Advocatus Diaboli
Liked 1,532 Times
The original source article linked below -- feel free to review.
https://cyclingtips.com/2019/12/the-...10-11-12-speed
#60
Quoted: 40 Post(s)
Liked 9 Times
Good point. I didn't extend my cass gear range moving from 10spd to 11, so the extra gear is imperceptible. I appreciate tight gearing to keep my cadence in the sweet spot, so I'm sure that's been helped a bit - but, I rarely recall the 10spd giving me issues in that regard. Also, the extra gear didn't make me faster (grrr).
Likes For Johnny Rad:
#61
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
It's also only one extra gear in one spot, whether it's gaining an 11, a 28/30/32/34, or a single gear in the middle (a 16, maybe). If that's not a spot that's bugged you, or you're happy with your previous range, 11-speed isn't going to give you much benefit. Chain life is nice, but no one is going to spend at minimum a few hundred on the upgrade to get marginally longer chain life.
The only reason we changed to 11-speed was to get Di2 on the tri bikes, where it makes a big difference.
Likes For Bah Humbug:
#62
Quoted: 2952 Post(s)
Liked 3,106 Times
It is nice to always get a 16, which you don’t always get on a 10spd cassette.
#64
Jazz Aficionado
When I had my very nice and Expensive Waterford RS33 custom built for me by a very prominent local shop here in the Denver Boulder area, unbeknownst to me at the time, but 11 Speed Campy Grupo was just introduced... but the shop installed 10 Speed Campy Record and never told me about the 11 or gave me a choice. Years later, the 10 Speed has been fine, but parts, like the middle chain ring of the Triple are getting scarce, so the shop tells me. Just an added thought to the conversation about 10 vs 11.
#65
Quoted: 8 Post(s)
Liked 6 Times
I have an old Giant wet weather bike with 9 speed 105, it hasn't missed a beat in years and is far smoother than my 10 speed SRAM Red (black edition) which I seem to be constantly adjusting.
#68
Likes For jefscolnago:
#69
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#70
Quoted: 1529 Post(s)
Liked 718 Times
But I have no idea what you're talking about otherwise; I'll take my 10s Red over poxy old Campy 8s in a hummingbird's heartbeat. I'm prepared to trade the clunky lever feel for its lightweight minimalism. I appreciate the spartan elegance of its design. No silly clockwork to seize up if the grease gets a bit stiff, no G springs to go soft. Hardly anything in there; mine have never missed a beat. Sure the Yaw FD is a bit of a fiddle to set up, but I reckon it's the tits - trimming be damned. The levers are plenty ergo and look great. IMO the whole group (2nd gen) looks great.
Mind you, it's Shimano all the way for my hubs, chains and brakes.
#71
With the latest Shimano 11-speed, 11-34 cassette can be retrofitted to in an older 10-speed hub (you either need or don't need the spacer) and now gives you a 1-to-1 gear option with the commonly-found, 105 compact 34-crank ring and RD.
#72
Liked 718 Times
I wonder how long the super wide gears fad is gonna last before folks decide they're sick of big jumps... gonna be a whole heap of peeps shopping for 11s wheels so they can use something other than 11-34.
#73
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
I've wondered that as well. The gravel racing world is in the midst of a debate over 2X or 1X. I just don't understand why anyone would ever want the cadence jumps associated with a 10-42 cassette.
Likes For Cypress:
