Can I use 15 mm thru axle wheel with a 12 mm thru axle fork?
Quoted: 82 Post(s)
Liked 8 Times
Can I use some sort of shim to make it happen or I need to rebuild the wheel and if so, can I use the same spokes or do I need a new one (when rebuilding I would also change the rim itself). What do you think?
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
What make and model of wheel? That determines what kind of operation you have to do to make it work.
Quoted: 1221 Post(s)
Liked 628 Times
Maybe. I helped my friend convert his bontrager duster wheelset, rear was 12mm, front was 15mm. He bought a conversion bushing online. However I had to turn down the outer dust caps on a lathe. The OD of the dust caps didn't fit into his fork, so I turned them down by maybe 1mm? It was just clearanced to fit.
Liked 406 Times
Looking back as far as the MY2017 PDF charts they have posted, 12mm endcaps aren't even listed as an option for M1900 Spline wheels.
Quoted: 353 Post(s)
Liked 92 Times
You have to look at the hub not the wheels themselves. M1900 Spline are DT 370 hubs. This is what you need:
https://www.worldwidecyclery.com/pro...0mm-front-hubs
Quoted: 82 Post(s)
Liked 8 Times
Bikes: Two Independent Fabrications, a Niner RLT, and a Trek Domane
Quoted: 10 Post(s)
Liked 16 Times
Talk to the hub manufacturer. I have adapters for my ENVE hubs so I can run the wheels on my 15mm Niner RLT fork and a 12mm Trek Domane fork.
Likes For gravelfan:
Quoted: 1088 Post(s)
Liked 1,022 Times
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I've bought 2 of these, when I built wheels for my wife and my gravel bikes I wanted to use new XT hubs which are usually reliable. With mine the front hub slipped into spot with no trouble, with my wife's there was a drip that was in the way, turned out to be a touch of epoxy but it scrapped down perfect without scratching the carbon and fit perfect. The tubes are a little trouble to fit in, have to give a real good push and don't easily come out.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
There is a guy in the road forum who designed some slide in spacers to convert axles from 15mm to 12mm.
Shoot him a private message and see what he has.
Joe Jack chinabomb build
Quoted: 1975 Post(s)
Liked 232 Times
