Best way to prevent getting salty sweat in your eyes?
Quoted: 7345 Post(s)
Liked 2,452 Times
@chas58, my feelings about merino are the same. I can only wear a synthetic jersey or shirt once, because it does stink, but the same is not true for my synthetic cap. I don't know why. I wear a wool or synthetic hat in the winter but no wool in the summer. And yes, it's amazing how many times I can wear a merino shirt between washings. Sometimes ten!
Liked 2,452 Times
@SylvainG, I wear them for various periods. You're right that drying them quickly after wearing them can help. Still, merino is worlds better at not absorbing odor. In the winter, I wore ONE merino t-shirt as an undershirt, every day except laundry day. I even skipped laundry occasionally.
born again cyclist
i'm an extremely heavy sweater, so this has been an issue for me. i found a pretty good solution that works for me by accident years ago.
the forehead foam padding at the front of my helmet started to poke out of its fabric shell, kind of creating a "V" shape, pointing downward
what happened is that gravity started to pull the sweat down to the bottom of the foam "V" (instead of onto my forehead) where it then dripped out like a leaky faucet.
perhaps it'd be a little gross to some to see their sweat drip... drip... drip... dripping right in front of their face, but hey, as long as it ain't going in my eyes, it's a win for me.
Quoted: 18350 Post(s)
Liked 4,502 Times
I'm a bit down on riding this summer..
For errands and such, I take the sweatband off at every stop, then rotate it so there is a dry spot over the forehead. Sometimes ringing (or ringing the helmet sweat pads).
This is a different approach that I prefer:
www.traxfactory.com/shop
Also available on Amazon. This replaces whatever front 'band' is in your helmet. Just peel it out and (assuming it attaches via velcro as most do) stick this in. Works better and longer for me even in 100deg+ than Halo & others mentioned.
Liked 2,452 Times
I wear wool socks year-round, but my body has a propensity to collect fungus. I got those fungus-y toenails, which were gross. I took the medicine to get rid of it, and you're only supposed to use it once per lifetime, and I've taken it twice. (Oops.) Now I'm extra cautious about fungus, so I change my socks more religiously than changing my underwear. So I have two rules about socks: (1) no cotton socks ever, and (2) change my wool or synthetic socks every day.
Bikes: 2018 Specialized AWOL, 2013 Surly Pacer, 2011 Raleigh One-Way, 1973 Raleigh Super Course, 2020 Surly Big Dummy
Quoted: 30 Post(s)
Liked 30 Times
I have a similar problem here. Not the temperature so much as the humidity which is typically in the 80% range. I have been using Walz Caps for a few years now, but I am sure there are other brands out there. The short bill on the front fits fine under the helmet and my body position on the bike allows the bill to drip in front of my eyes, although sometimes it gets on my sunglasses. As others have mentioned, caps do increase the temperature of the head, but a quick squirt from the water bottle will cool things off for a while. As a baldy, there isn't a lot of good options.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Edit: Just checked the Sweat GUTR website and it seems they have made nice enhancements to the product since I last used one. Seems like a no brainer for guys that overpower a Halo.
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
Summer has now finally started here. For the next weeks my evening commutes will be hot with temperatures around 100 plus high humidity. Meaning I will be sweating like crazy. I am using one of these halo sweat bands but even that gets drenched within minutes and I have salty sweat pouring down my face and into my eyes which burns.
What are the best ways to keep the sweat out of the eyes? Thx.
Another vote for GUTR
A friend turned me on to the GUTR. I use it for any length of bike ride where I am sweating a bunch including my daily commute.
I can relate. I don't sweat, I LEAK. Anyway, if a Halo isn't getting it than I'd try the Sweat Gutr. It's a silicone channel that you place just above the eyebrows. It flat works but is not the most comfortable. You do get used to it though. One other thing I recommend is removing the brow pad in your helmet because it just saturates and then drips in your eye's.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Another Buff
I'll wear a headband or bandana on even mild days with mild activity, because I'll have sweat in my eyes in 10 minutes. I use a uv+ buff in pirate cap mode under the helmet. The fibers are supposedly designed to wick perspiration throughout the garment, allowing better evaporation, and thereby better cooling.
I'm actually amazed that a single thickness poly knit is capable of succeeding where multiple layers of cotton fail on occasion, but that's the future. I'll use a merino buff on cooler or damp days. You can get decent deals on old stock from Buff and on Amazon whenever.
I use these and they are amazing. Also they help make up for worn padding in my helmet too. Get the thin 1" version.
https://www.amazon.com/Halo-Headband...qid=1565198803
I got two, because I can't cycle without it in the summer. I'll soak the pads in my helmet, but these drain the sweat to the back of my head.
Tried the cycling caps but they are too hot and they don't fit my head well. I need the ventilation.
Let's Ride!
Quoted: 327 Post(s)
Liked 37 Times
i was thinking the same. i would love to see some humidity in the 40-50's. I think that my sweat doesn't evaporate because the air is 80+ % humidity already.
Likes For jbucky1:
Quoted: 2599 Post(s)
Liked 1,924 Times
The answer to this thread's question is obvious right now: ride in the depths of winter and you're very unlikely to get sweat in your eyes.
Likes For pdlamb:
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
These work well for me. The have an antimicrobial yellow band in the front that stops the sweat cold.
Quoted: 4790 Post(s)
Liked 3,917 Times
In my racing days I solved the problem of salty sweat in my eyes by eliminating the salt (almost completely). I went on a very low salt diet specifically to sweat less sodium and fare better n hot, humid races. That worked very well, (It was also a major eyeopener. We Americans eat an incredible amount of salt. After I retrained my taste buds, everything that came in a package was way too salty.)
So, that summer, sweat in my eyes didn't sting.
I have an issue with the Halo caps. That sweat diverter ridge, Under my POC helmet, I get headaches from it. Took me quite a while to figure out it was that ridge doing it. I thought it was dehydration until I got the headache fully hydrated. Then I started noticing the same headache from the winter caps I've been wearing. The logo on the front. I now wear it backwards. (I;ll start wearing the Halo backwards as well. 'Till now it's been out of circulation.)
Ben
Ben
Quoted: 482 Post(s)
Liked 151 Times
The inside of t he halo I posted above has the same yellow sweat-stopping band. They should work similarly, though the cap has more material to absorb sweat. It is very cool and breathes though.
Likes For GeneO:
