Guerciotti BB Crack?
Quoted: 1104 Post(s)
Liked 1,824 Times
It looks like the BB area has been resprayed, as if a repair was done in the area???
Does the paint look like it's been blended in like around the BB and/or is there cracking in the paint in any other area of the frame?
If not then you may have an answer to your question about a crack.
Also, there is a smaller ding behind the dent in the DS chain stay. Dents like these are not normal and can come from a severely jammed chain???
verktyg
verktyg
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
verktyg
verktyg
All things that are fixable but all things that should have been disclosed before the sale.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,180 Times
It looks like there is "crazing" on all of the paint and might be a respray as evidenced by the chip that was painted over in the OP's 2nd pic...
The paint seems very thick as mentioned around the BB and could be Bondo or something like a body putty. Soap was suggested as a means to check for cracks, if it were mine I would use an Exacto Number 2 and do some exploration.
Even if you have to do a touch-up your peace of mind would be worth it.
Best, Ben
Best, Ben
Voltaire
Voltaire
Quoted: 331 Post(s)
Liked 332 Times
Standing Test
Put all your weight on one pedal and jump around a bit. The very best steel bikes swing flex a considerable amount under load (that's why they are more comfortable to ride) Any cracks in the BB shell will be obvious.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Rather than using the BB, crankarm, and pedal spindle to try to flex the BB shell, especially since you've pulled the BB out, just use a garden rake handle. The wood won't damage the threads and you'll be able to flex it in any direction you want.
Ideally, have a friend flex the BB shell, and use your finger to feel for any movement. Your finger is more sensitive to movement than your eyes can discern.
Dale, NL4T
Dale, NL4T
Quoted: 159 Post(s)
Liked 375 Times
In the BB area I can see some of the original paint under the new paint.
Could the entire bike have been cover sprayed with non compatible paint or clear coat???
That is what it looks like to me.
Would it be possible to chemically remove the new paint leaving the old?
The bike and the jersey are part of the original team kit from the North Georgia Wheelman team. There were 10 to 15 of these custom painted bikes ordered from TSD. I designed the jersey and picked the paint colors for the team. This was way way back before things were done by computer.
I know of two others that still exist. This is the first one I have seen for sale in many years.
I was particularly interested because I thought it was a Gainesville, FL team.
I agree that it looks like the PO sprayed the frame with a thick clear coat that yellowed and cracked with age.
Likes For delicious:
Quoted: 4510 Post(s)
Liked 6,377 Times
@nomadmax,
Hope this works out, that of course will be up to you. Challenges like this can always be a valuable learning experience, perceived or not. They widen your scope and expand your critical thinking which can be invaluable later when applied to other challenges.
Make it so.
Make it so.
Liked 1,824 Times
Thank you all for the suggestions and help. I just got back in from a bike ride where I mulled over my experience with the seller, the overall poor condition (not as described) and the undisclosed damage to the right chainstay. I've contacted the seller for a refund and will personally deliver it to him, possibly this weekend. Again, thanks for the help, this place is the greatest.
Likes For nomadmax:
Likes For Last ride 76:
Quoted: 964 Post(s)
Liked 1,451 Times
I think you've made the right decision. That frame looked like something I would commute on - a once-great machine, now unfit for public consumption due to damage!!
Quoted: 76 Post(s)
Liked 76 Times
the dents look like really bad backpedal chain suck. i saw something similar happen to a guy's bike years ago - he was wearing baggy pants and they got caught in the chain, he tried to back pedal out of it but the chain sucked down and got all jammed between the sprockets and chain stay. he ended up having to cut his pants out of the chain and put a pretty nasty dent in the chain stay, not unlike the one on this bike.
Likes For t_e_r_r_y:
Quoted: 18371 Post(s)
Liked 4,507 Times
I agree that sending it back intact is likely the best course of action.
I'd hate to be a seller, and have someone strip half the bike, then send it back as a mess.
On the other hand, I wouldn't sell a bike that I couldn't stand behind 100% (99.9%). So, the first step would be to strip the paint on the bottom bracket.
Come up with a reasonable value beforehand on what to do if one finds:
- Bottom Bracket Cracked
- Tubes Cracked
- Etc.
- NOTHING... Everything OK
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
Concur with everything above, though I'm not sure those dents are chain suck; would have expected them at the bottom if so. At any rate, it's a terrible repaint and the whole BB area just doesn't smell right.
Not something I'd touch without a price that'd make experimentation for the sake of fooling about with it feasible. You made the right decision.
-Kurt
-Kurt
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Chain Stay Dents
Most of the Guerciotti frames that we sold back in the 70's were 56cm to 60cm and they were made with Columbus SL tubing. The larger sizes were probably made with Columbus SP tubing.
Until about 1980, the Columbus SL chain stays had a wall thickness of 0.7mm. There were lots of frames made with those tubes that suffered cracks or breaks in the left - non drive side chain stays.
In 1980? Columbus increased the wall thickness of SL chain stays from 0.7mm to 0.8mm. Aelle chain stays were 0.9mm wall thickness.
A strong rider having the chain come off during a hard sprint or honking out of the saddle could have easily caused those dents when the chain jammed between the chain stay and the chain ring. Thin wall chain stays can dent easily.
@t_e_r_r_y either situation could have resulted in enough back pedaling to jam the chain.
I've had a chain bounce off and jam a number of times over 55 years of riding derailleur bikes. It shouldn't happen with a proper FD properly adjusted but it did.
I have a number of old frames with dents in the DS chain stays but they are in the center line of the tubes. It doesn't affect the ride or handling and the dents are hidden behind the chain rings.
Just one more thing.... DayGlo paint contains a high amount of pigment and requires a protective clear coat to last. It's usually been flat or low gloss. Back in the 60's a lot of US military aircraft were sprayed with DayGlo "International Orange" paint, especially for training and search and rescue uses.
High gloss clear coat could shrink a lot more when covering that high pigment content paint causing the cracking.
I have 2 frames that I built back in 1992 that I had Ed Litton spray for me using DayGlo paint with additional non fluorescent pigment. The top clear coat contained a small amount of pearlescent material.
They still look great but they're stored in a dark area to prevent fading.
verktyg
Chas. ;-)
Chas. ;-)
Quoted: 796 Post(s)
Liked 522 Times
I think you will sleep well at night OP good decision and thoughtful process to determine what the best course of action was, some old folks might call that wisdom
Liked 1,824 Times
@verktyg
Yes sir, the tubing is Columbus SL based on a couple of things I know about Guerciottis of this era. The BB shell on the Aelle tubed bikes have a couple of slots in the bottom as opposed to the star the SL and SLX bikes have. The fork steerer tube has rifling in it, the Aelle bikes do not. As always, you're a wealth of information (as are many others around here) and that's the reason I know anything around here
Edited to add:
Here's the irony. The seller had been contacted by a forum member here who actually did the design work on the team bikes. After the conversation, the seller believed his bike was made of Aelle tubing as is the other example in this thread. I found out that there were two versions of the bike, some in Aelle and others in SL. After seeing the SL sticker and asking what cut out was on the bottom of the BB (a star) I told the seller his bike was made of a better grade of tubing and adjusted the price to reflect it. Everyone wants a great deal but I don't want one so bad that I'll trade my integrity for it.
Edited to add:
aged to perfection
Quoted: 835 Post(s)
Liked 1,252 Times
I think this whole story is a learning experience about not getting overly swayed by a seller's hyperbole ("rare", "appraised value" etc) and doing your due diligence before buying. there are diamonds in the rough out there ! Somebody on CR just picked up a Raleigh pro for $150 bucks BUT it came from a thrift store and he had the chance to look at it.
On ebay you have a couple pictures and you have to evaluate not only the bike but also the efficacy of the seller! I have seen some ebay auctions where the seller is clearly hiding something. So it pays to do your homework and manage your risk. I sure wouldn't pay collector's money for a bike based on blurry cell phone pics, or that I had any questions about. As bike experts we learn, like people who trade horses or cars, what a good one (or a bad one) looks like, and make our decisions accordingly.
I'm glad the OP was able to get his money back. This was an interesting thread.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Likes For mpetry912:
Liked 1,824 Times
UPDATE
The seller and I conversed via email and he offered to refund the entire purchase price (not including shipping) and let me keep the bike. I told him that taking something for nothing is stealing in my book so I countered with the maximum amount I would have offered/paid had I driven down and seen the frame issues firsthand (meaning he adjusts down the amount he sends me). He really stepped up in my book and I give him credit for doing something many people don't want to do these days, the right thing. Apparently, he lives by the same code I do; my good name is worth more to me than ANY amount of money.
When the transaction is complete, I'll strip everything off the frame, take loads of photos for paint and decal placement, then take it up to Franklin Frame here in Ohio. I'll know more after he assesses it and gives me his determination. Suffice to say, this frame and fork will live to ride again, albeit with modern components as it will be in the regular riding rotation.
Quoted: 159 Post(s)
Liked 375 Times
That is awesome!
I am also emotionally invested in your Guerciotti. It is great that this situation has worked out for the best.
Please keep us posted on the progress.
Liked 6,377 Times
UPDATE
Liked 6,377 Times
Mark Petry
Mark Petry
If you are realistic, often hard to do, going in, then you can do ok, if not, well buyer (you) beware, mainly of yourself.
Likes For merziac:
