Broken derailleur
Quoted: 8275 Post(s)
Liked 9,031 Times
Broken derailleur
I have a Campagnolo Chorus 10 speed with 50/34 rings and the front derailleur cage is broken. Will other derailleurs work, as long as the cable pulls from the same direction?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Yes, Mostly
A replacement 10 speed Campy Chorus derailleur replacement runs from $16 used to $40 new on your favorite auction site, so a replacement won't break the bank.
Front derailleurs have fewer limits on them than rear derailleurs, and a road front works just as well in friction as with integrated shifters. Since the shifter is what controls the cable pull, just about any similar speed derailleur will work given the same chain width, but I'd go for a direct replacement.
How'd you break the cage?
Liked 9,031 Times
I'm not exactly the master of maintenance and I tend to let things go until they fall apart or fail. The bike has 35,000 miles from me and I bought it used.
I'll check out e-bay but I was wondering if something I have lying around might work.
The dropped
Liked 1,014 Times
Chain suck is a symptom of a worn drivetrain. You may need more than a new derailleur then. Worn chainrings, stretched chain, worn out rear derailleur springs can all contribute to chain suck. If your chainrings are worn and the teeth look like shark fins, chances are that your cassette cogs are also worn unless you've replaced them already.
It wouldn't be a bad idea to see what your friendly neighborhood bike shop mechanic has to say. You'd probably get a few opinions here if you can post pictures too.
Liked 9,031 Times
The chain and cassette have been replaced a few times and the rings once. You're right, it all probably needs to be freshened up. Maybe I'll just get a new bike instead. What's that retirement account for, anyway?
Thanks for your insight, btw.
Liked 9,031 Times
