Go Back  Bike Forums > Bike Forums > Training & Nutrition
Very basic intervals question
Training & Nutrition Learn how to develop a training schedule that's good for you. What should you eat and drink on your ride? Learn everything you need to know about training and nutrition here.
Old 09-29-10, 10:36 AM
sevrdhed
So, I'm not sure I'm yet ready to do intervals - only been on the bike for 1000 miles so far. But every time I read about them, there's always one question that pops into my mind:
Where the heck do you DO intervals at?
For those with power, I can't imagine the terrain matters that much, because you'll still be able to see your power regardless of whether you're goin uphill or downhill. But I dont have power and I certainly cant afford it anytime so, so I would simply be doing them based off of my RPE.
Because of that, I think terrain is going to matter quite a bit. So - given that I live in a very hilly location, where should I be doing intervals? Should I find the longest stretch of flattish road I can get? Or should I just go and throw myself at whatever monster hills are nearby?
sevrdhed is offline
Old 09-29-10, 11:02 AM
Pat
Bikes: litespeed, cannondale
Well, it depends on what you are trying to accomplish. I live in Central FL so I gotta go drive to find a decent hill.
I think with 1000 miles in your legs, you can do intervals. You warm up. You get yourself up to your top cruising speed and then you go pretty much as hard as you can. You can hold that for 1 minute up to three minutes. You back off, recover and repeat.
People also do hill intervals. Probably the best way to do those is to go and find a nice steep rather short hill and climb it until you are done.
If you do these things right, your legs will be cooked. So your next day's ride might be a recovery ride or a long slow distance (LSD).
Muscles can be very specific in function. If you do hill intervals, they probably will not help your flat ground power so much and vice versa. You might alternate them.
Also, if you are doing intervals intensely enough, you should probably only do them once per week.
Intervals are good for increasing your top end power.
Pat is offline
Old 09-29-10, 01:19 PM
Crack Monkey
Some people prefer to do structured intervals on the indoor trainer for this reason.
But, outside, you just have to do the best you can. You just have to find some road/trail/whatever that works well enough with the interval sets. It's pretty much impossible to find someplace to do a true 2x20 workout in the suburbs, but for most shorter intervals, I can get close enough.
Crack Monkey is offline
Old 09-29-10, 02:00 PM
DataJunkie
Liked 3 Times in 3 Posts
I have a road near my house that has 2 stop signs and is 9 miles one way. It works perfectly for around an hour of intervals.
For my LT tests and hard intervals in winter I use a trainer. Then go out and ride.
DataJunkie is offline
Old 09-29-10, 02:33 PM
sevrdhed
Thaaaats what I was afraid of. Makes sense though, doin 'em anywhere near my house would be rough.
sevrdhed is offline
Old 09-29-10, 02:50 PM
simonaway427
Bikes: 2010 S1, 2011 F75X
There's a 5 km triangle loop near my house. I sprint the long leg of the triangle then easy spin the other two legs for cool down. I do 5 laps of that and I'm spent.
simonaway427 is offline
Old 09-29-10, 03:05 PM
gregf83
Quoted: 1186 Post(s)
Liked 289 Times in 177 Posts
If you have hills with a reasonably steady grade then the simplest thing is to just go up the hill for whatever duration you're working on. If you want 5 min intervals, go up for 5 min turn around and repeat. This will also give you a close approximation to your power if you can measure how much you are climbing in a given interval. As you improve you'll go a little further up the hill in the alloted time period.
gregf83 is offline
Old 09-29-10, 03:33 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
I've got miles and miles of flat country roads a 20 minute ride from my house. On a calm day no problem, but if it's windy, especially if it's gusty, it screws up my HR.
caloso is offline
Old 09-29-10, 04:11 PM
AzTallRider
I need speed
AzTallRider's Avatar
Bikes: Giant Propel, Cervelo P2
Check out the workouts in this set of exercises (the BF workout list).
https://docs.google.com/Doc?docid=0A...bmprbmQ2&hl=en
Some of them will fit into your terrain just fine.
AzTallRider is offline
Old 10-04-10, 07:17 PM
malux
Bikes: 2008 Trek 2.1
+1 for varying it up. Do some intervals for speed and others for power. It'll help keep your body "surprised" and build up both aspects.
Pat, do you make it out to the west orange trail at all? I live out by Winter Garden
malux is offline
Old 10-06-10, 10:56 PM
tallmantim
tallmantim's Avatar
I have a velodrome and a "circular training track" (velodrome without proper banks) close to home - the second is on my way to/from work on the bike so is perfect.
What do you want to get out of your training? Or (as said above) are you looking at mixing it up.
To stress your aerobic capacity and fitness, VO2Max intervals are very good - requiring 3-6 minutes or so at the highest intensity you can. I have a power meter which makes it easier, but equates to sitting on approximate 40km/h while on the hoods for me if I didn't have one. If you are doing them right you should need to bail on the last one or unable to start after 5-6.
Shorter will affect your neuromuscular and anaerobic systems more.
tallmantim is offline
TimothyH
22
04-02-18 10:35 AM
cthenn
5
07-24-16 04:55 PM
knoxtnhorn
Road Cycling
30
01-03-15 07:47 AM
hhnngg1
Road Cycling
22
10-24-11 06:41 PM
BudFox
4
09-28-10 02:38 PM
