2019 Kona Sutra.
While Seeker's points above would generally be correct, I recently weighed my partner's 48cm 2017 Kona Sutra when we were packing it up to fly home from our last trip. IIRC it was 14.something kgs. I want to say 14.3, but I'm not totally sure of the exact number. It was not high 14, like 14.8 or something because it would've stuck in my head as 'almost 15.' That was with the rack and fenders, without bottle cages or other little add ons, maybe without pedals but I'm not totally sure on that one.
https://www.konaworld.com/sutra.cfm
FargoMort
Bikes: Salsa Fargo, Fuji Gran Fondo, Maverick Matic 70
Large person opinion
I am 64, 230lbs, 36.5 inseam, with shoulder/ neck issues when strung out to far and looking for a road touring bike. I also have bad hamstring flexibility. I currently ride a Salsa Fargo, Large with 700x38c tires on it. The Fargo is a great bike but rides entirely different with its true tires on it, 29x2.2, plus I got a Large vs XL due to liking a more upright feel, shorter top tube. Which was probably a bad decision. I also recently switched to Jones 2.5 hbars. And I have Ritchey riser stem at about 45 degrees. If I put even 2 lbs in my handlebar bag it gets wobbly. But I finally achieved my handlebars being even with my seat and no neck issues. I am looking to transform my Fargo back to its intended off road tires and purpose. Then I plan on getting one of the following. Sutra, Disc Trucker, Giramondo. After all that I cant find any in my size locally to even sit on. Looking to get XL or 58 60cm. Worried about hitting me heal on panniers on the Sutra or the DT putting to much pressure on my neck and shoulders if I dont make it look stupid like my Fargo fixes, a Giramondo post said the frame flexes and is wobbly. Any thoughts on this or things I havent considered for a Clydesdale rider like me???
They really went for a short stem on that new 2020. Looks like 50 or 60mm?
^ It looks more like 75-80mm to me. Regardless, some owners will certainly have to use a short stem with the 2020 Kona Sutra due to the long TT. Standover height is a bit high too; it's 2cm higher than Surly LHT/DT in sizes 54, 56 and 58 with essentially same size tires.
Size/ST 46 48.5 52 54 56 58
TT Length 527 540 553 569 585 603
Standover 745 765 785 810 830 850
Reviving this long dead thread to add the following about the Kona Sutra Rack;
I raised a warranty claim with Kona and was told that the lower rails are not for carrying panniers and so that is why they failed. You are only to use the top rail. I was amazed to be told this as the lower rail is perfect for placing my ortliebs and then strapping my tent onto the top rail.
So therefore there is nothing wrong with the welding, it is just the dumb users.
The lower rails on this rack design (an inferior copy of Tubus' Logo) are practically useless for anything but serving as a lower-center-of-gravity attachment point for panniers. If it were me, I'd definitely contest Kona's BS response to this warranty claim. Apparently Kona's rack is for looks / bike sales only, and not to be used for actually carrying bags in a loaded touring application. If this is Kona's official position on on their rack, then the Sutra webpage should include a disclaimer which states rack cannot actually be used in the usual manner, i.e. carrying loaded bags. I wonder what Kona thinks those lower rails are for?
Consider buying a Logo rack (if you like that design) from a seller with good return policy in case you can't fit it to your Sutra (but you probably can). Once you've fit it, take a picture and send it to Kona along with your denied warranty claim - maybe this will compel them to reimburse you for the expense of replacing their faulty product. BTW, a rack that breaks from simply carrying a pannier is a potential cycling safety hazard. Maybe you should share your experience with this organization:
https://www.cpsc.gov/recalls?combine=kona
Quoted: 3459 Post(s)
Liked 1,466 Times
Most anyone who's owned a Logo style rack attaches their bags to lower rails so that top rack top may be used for other gear, frequently a tent, which is often wet and needs sunlight to dry. It sounds like you used Kona's rack in the same manner as 9 out of 10 owners.
The lower rails on this rack design (an inferior copy of Tubus' Logo) are practically useless for anything but serving as a lower-center-of-gravity attachment point for panniers. If it were me, I'd definitely contest Kona's BS response to this warranty claim. ...
My Tubus Logo EVO was designed for that exact purpose, those lower rails do not serve any other purpose. See photo.
That said, check to see how much time you have on that warranty. I have heard that the warranty on the rack on the Trek 520 is a shorter time span than on the bike itself. They consider the rack an accessory and not a bike component, or some such argument. Kona might not warranty the rack to the same terms as the rest of the bike, check the fine print in the warranty.
