BB cable guides
Quoted: 45 Post(s)
Liked 44 Times
BB cable guides
I have a custon built frame with brazed on cable guides under the bottom bracket. At the time it seemed like a good idea, the builder certainly thought it was a step up from the basic moulded plastic cable guide.
As an Engineer, a steel cable running in plastic ((I assume it is nylon or similar) is a much better engineering solution than one running on steel. Add a paste of mashed paint and a bit of rust that will develop in the steel guides over time and they seem even less of a good idea.
Having said this I have had no problem with my custom frame, I just cannot see the point of brazed on steel cable guides under the bottom bracket.
Am I missing something?
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
If you are worried about rust there you can use a small piece of plastic cable tubing to protect the paint. Not sure why they didn't run the tubing on both cables here but think you will get the idea...
Quoted: 45 Post(s)
Liked 44 Times
That is what I did on my frame but the sleeves move over time and end up in the wrong place and doing nothing.
Also from experience - in my younger days when I still went out in the cold - the tube can get water in, freeze and hamper gear changing.
I haven't got a problem with this art all, just wondered.
Quoted: 4195 Post(s)
Liked 3,837 Times
AndrewRStewart
AndrewRStewart
When I add brazed-on cable guides, they're either brass or stainless. Carved up to allow for any water to drain out, rust has never been a problem.
