How thoroughly to wipe chain after lubing?
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
i know to wipe the sides of the chains but should I leave the rollers be and not wipe them or has lube gotten down instead where it needs to be and I can wipe as thoroughly as I want?
I wipe as much of the lube that's on the links and rollers as possible and do it once again after a few rides. The only place that must have lube on it is on the pins and inner links.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Wipe all surfaces you can easily get to with your rag. Wipe, then wipe, then wipe some more. Repeat after a few rides, then do it again after a few rides, then again and again, until you relube. The objective is to remove as much lube from the outside of the chain. The lube will remain where it counts and you will have a cleaner bike.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
The correct answer is: more wiping than you can be bothered with.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
The better you wipe down the exterior, the less it will gum up with goo, and the longer it will last.
Quoted: 5223 Post(s)
Liked 3,579 Times
regardless of lube time, if I have to use a screwdriver to scrape crud off my rear der rollers then I'm not wiping enough
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
Lube will collect grit and will act like sandpaper on the "parts" the chain comes in contact with.
Keep your chain clean.....
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Of all sorts. At one time years ago I had 30+ bottles of different lubes laying around. What I find works best for me is to use a really thick lube. Then I can go forever w/o having to relube. That approach works for me, anyway, and I'm happy with where I'm at.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I wipe the chain plates, on the curve of the big ring, full rotation of the chain a couple of times. I don't care what's left on the rollers; it's not important other than slinging off onto your legs or bike. By the time I've gotten the plates wiped, there's not enough left to matter.
Quoted: 151 Post(s)
Liked 42 Times
Thanks for all the replies. Sounds like more wiping is better.
Quoted: 800 Post(s)
Liked 512 Times
I wipe all parts of the chain. In fact it feels like I've wiped the chain too much. Which probably means I've done just enough.
Quoted: 4195 Post(s)
Liked 3,837 Times
To tangent somewhat- I feel that wiping off chains is also like washing your car. Looks better but doesn't do much for the internal workings. In fact some say that wiping off the chain will also push some of that outside grime into the chain.
I talk about this to customers and club members all the time. My point isn't to stop their cleaning of the outsides of their bikes. Quite the opposite. My goal is both a better understanding as to what outside cleaning does (or doesn't) do and that taking care of their bike/chain is more then superficial outside cleaning. I do say that the time spent getting close up to their bike's parts (during the outside cleaning) gives then the chance to both better understand the workings of their bike and to better see when those workings are changing/becoming a problem. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2599 Post(s)
Liked 1,924 Times
While it may be possible to push some grit into the chains while wiping it down, that's going to be hard. After all, the pins are press fit (and then riveted on modern chains).
But the point of wiping a chain, as I see it, is to get most of the exterior oil off. That oil standing on the outside of a chain will collect dirt, dust, and road grit. To the extent you can keep that from sitting on the outside of the chain, the chances of it working its way inside the chain (as the plates rotate going around a sprocket/cog/idler pulley and then straightening) are reduced.
My take on the question? Wipe it down until there's the thinnest film left as a rust preservative on the surface. It should be so thin that the gunk is too heavy for the oil to hold It there. After a re-lube, wipe side plates, wipe the rollers while forcing the chain to bend so you rotate the rollers. Then go for a ride or four, and repeat the wiping routine. Forget about it until the chain starts squeaking.
Liked 3,837 Times
Originally Posted by pdlamb;2064516[b
4]While it may be possible to push some grit into the chains while wiping it down, that's going to be hard. After all, the pins are press fit (and then riveted on modern chains[/b]).
AndrewRStewart
AndrewRStewart
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I wipe it once with a paper towel as I drop it into the pot of melted paraffin. A month later I do it again.
I tried an experiment with Muc-Off C3 Ceramic Dry lube a while back. I put some paper towels on the floor under the chain area and lived the chain as per normal. I then let it dry overnight. When I came to wipe off the excess the next day, before a ride, it was dry to the touch so there was really no excess. Any excess had already fallen onto the paper towels below the chain.
The entire process would take three days though and would only work with dry lube! One day to wash the drivetrain thoroughly, one to lube and the third to let the lube become touch dry.
If you use Chain-L, (which is a great product), wipe it and wipe it until you absolutely, positively, can't wipe it any more.
Then wipe it some more.
After a fresh lube job
wipe well, then one
last wipe down with a rag with solvent on it
(brake clean ...)
Helps keep it from collecting dust.
wipe well, then one
(brake clean ...)
I regularly wipe my chain off if it is dusty or dirty even if it does not need lube. If you stop the build up of crud it helps keep the rest of the drive train clean and recuses wear.
Quoted: 3352 Post(s)
Liked 1,056 Times
Lube with a good oil like Mobil 1 in the evening. Spin the chain backward for at least two minutes. Then before your ride the next day, wipe all parts of the chain, and every day before each ride.
