What are the most vulnerable parts on a gravel bike frame?
commu*ist spy
I'm getting some helicopter tape to cover the most vulnerable parts, but I don't really want to cover the whole thing. So far, I got the bottom side of the down tube, lateral sides of the top tube, and the rear/sides of the seat stays. Now I'm out of tape. I'm wondering where else I should apply it.
Non omnino gravis
commu*ist spy
I just want to protect the frame from rock strikes and such. Then I'll cover it with dirt and ****
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
Mine seems to take the most hits at the BB shell and chainstays. Limestone singletrack is about the worst offender. It can flip some pretty big stuff at your frame. Actual gravel and hardpack roads just send tiny stuff. Maybe eventually it would "sandblast" like a previous reply mentioned.
Between the powder coating and the 853 steel, I'm not too worried.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Frame protection on a well ridden gravel bike is a fantasy.
This was our ride Saturday...
-Tim-
-Tim-
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
The section of chainstay just behind the bottom bracket, facing the chainrings usually takes a beating from chain drops, especially when the chain gets wedged between the small chainring and chainstay. A lot of carbon bikes (e.g. my Niner RLT9 RDO) come with a metal plate stuck on this area for extra protection. I have at least three frames (including one steel) that are gouged up in that area.
For general chainstay protection, I use the MTB trick of wrapping it with a section of old inner tube. Sometimes you can't get close enough to the bottom bracket to guard against chain drops though. I've thought about getting a sheet of brass from a hobby store and using a combination of tin snips and a ball peen hammer to fabricate a protector plate.
commu*ist spy
3 frames sounds like an awful lot to be having paint chips in that area. is gravel biking more prone to chain drops, or was this a misadjusted limit screw issue? but I can see how that area would be pretty important to protect.
Expired Member
Quoted: 3674 Post(s)
Liked 5,435 Times
It's normal and not indicative of maladjustment. Unless you have one of the newer clutch rear derailleurs, the chain may/will whack the chainstay over rough terrain. You don't have to drop the chain to have chips. Lots of protection options.
vinuneuro
36
09-23-19 06:12 PM
Big Wally
26
02-03-18 10:04 AM
Inpd
13
08-31-16 01:12 PM
Sito
23
03-07-16 06:27 PM
