Needing to Upgrade my Road Helmet - GIRO
Quoted: 344 Post(s)
Liked 20 Times
I need to get a new GIRO road helmet so I would like to know what you suggest. I'm considering the Cinder MIPS so far. The reason I prefer Giro is they seem to fit the best that I have tried.
Cheers
Cheers
Quoted: 152 Post(s)
Liked 173 Times
I've been using a Syntax MIPS for a couple of months now and am happy with it. Nice looking helmet IMHO for a mid-priced bucket. Can't say how it performs in a crash luckily.
Giro Syntax MIPS
Giro Syntax MIPS
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Needed a new hat this year, so I went with the Synthe. Really happy with it so far. Just remember helmets are cheaper than heads.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I like my Synthe. FYI you can frequently find NOS lids on Amazon etc. I paid half retail for my Synthe.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
The safest helmets are generally never the lowest weight and therefore most expensive helmets. go figure.
Non omnino gravis
Quoted: 800 Post(s)
Liked 512 Times
I was looking for Synthe when I was going my helmet shopping. I had a hell of a time finding one because I'd been told the helmet had been discontinued and replaced by (I forget the name). If that is the case, you may be able to find a Synthe on closeout price.
Quoted: 10 Post(s)
Used to have an Aeon, it was light...I say was, because when I crashed 3yrs ago 37mph coasting over the finish line at a sprint finish/race...somebody hit my handlebars...and down goes Frazier...bad wreck, bonked head, broke helmet...only flashed KO'd but came right to tumbling still.
So, the helmet saved my head, and it is one of the lightest helmets on the market at the time, probably still is. Another type of helmet blow, well, who knows how it fairs, but it did it's job.
Any weight on this helmet the Syntax Mips? Can't find it doing a quick google search or on their website. Same with the other higher level lines of this helmet?
I'm currently using a Bontrager road/aero type that has less vents...supposed to be the most aero at the time I bought it 2.5yrs ago...but it sits way low on my forehead/hitting glass arms as well...the Giro never did this, or obstruct my view. I'm always having to push up on my glasses in the middle and move the helmet back upwards...not sure why I haven't bought another helmet by now...but looking to move back to the Giro line, loved the fit/weight and protection overall of any helmet I've had.
Bikes: '86 Centurion Elite RS '17 Trek Domane SLR6 Disc '16 Trek Boone 5 '15 Trek Fuel EX 9 '20 Trek Checkpoint SL6
Quoted: 25 Post(s)
Synthe, but I've had two and both had their retaining bands break (at the back, near the adjuster). They still work and fit firmly on my head, but they don't adjust quite right anymore. Too bad because it's an expensive helmet. And it's hard/impossible to retrofit a replacement band.
Quoted: 551 Post(s)
Liked 277 Times
Likes For tagaproject6:
Quoted: 1851 Post(s)
Liked 678 Times
I've run the Havoc, Atmos, Aeon, Ionos and Synthe. There are subtle differences in how Giros fit, but not so great as to make one not good. I did not like the Synthe MIPS - the system created bumps in the cage that sat funny on my head and hurt. The regular Synthe fit much better - til I broke the cage.
I'm running a Kask Mojito now. It is super comfortable, though the chin strap is a bit short.
Anyway, they all meet the same standards for protection. Pick the one that fits your budget and color scheme and you will be fine.
Quoted: 4559 Post(s)
Liked 2,802 Times
I really like Bell's attention to detail in my Formula MIPS, so I'd planned to get a Z20. Lots of little things, like the full coverage of protective plastic over the EPS foam on the underside of the lid. Well designed harness, foam pads, etc. Holds up well over time and repeated cleanings.
But I saw an ad for a small discount on the newish POC Omne Air Spin so I ordered one.
Holy a/c, that thing really scoops in the air flow.
But POC is a quirky helmet and I wouldn't recommend one unless you can test it in a store (they're difficult to find locally), or the seller has a generous return/exchange policy.
But check out the Ventral and Octal, if you don't mind goony looking lids.
With the Omne, the portion of the strap that goes from the helmet to the "Y" splitter that hangs below the ear is non-adjustable. I suppose they wanted to eliminate the risk of people adjusting the strap inappropriately -- which I tend to do. Last time I washed the strap on my Bell I moved the Y piece down to the end and forgot to reset it. Can't do that with the POC. Only the short segment of strap that goes under the chin is adjustable. I've seen photos of people wearing POC helmet sizes too small for their noggins, and their ear lobes are pushed out by the non-adjustable strap. I got a large since my 59cm noggin is borderline large. Fits fine.
The Omne is really more of an all purpose helmet, more like a hipster commuter/skater helmet but with good ventilation rather than a bowling ball with three tiny holes. The other POCs would be better road helmets, but pricey.
The Omne is $150 and still pricey for what you get. If I didn't know it was a POC I'd have guesstimated an appropriate price at $50-$75. It's main attributes are much thicker EPS (and a little heavier, natch) and outstanding ventilation. I dunno if their SPIN alternative to MIPS matters.
The graphics are splashy and look like ads. The brochure humble-brags that the paint will fade because they avoid hazardous chemicals. Somehow that's supposed to be a virtue. I'm not sure POC sells enough helmets that a tiny amount of sun resistant paint would contribute to global harming. But oh-kay, I bought it anyway.
I'm gonna make the Omne my casual group ride and errand/commuter helmet, so I'll always have one helmet set up to hold a video camera and lights, etc.
Advocatus Diaboli
Liked 1,531 Times
Likes For Sy Reene:
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
A few years ago I bought a Synth MIPS. 3 weeks later I crashed and cracked it. Went back to the LBS and they contacted Giro about a crash replacement. Giro gave me 30% off and the LBS gave me another 20%.
On Your Left
Liked 2,433 Times
Quoted: 822 Post(s)
Liked 1,955 Times
I have been wearing this Giro Register for the past six months to replace my crushed Lazer.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For $50 it is a MIPS and fits my fat head well. No complaints. Have not crashed tested it by bouncing off concrete like the last one.
On Your Left
Liked 2,433 Times
Crashing is part of cycling. If you think you'll never crash then you're a fool.
BTW... i'm a healthy weight and happily married for 36 years.
Quoted: 4717 Post(s)
Liked 1,882 Times
Crashing is a fact of cycling. I'd share some photo's, but the Mods frown on the truth being shown.
On Your Left
Liked 2,433 Times
Hey, we all made decisions and have to "live" with them.
