Cup and cone versus cartridge BB
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I've heard lots of people make that complaint as well as complaining about Shimano Octalink and ISIS bottom brackets (not those guys but the International Spline Interface Standard). I've never had a problem with any cartridge bearing bottom bracket and seldom see a bad one at my local co-op. I see roughly 1500 bikes a year with all kinds of problems.
Bad bartridge bearing bottom brackets show up only a few times per year. They are so rare, in fact, that it's something to take note of.
I've had no end of wear issues with bottom brackets back before cartridge bearing bottom brackets. In the early days of mountain biking, I had to replace the bottom bracket very often and had to rebuild on a roughly 6 month schedule. Modern bikes...new ones from HelMart...that have loose bearing bottom brackets are a total waste of time and effort. The bearings wear to dust in about 200 miles. I see hemispherical bearings in those on a regular basis. The "steel" (SLO? steel like object) that is used for the cups is often so poorly constructed that the cup pulls apart as it's being extracted. I've had to tell several people that their bike is irreparable because the bottom bracket has started to separate and we can't get the cup out of the frame.
Nope. Got no love for loose bearing bottom brackets.
Though still have 1974 Shimano (Dura Ace?) with french threading - still looking good. Road bike though - not much mud (plenty of dust though).
This is Rivendell Bikes Grant Peterson's opinion:
"This style was and is still the simplest, strongest, most crap-and-bad adjustment tolerant style of bottom brackets. They’ll go on and on even bone dry, because the big ball bearings and the interface are a match made in heaven."... "This style of bottom bracket keeps working even when it’s been ravaged by cheapness, time, poor adjustment, and neglect. "... "Sealed cartridge bearing bottom brackets aren’t nearly as tolerant. The balls in the “sealed cartridge” are smaller than the balls in a cup-and-cone bottom bracket, and the weak part is the cartridge that holds them. If that breaks, the balls escape and go who knows where, but they don’t stay where they need to be between the cup and the cone race. I’ve seen this happen many times, even on super expensive bottom brackets. I’ve seen those bottom brackets fail in less than a year, even though they’re sold as lifetime bottom brackets."... "If I had to pick one bottom bracket for one bike for the rest of my life, it would be a high-quality cup and cone bottom bracket, for sure. "It took a couple of years for bicycle parts distributor Jim Porter (of Merry Sales) to persuade Tange to remake them. It took a couple more to get all the details right. We may be the only bicycle people in the country who is happy to see these back. They are beautiful bicycle parts, made without compromise or concession to trends, and it is unbelievable that we even have them, and doubtful that they’ll continue to be available (unless these become NOS in 10 years)."
https://www.rivbike.com/collections/...6klsej-lkangkn
Note: I am not taking any sides on this issue : )
Mostly harmless ™
Liked 216 Times
If it weren't the case, I'd consider cup and cone, but from my experience, Shimano cartridge ones are a "no brainer" - dirt cheap, maintenance free and very durable.
Hollowtech II ones, where bearing balls are larger, but placed on the outside, don't last nearly as long - start creaking from dirt relatively quickly and wear out a lot faster than square taper ones.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
My limited observations
Cup & cone - yeah, I've had some that are junk. My 1968 Sprite is original that I greased and replaced balls in 5? years ago. Was it ever serviced before then? Who knows. Still fine
I've had plenty of bikes with cup & cone that got minimal service and were fine
Cartridge - One bike that I have that came with one failed after 2K? 3K? but it was a cheap chin-haur. UN 55 in there has thousands on it. Redid an old DB hybrid with a cartridge for a guy that used it for his winter beater. The bearings were literally gone - I pulled the spindle without removing the cups.
External bearing - My main road commuter has probably 20K miles on a 105 HTII BB and 6603 Ultegra crank. Still fine. Maybe it creaks, between wind noise and hearing loss I don't hear it, but it spins smooth.
In general when I'm rehabbing a vintage bike for someone or flip, if the C & C is suspect in any way I'll drop in a UN55. Cheap and I'd be shocked if the new owner would ever service the C & C
Any BB will give you good long service or will fail prematurely. Rider, riding conditions, service (or not) will all be different for every bike.
Thanks everyone. I've got 30 miles on it since redoing it and it seems to be doing well. Also noticed more noises afterwards, needed to regrease the sleeve bearing in the rear derailleur jockey wheels. I finally have smooth silence!
I've basically got a small fleet of cheap beater bikes that I'm learning to wrench on. One of them came stock with a sealed cartridge and the sheer end user laziness aspect of it really appealed to me. ;-) If the cup and cone gets rough again on this one I'll probably hang onto the parts and swap in a cartridge just for giggles and comparison. Might even get crazy and swap out the crankset completely, just for fun...
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
...and I have replaced (or in the case pf Phil Wood BB's, sent off for rebuild) any number of them due to failure/roughness in the spin. This includes (but is not limited to) at least one of the old Mavic units that was installed with a special chamfering tool, and numerous Shimano units that were apparently the victims of poor quality control, because they failed early in their service life. I know it's difficult to believe stories you hear on the internet, versus your own studied opinion based on personal experience, but I'm not making this up.
That said, of the remaining 31 or 32 bikes, there has not been a single failure of cartridge bearings no matter what duty I've put the bike to. Some even have mid90s ISIS bottom brackets which were supposed to be the worst of the worst. One of them has about 10,000 miles of trouble free loaded touring on it. Another one is doing duty on one of my current mountain bikes.
I certainly use sealed units. They're nice because they simplify swapping out crank spindles....all you need to worry about is length, spindle taper, and threading in selecting the new one. I love them for that reason alone. But you're wrong on the average user's requirements in terms of service intervals on an older cup and cone unit, and you have some mistaken notions about the range of quality available and failure rates in sealed units. (Based on my own experience...which is not insignificant.)
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Quoted: 26381 Post(s)
Liked 10,357 Times
...*sigh*.
Mostly harmless ™
Liked 216 Times
It's been a while since I've had a loose bearing bottom bracket but the recommended interval back in the day was about 6 months. It's similar to the recommended interval for loose bearing hubs and headsets. Of course they can go longer but you risk damage to the bearing surfaces.
Once a year service has worked fine for me - though I ride whole year long.
Not too much off-road, but lots of water, road dirt spraying, dust...
Perhaps it depends on riding conditions, but in my experience, once a year is quite fine, 6 months being probably an overkill (though it surely depends on the mileage and riding conditions).
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
The problem with rebiuldable and adjustable BB's is that they have to be rebuilt and adjusted.
Shimano sealed cartridge bb's last so frigging long it makes almost no sense to run a loose ball bb unless you're doing a resto or for really specialty applications.
Liked 4,201 Times
I know, right? I have a box of spindles and loose bearing bottom brackets and a box of cartridge bearing BBs at my co-op. I can go and pick a spindle at random and it will likely be pitted...some worse than others. I can go and pick a cartridge bearing BB at random and it will be just fine.
Stuart Black
Stuart Black
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Likes For Cyclist0108:
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
Friendship is Magic
Bikes: old ones
Liked 10,357 Times
If you don't mind occasional maintenance then keep it. The one I had I screwed up because the bike books didn't tell me about bearing preload. https://www.sheldonbrown.com/brandt/bb-adjust.html
I replaced that one with a shimano sq. taper cartridge. I bought into the Phil hype and used two of theirs. The bearings needed replacement too often so I went back to shimano. The two I have, have over 20k miles on them.
Liked 4,201 Times
That said, my point is that very few of the cartridge bottom brackets that get salvaged in my co-op are bad. The same cannot be said of the loose bearing bottom brackets. And it's not because we get fewer of the former and more of the latter or that people are more prone to throwing out cartridge BB.
Stuart Black
Stuart Black
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
This discussion reminds me of a conversation I had with a more experienced co-worker at my first job, in a bike shop, in ~1991 or so. The fellow had a Trek 8700 (carbon tubes bonded to alu lugs) mountain bike and it was constantly out of service for one issue or another. This one time he was having a problem getting some part (I think) for his Bullseye hubs, and I asked why he didn't just get a Shimano hub. He went on and on about the drawbacks of Freehubs compared to Freewheels... I don't remember what any of his points were, but I know now that, while he had every right to prefer whatever design he wished, he was way off the mark. Perhaps he was technically correct about the things that were superior with freewheels, but the modern design is better on the road, if not on paper.
Hello
The low cost and easily self maintained traditional bottom bracket, seems a natural choice for the bicyclist who is self reliant and seems to prefer inexpensive solutions to there needs.
Bikes: 1975 Raleigh Sports, Cycles Toussaint Velo Routier, Yuba Mundo, Raleigh Sports (1970)
Quoted: 34 Post(s)
Liked 10 Times
The cup and cone BB on my 1990 Schwinn road bike started knocking a bit and when I overhauled it the spindle was pitted. I got a replacement spindle from the community bike workshop for like $4, but finding one with identical length and taper type that wasn't also pitted was a tedious and rather filthy chore. And adjusting the BB was a little tedious as well (although I'm sure it gets easier the more often you do it).
Building up my new road bike and installing the cartridge BB was like: "That's it?? It just... screws in??"
I've been riding my roadster every day year round (including in heavy snow) for 8 years and the cartridge BB has never given me any problems. My only concern is that rust on the BB shell might make removing it difficult when that time does come!
Liked 4,201 Times
Not buying it. A "natural choice" for the self reliant cyclist is the bottom bracket that requires the least amount of effort. Loose bearing bottom brackets don't fit that bill. They do need rebuilt relatively often and they aren't all that "low cost". A new spindle costs about $7. A new cartridge bearing bottom bracket costs as little as $10. If loose bearing bottom bracket is cheap, it won't have seals which necessitate more frequent rebuilding and replacement of spindles. And the constant removal for maintenance risks damage to other parts which may also need periodic replacement. Hook spanners are hard on lock rings.
Stuart Black
Stuart Black
Shouldn't we express maintenance intervals in distance units (or even better revolutions)?
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I really enjoy a good quality loose cup and ball bottom bracket bearing set. But for ease of installation, the cartridge bearing wins. Loose requires more work.
The last two loose cup and ball BBs I've installed were on refurbishments. One on a Motobecane Grand Jubile, the other on a Fuji America. In each case, the final adjustment required me to re-do my work several times to get the right amount of pre-load/tension to eliminate play in the spindle without binding the cranks.
Especially since the action of tightening the lockring drives any slop in the adjustable cone outward as the ring presses on the side of the bb shell. I also find that there may be some "settling in" of the spindle and bearings after the first few hundred revolutions, because I wind up re-tightening after the shakedown rides. It's frustrating, but also pleasing once everything is finally right. Anyway, I ride all types: external bearing, cartridge, and loose. Each has its advantages.
Quoted: 7342 Post(s)
Liked 2,443 Times
Any unit you use is flawed. Perhaps hours of use would be best, but it's hard to keep track of.
Occam's Rotor
Liked 2,331 Times
I just got fed up with my White Industries square taper bottom bracket, and ordered an $18 Shimano external BB and a GRX 46/30T crankset to stick in it. Five years from now, if I am still alive, when the $18 external BB needs replacing, I will get another $18 one, and look lovingly at my $120 boutique high-maintenance square taper noise-maker/torture device sitting in the spare parts bin.
Occam's Rotor
Liked 2,331 Times
