Choice of a Fork??
Choice of a Fork??
OK i have it down to 3 forks the first one is the Manitou Axcel Super, the second is the Manitou stance static and the last one is the Marzocchi Gran Fondo 2. I have an STP3 (which is a freeride bike) and i usually do alot of "freeriding" (more jumping then any thing). I have about 250 to spend so if u have any other suggestions let me know thanks.
Bikes: Trek Jack...trials bike soon.
Those forks suck. You can get FAR better forks for 250. What currency are we dealing with here?
Bikes: Intense SS, Old spesh P series, ski/snow bike, fixie conversion
wait what!!!!!!!!!! Marzocchi Gran Fondo 2 hahahahahah
Like I said in your other post get a fork out of the marzocchi dj line!!
And I do not suggest jason's suggestion either, its a great fork but 150mm travel is to much for a stp. Don't get anything more than 120mm.
The Stp feels gay with anything less than 130. The bottom bracket is too low to the ground with my brother's Stp's current fork (100mm of travel), and his feet and cranks hit the ground a lot. I've seen many people put 150 mm travel forks on the STP and it works amazingly.
In fact, I believe there's a guy in NWD 6 that has an STP with a 6 inch fork.
Long haired freak.
Bikes: 2011 SE Old Man Flyer.
Because Jason knows his stuff alot of the times?
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
You likely saw lenosky. He was riding a pike which is around 5.4in travel. It looks like he is also using the uturn to drop the length of travel for appropriate riding. Considering he designed the frame it would likely be fine with a 100mm.
Not everyone hates law bottom brackets. In fact some people prefer them. As long as you have decent timing you get better at not hitting them.
Originally Posted by Maelstrom
Not everyone hates low bottom brackets. In fact some people prefer them. As long as you have decent timing you get better at not hitting them.
Lenosky probably has shorter cranks on his STP though.
Wood Licker
Quoted: 23 Post(s)
Probably...
and you might find as you become a better trials rider your geometry requirements for a bike will change. This happens in dh. As you get faster you want more travel and a slack HA. As you get better in trials you might want a shorter bike (MUCH) with a steeper HA. The bike was made for lenosky's trials which is a mix of street and the hop hop.
Linky
Shorter as in squat...not length.
The STP is made differently in every country. I think that Australia has the best STP line, and they have their STP's with 140 mm of travel.
https://www.giant-bicycles.com/au/030...sp?model=10070
