Dinotte Tail Light Alternative
#201
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
There is this new tailight thing that I've never seen before but the concept sounds interesting though. Two problems that I thought of right away was that the tailight itself was not bright at all, and how long would the batteries last?
See: https://news.cnet.com/8301-17938_105-...?tag=mncol;txt
#202
Randomhead
Liked 3,699 Times
#203
That was my first thought too, but then my mind began to think about some cars I've seen that use UV light to cast a light beam onto the road the length of the car, at night you see this pretty good. Same with red laser pointer light, at night you can see it a long ways off. So I'm thinking if you can see a uv light pretty good would a laser with more pronounced lines show up better and would the green be more pronounced then the red in a pointer? I can't answer that because I've never see the effect that BikeLane is doing at night.
#204
Bikes: Planet X Kaffenback, Homebuild eBike, 26" folding MTB & tadpole tricycle
DX have just added a red XP LED drop-in module that fits the SKU 20333 torch
So $9.90 for the torch plus $8.34 for the 5-mode 90 lumen red module and you get Hi 90-Lumen, Mid 60-Lumen, Lo 20-Lumen, Fast Strobe 80-Lumen and SOS 80-Lumen plus the original module as a spare.
$18.24 (plus an 18650 cell that most people already have) seems pretty good value to me.
#205
Thread Killer
Bikes: Fuji Touring Xtracycle, Merlin Road, Bacchetta Giro 26 (Sold), Challenge Hurricane, Cruzbike Sofrider
#206
#207
I saw a Dinotte tail light the other day, and its brightness is in a whole other league that the Planetbike. But the Planetbike one will probably be sufficient for most people's uses. Mine has lasted me over a year on the same batteries. Highly recommended.
#208
Ths Hipstr Kills Masheenz
Bikes: tirove
yeah i saw a recumbant with a dinotte. it was ungodly bright.
probably about the same with the ultrafire... i'll probably try the ultrafire. i work at a hardware store so i'll probably be able to make a mounting solution that is better than the dx ones. not happy with my universal holder i got with the p7. probably.
#209
Bikes: Giant CRX
#210
#211
The operation of mode switching is pretty standard. If you switch it off then on quickly it swaps to the next mode. Some have a switch that breaks connection with a soft press which is more convenient, but it isn't essential. Actually in some ways they can be less desirable as they can switch modes when jolted if the button is part pressed by the silicon cap. I had a torch that did this, but removing part of the silicon cap centre pip cured it
#212
rain-forest commuter
Bikes: 2008 Kona Dr. Dew, 2002 Kona MokoMoko, 1994 Cadex, 1990 Breezer Thunder
what about this from DX?
https://www.dealextreme.com/details.dx/sku.20333
#213
Bikes: Giant CRX
Nice - but not a flasher
https://www.dealextreme.com/details.dx/sku.14450
#214
Not a flasher. I'd prefer the module referred to a couple of posts earlier matched with a 'zoom' torch like this one --
#216
Red lights.....no siren!
Me too.............I use a Blackburn 4.0 right under the 140 Dinotte. I put both on flash. The flash rates for both units are such that the Blackburn gives around four or five respectable flashes, then the Dinotte fills in with one super burst. I find it very effective for daytime riding. At night I simply point the 140 down a bit.
#217
https://vetta.com/product_show.asp?ptype=whole&id=60
I have this and find it to be extremely bright and cost-effective. Only the Dinotte is brighter. 4 not 2 batteries and AA's not AAA's and 20 LED's is a lot of light. The slow flash rate gets some criticism but I like it.
#218
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
FYI, here's a video that I took showing a Planet Bike SuperFlash and a Dinotte 140L on the back, and a MagicShine light up front. Note that by the time I turn around, probably 200 feet down the road, you really can't see the PBSF anymore because it's totally swamped by the Dinotte.
Also, note that the Dinotte that takes AA rechargables is often on sale for $100 or so if you supply your own batteries. It's $120 normally.
https://www.youtube.com/watch?v=YI52d5bGKHQ
Work: the 8 hours that separates bike rides.
#220
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
The Planet Bike Super Flash is a Very Good Night Tail Light.
Five bikes in this Video have PBSF, but you do need to keep fresh batteries in them:
Fred "The Real Fred"
#221
Some of my group rides trikes and I reccomended that they get the Dinotte for daytime visibility. On the "strobe" setting it is eyecatching and bright enough to stand out in broad daylight. It is also still bright when viewed at an angle where the Planet Bike loses effectiveness.
I don't see a need for one that is twice as bright.
#222
Bikes: tirove
my k2 red WF501B's just came in and they're silly bright. i'll figure out a mounting solution and post results.
#223
Bikes: 1975 schwinn 21 speed chest unit 1973 21 speed schwinn varsity campus green 1975 schwinn varsity chestnut !975 Schwinn varsity cestnut
Quoted: 23 Post(s)
Ok I have two bell blinking red leds tail lights on my bike and thought they were good
There is no way that I can afore the Dinotte lights I have seen videos on super flash and thought
That they were very bright Looking at the niterider cherry bomb and for what I have read that is very good also but at a lot less price SO do I stick with the bell lamps, go with super flash, or the cherry bomb
The super flash and cherry bomb can be had for about 25 bucks the dinotte light is over 140 bucks and there is no way I can swing it I just got the Magic shine so I am taped out for now. On a fixed income SUCKS
#224
Bike ≠ Car ≠ Ped.
Whichever one you get, mount it on the bike and aim it level to the rear so that it doesn't point at the sky or the ground. You could afford to point it a little to the side to hit drivers better, but don't go so far that you lose rearward visibility; use a wall when aiming to make sure that you still get plenty of light directly along the bike's centerline.
#225
