WTB Hidden Brake Adapter for Track Fork
Old 10-17-19, 03:13 PM
Mr_Asifi
Mr_Asifi's Avatar
Bikes: 1983 Peugeot PSV10
Quoted: 30 Post(s)
Liked 12 Times in 8 Posts
Before I order one from Japan, wanted to try here first. Will be using it for my Raleigh Track bike. I’m not as good as I used to be stopping myself so definitely need brakes.
Thanks,
Asifi
Mr_Asifi is offline
Likes For Mr_Asifi:
Old 10-17-19, 04:43 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1130 Post(s)
Liked 112 Times in 95 Posts
The online example shows a sculpted fork crown that likely gives the adapter enough clearance. I'd want some exact measurements, especially with the diameter of the quill that inserts into the steering column.
I think I'd rather sub in a road fork painted in Raleigh livery. Maybe less expensive by the looks of that piece?
clubman is offline
Old 10-17-19, 08:16 PM
Last ride 76
Last ride 76's Avatar
Quoted: 270 Post(s)
Liked 99 Times in 80 Posts
Thanks,
Asifi
I've not seen a solution like that before... pretty neat.
Here's hoping you can make it work. Be great to keep bike unchanged. Let us know what you do...
Cheers, Eric
Last ride 76 is offline
Likes For Last ride 76:
Old 10-17-19, 08:41 PM
noglider
noglider's Avatar
Quoted: 5867 Post(s)
Liked 365 Times in 259 Posts
That's really clever. I have a Raleigh track bike just like yours but smaller. As I received it, my fork was already drilled for a brake, and that's good for me. Are you trying to avoid that?
noglider is offline
Old 10-17-19, 10:36 PM
Last ride 76
Quoted: 270 Post(s)
My Witcomb came drilled as well, but I don't know that I would take a drill to it, if it wasn't. The purest of the pure, and all that. Though it was a very common mod BITD, since many of us had no reasonable access to tracks.
Old 10-18-19, 01:14 AM
Mr_Asifi
Mr_Asifi's Avatar
Quoted: 30 Post(s)
Yes, trying to avoid drilling. I was open to drilling the fork before I saw the couple of alternate solutions. I found this option in the forums actually and someone mentioned there is room for up to 25c tires but it will be cutting it very close.
Mr_Asifi is offline
Likes For Mr_Asifi:
Old 10-20-19, 04:18 AM
Senrab62
Quoted: 65 Post(s)
Liked 10 Times in 9 Posts
I am not able to help with your inquiry, but can you please link that Japanese solution you found please?
Good luck!
Senrab62 is offline
Old 10-20-19, 06:19 AM
PilotFishBob
My brain hurts!
PilotFishBob's Avatar
Bikes: A few. Define "few".
Quoted: 313 Post(s)
Liked 64 Times in 44 Posts
Interesting. I've never seen that though I did run across this awhile back - no track bikes in my inventory so it was just a curiosity. Not as elegant as what you posted and pricey, but no tire clearance issues - you probably have seen this... https://www.ebay.com/itm/Dia-Compe-K...-/302047062655
PilotFishBob is offline
Old 10-20-19, 10:07 AM
Mr_Asifi
Mr_Asifi's Avatar
Quoted: 30 Post(s)
Good luck!
Link
https://alexscycle.com/products/801-...for-700c-fd700
Mr_Asifi is offline
Old 10-20-19, 10:47 AM
jeirvine
jeirvine's Avatar
Bikes: '72 Moto Grand Record, '72 Gitane tandem, '72 Raleigh Super Course, '73 Raleigh Gran Sport, '73 and '76 Colnagos Super, '76 Fiorelli Coppi, '78 Raleigh SBDU Team Pro, '78 Trek 930, '81 Holdsworth Special 650B, '86 Masi GC, '87 Panasonic DX5000
Quoted: 495 Post(s)
Cool bike, and a cool adapter. Keep us posted as you proceed.
jeirvine is offline
Old 10-21-19, 06:27 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1612 Post(s)
Liked 56 Times in 47 Posts
I wonder if one could 3-D print that doodad.
I put new leather on ruined saddles like Brooks, etc. You can reach me by private message.
rhm is offline
Old 10-21-19, 02:21 PM
delicious
dork
delicious's Avatar
Quoted: 49 Post(s)
Liked 4 Times in 3 Posts
Thanks for the link! I've been looking for this adapter for years.
delicious is offline
Old 10-24-19, 12:33 PM
billytwosheds
billytwosheds's Avatar
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone
Quoted: 161 Post(s)
After lots of research I ended up using this one, with the correct clamp shape for the blades of my fork.
It does flex quite a bit, and doesn't serve as a true front brake. At best it's a brake for trailing, not sure how it would hold up if one were to grab a fistful of brake in an emergency.
The insert-style caliper mount does look super clean, but I have the same reservations as others about fitment/clearance.
billytwosheds is offline
Old 11-04-19, 06:07 PM
Mr_Asifi
Mr_Asifi's Avatar
Quoted: 30 Post(s)
An update for those who were interested. The adapter ended up working out for me. I used a rear brake and a steel spacer (don’t recall the exact name for it or measurements) from Dale’s Hardware. The tires are 25c.
Plenty of stopping power and no play.
Mr_Asifi is offline
Old 11-05-19, 05:46 AM
Trakhak
Quoted: 415 Post(s)
Liked 45 Times in 34 Posts
Looks great, but please reinstall the brake pads with the open end of the holder facing backward. You don't want the pads launching themselves out of the holders in a panic stop.
Trakhak is offline
Old 11-05-19, 08:50 AM
jeirvine
jeirvine's Avatar
Quoted: 495 Post(s)
That there is a cool gadget, and a very fine bike. I would ditch the spacer and cut down the bolt, but if it works fine, then it would just be for aesthetics.
jeirvine is offline
Old 11-05-19, 10:19 AM
Last ride 76
Quoted: 270 Post(s)
Yeah, flip them around... But ever try to get a pad out of those record shoes? Even bitd?
The bike looks awesome. Congrats.
Old 11-07-19, 12:48 PM
CroMo Mike
CroMo Mike's Avatar
Bikes: Listed in my signature.
Quoted: 102 Post(s)
Liked 4 Times in 4 Posts
No need to remove the pads, just swap the pad holders and all, right-for-left.
My C&V Bikes:
1972 Bottecchia Professional, 1987 Bottecchia Team C-Record, 1982 Colnago Super,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron Super Record
CroMo Mike is offline
Old 11-07-19, 01:06 PM
noglider
noglider's Avatar
No one said to remove them. He was saying that the difficulty of removing indicates that the danger isn't as bad as it appears. I might not agree with that, but it's a point. Removing the pads from their holders does nothing to reduce the problem, though, which is why no one suggested it.
noglider is offline
