Batteries in the cold
#51
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Back in my RC car racing days we used to charge batteries in a cooler because the charger would take longer and report a larger charge. But in reality it just took more because the battery wasn’t working as well. Then we’d go race and the Nicads would get label-melting hot. Some companies sold aluminum finned heatsinks. Bro science at its finest...
Genesis 49:16-17
Genesis 49:16-17
#52
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
#53
have multiple batteries that are good to go
#54
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
These battery problems might be a reasonable argument to convert to a dynamo hub.
Also: computer USB ports do not necessarily output as much charging power as dedicated USB chargers.
#55
There are 18650 batteries from Nitecore especially for use in low temperatures:
nitecorestore.com/SearchResults.asp?Search=low+temperature&Submit=GO
charger.nitecore.com/product/nl1829ltp
charger.nitecore.com/product/nl1829lthp
charger.nitecore.com/product/nl1829rltp
#56
Quoted: 18373 Post(s)
Liked 4,508 Times
The electric cars are supposed to regulate their battery temperatures (heat or cool as needed). It might help if they are on a float charge at night so they can have power heating.
My guess is the Tesla range was shortened because the guy was using electric resistance heating in the car (and perhaps for the batteries).
Ideally, though, a car will also recover heat from the motor for use.
#57
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
This is one of the reasons I no longer use lights with integrated rechargeable batteries. Instead, I use lights, front and rear, that can use removable primary or rechargeable batteries. They are getting more difficult to find, but they are much more versatile if you ride in the cold or need for a light to longer than a few hours (and don't want a battery pack with cord). My front light is a Fenix BC30 (in warmer weather I use 18650s, and in cold weather I use the same and carry extras or CR123A primaries), my rear is a PDW Radbot (rechargeable AAAs in warmer weather, extra off the same when it's colder or lithium primaries).
Don't complain about the weather and cower in fear. It's all good weather. Just different.
#58
Quoted: 539 Post(s)
Liked 44 Times
In the normal course of things, I replaced several of my extra blinkies this year. It's getting harder to find decent lights that at least pretend to be weather resistant, so I've got at least one rechargeable blinkie on each commuting bike. I've already found it more of a hassle to take each one off the bike, bring it in, and recharge it weekly, as opposed to tossing a couple new alkalines in every 4-6 weeks. Not looking forward to finding out what really cold weather is going to do to the rechargeables.
Pull in on the bike, connect the charging wire, done. Of course having to plug anything in is a slight amount of hassle but I find it's easier on my brain to do it every time than to mentally remember something periodically.
Yeah mine to. :-) Even better, in the winter with the snow reflecting lights you need less light, so even my older dynamo lights gets me more light than I need. Dynamo's are really ideally suited for winter riding.
#59
Pacific
Sub 0C being rare here* , My studded tire bike has removable battery lights AA & AAA.. they go in my pocket when I'm off the bike..
When 27f it was dry, last year not a cloud to be seen (or retain heat from daytime) ..* I'm by the ocean.. ranges between lower 40s to mid 50s.. ...
Mountaineers headlamps have the battery pack on a cord, so you keep the batteries in a pocket under the down parka..
#62
Panasonic NCR18650F is designed for use in low temperatures:
https://na.industrial.panasonic.com/.../ncr18650f.pdf
Panasonic NCR18650F 2900mAh Low temperature AKKU li-ion battery -
lungimsam
Commuting
9
12-01-12 08:55 AM
Not the Slowest
6
11-08-10 12:22 PM
