Tire clearance: would you ride?
Old 09-02-19, 02:37 PM
jideta
Quoted: 94 Post(s)
Liked 139 Times in 74 Posts
Chain stays from below
front fork
Probably a couple of MMs on each side, top of tire has more room.
28mm tires on 24mm wide rims.
Thinking 23mm wide rim is goin to be better (got some HsonPlus coming in)?
Or go back to 26mm tires?
What say ye?
jideta is offline
Old 09-02-19, 04:46 PM
Tulok
Tulok's Avatar
Quoted: 47 Post(s)
Liked 20 Times in 17 Posts
Yes without hesitation.
Tulok is offline
Old 09-02-19, 05:03 PM
diff
Quoted: 18 Post(s)
Liked 5 Times in 5 Posts
Yeah that is fine. As long as when you spin it there is no rubbing.
diff is offline
Old 09-02-19, 05:04 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Plenty of room.
caloso is offline
Old 09-02-19, 08:53 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
Originally Posted by caloso
Plenty of room.
+1 unless you break a spoke.
I wouldn't worry about the off chance of breaking a spoke.
noodle soup is offline
Likes For noodle soup:
Old 09-03-19, 09:07 AM
GuitarBob
Kit doesn't match
GuitarBob's Avatar
Bikes: 5
Quoted: 187 Post(s)
Liked 27 Times in 19 Posts
I'd ride it too. As the tires wears it'll get even better .
GuitarBob is offline
Old 09-03-19, 09:12 AM
Banzai
Jet Jockey
Banzai's Avatar
Bikes: Cannondale CAAD9, Ritchey Breakaway Cross, Nashbar X-frame bike, Bike Friday Haul-a-Day, Surly Pugsley.
Quoted: 382 Post(s)
Liked 29 Times in 25 Posts
Jan Heine, the plump tire evangelist, says 3mm minimum spacing all around for safety.
Industry standard has historically been 4mm.
Banzai is offline
Likes For Banzai:
Old 09-05-19, 05:03 AM
jideta
Quoted: 94 Post(s)
You guys had me feeling all brave then I remembered that once a year I gotta ride over Monkey Pod seeds:
So sticky you can hear them seeds and parts bounce off yer tubing. Need to clean inside of fork.
Also no avoiding as the Monkey Pod trees are like everywhere.
Back to 26mm tires me thinks.
BTW, 23mm rims weren't any better.
Thanks!
just found out that the seeds are edible! free food!
jideta is offline
Old 09-05-19, 09:57 AM
goenrdoug
goenrdoug's Avatar
Bikes: 2019 Supersix Evo, 2002 Trek 2000
Quoted: 273 Post(s)
Liked 45 Times in 32 Posts
No, would not ride. Look for a minimum of 3-4mm clearance between tire and frame -- more if your wheels are flexy and/or you are heavier/frequently crank it up to 400W.
goenrdoug is offline
Old 09-06-19, 08:22 PM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times in 266 Posts
Put some duct tape and inside the chain stays. If the tire rubs then no. I got new wheels for my Madone 5.0. Went from 14mm inside width rims to 19mm. Now a 25mm tires is almost 28 mm and a 23 is almost 27 mm. I have to run a 23 in the rear and can run 25mm in front. So much for jumping on the wide tire band wagon unless I get a new frame.
biker128pedal is offline
Old 09-07-19, 02:54 AM
jideta
Quoted: 94 Post(s)
I hear ya.
My bicycle is 9 years old or so, not designed with these newfangled rims in mind.
Going down to 23mm wide rims mades things better some at least in front.
Decided I wanted some aero so thinking about some Aforce wheels at 24mm wide and I'll be back where I was. 26mm tires.
Shouldn't be too bad.
See if I can fit the 28mm tires on my steel frame.
If not, anyone wanna buy some 28mm Turbo Cottons?
jideta is offline
Old 09-07-19, 04:04 AM
jbchybridrider
jbchybridrider's Avatar
Quoted: 227 Post(s)
Liked 390 Times in 149 Posts
Right side of tire as pictured, has never touched
jbchybridrider is offline
Old 09-07-19, 04:31 AM
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
If the frame isnt carbon id ride it. Ive stuffed 48mm tires into a frame for similarly tight clearance amd ridden them on gravel without issue
redlude97 is offline
Old 09-07-19, 07:48 AM
sdmc530
Heft On Wheels
sdmc530's Avatar
Quoted: 887 Post(s)
Liked 560 Times in 346 Posts
Run it!!!
sdmc530 is offline
Old 09-07-19, 01:22 PM
seau grateau
seau grateau's Avatar
Quoted: 1332 Post(s)
Liked 398 Times in 194 Posts
Hell yeah
seau grateau is offline
Old 09-07-19, 02:30 PM
JohnJ80
Bikes: N+1=5
Quoted: 875 Post(s)
Liked 244 Times in 181 Posts
I'd have to agree with this. I just went through this trying to get some Schwalbe Pro ones in 28mm to work on my racing geometry frame. Probably 2mm or so clearance so the tire turned through there. The downside was anytime I picked up a little tar covered rock, it would tend to jam in there and I'd have to stop and knock it out. So it's going to depend on where you ride and your tolerance for getting stuff jammed up in there. The 28's I was using were on the pudgy side and it was on a wide, but not exceptionally wide rim (23mm, I think internally).
JohnJ80 is offline
Old 09-08-19, 06:00 PM
jideta
Quoted: 94 Post(s)
Yeah the more I look at it the more it's a no go.
Carbon frame so anything gets stuck...I can imagine the sound it's going to make. The monkeypod seeds can be crazy and they've gotten stuck in the fork before.
LBS guys said no go too. Customer there laughed and said he'd go.
I suppose it's easy to say when it's not your frame!
Thankfully I've been waiting for a free hub so I haven't been tempted to ride it.
jideta is offline
Old 09-08-19, 06:01 PM
jideta
Quoted: 94 Post(s)
Not really worried so much about side to side, more like on the top and back of chain stays where stuff can get stuck.
If was just side to side I'd go.
jideta is offline
Likes For jideta:
UnCruel
Bicycle Mechanics
2
09-06-15 05:01 PM
part_robot
Road Cycling
3
05-05-15 07:14 AM
SevenSpokes
Bicycle Mechanics
2
12-22-13 04:38 PM
smurray
Road Cycling
2
06-11-12 11:19 AM
clanmacleod
Hybrid Bicycles
5
12-12-09 05:12 PM
