Made some progress on organizing the shop
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,084 Times
Got some of the wheels up off the ground.
Bikes: Numerous
Liked 3,084 Times
But still have more work to do ....
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4677 Post(s)
Liked 5,790 Times
The never ending battle.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 333 Times
Well done. Step by step gets things done.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
Bikes: Numerous
Liked 3,084 Times
Those are pieces of a sandbag toss game that’s pretty popular in the south. It is called, without any sense of irony, “corn hole”.
PM me your cotters
Quoted: 1137 Post(s)
Liked 588 Times
And used to be "bean bag toss". Why it needed to be renamed to "corn hole" is anyone's guess.
I made something similar but used 1/2" conduit. Clamped two runs in parallel offset by about 12-14". Home Depot and Ace Hardware both have "sign hangers" for around a buck a piece you can modify in half, then bend to hang pairs of wheels. Just cut in half above the middle loop, then bend to offset. Here are some pics to explain. First, the whole hanger, the halved hanger, the bent hangers. $1 per pair of wheels was a good cost to benefit compromise for me. Then the conduit running parallel and some wheels hung.
Bikes: Numerous
Liked 3,084 Times
I like that idea francophile.
Im thinking about how to do a second row in front of this one with the wheels staggered and hung up higher, suspended between the floor joists. Maybe some iron pipe run through them with your hangers might be the solution.
PM me your cotters
Liked 588 Times
Yeah, without having I-beams or joists with gaps, my idea of using conduit won't work unless you were to using (at least) strategically placed shims or furring strips to act as a standoff.
I won't lie though, the conduit idea was from someone else here. I just stumbled upon the "sign hangers" at the store and realized the loop part would hang perfectly on conduit. Just needed to bend the correct way to support a wheel.
Using the parallel runs allows an offset so you can pack in denser. I aimed for 13" between the conduit runs if memory serves correctly, this puts the QR or axle holes just shy of the next rim's edge. You could do the same with another 2x4 a foot away, then stagger hooks in between the other 2x4's hooks.
Sad part about this is, even with this, I can store a good 40 wheels and still have another 10-15 pairs on the floor.
Honestly, wheels for me are almost like Tribbles in Star Trek. I need to do a mass-post here of wheelsets but I should probably buy a bunch of wheel shipping boxes in advance. I've got some pretty cool stuff I'll never use.
Quoted: 1627 Post(s)
Liked 630 Times
Coat hanger wire. Or old galvanized spokes; plenty stiff.
Likes For Lascauxcaveman:
Bikes: Numerous
Liked 3,084 Times
Well on further reflection, it will be a major engineering challenge to work iron pipe up into the position I need. I think what I’m going to do is Fix short sections of 2x4 horizontally, screwed end on into the vertical joists, about 8” higher than the current 2x3. Same hook idea and the wheel will rest against that 2x3. I’ll have to stagger each one a little to be able to place the screws but I think it will look good.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Anyways, its popular all over.
I always figured corn*hole was a reference to the bags being filled with corn as a weight.
The awesome bikeforums software makes me separate corn and hole because it lacks context. It will be a sad day when the robots finally take over.
WGB
Bikes: Panasonic PT-4500
Quoted: 1794 Post(s)
Liked 2,328 Times
@francophile "I should probably buy a bunch of wheel shipping boxes in advance"
Instead of buying grab the boxes flat screens come in and you can cut to size.
Likes For WGB:
PM me your cotters
Liked 588 Times
I'll probably just hit up Uline though, buy 15 boxes and move some product. I need to clear some floor space. And I can't use the above.
working on my sandal tan
Liked 2,563 Times
The game is plenty popular in my area... with "Beavis & Butthead" and "Office Space" in mind, I call it "bags" whenever possible.
P.S. Nice work on organizing your wheels, @Spaghetti Legs. I don't have a large collection of spare wheels, but I could stand to organize them better.
PM me your cotters
Liked 588 Times
Because my pics above sucked, here are two more showing what I'm doing. Better shows the conduit and the basic clamps. And a fingertip, because I've had a bad day.
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Who needs iron pipe? I just used the cheapie conduit. You could easily use PVC. Strength isn't imperative.
Liked 5,790 Times
Likes For gugie:
Quoted: 821 Post(s)
Liked 255 Times
Looks great everyone.
However, I am pleased to report my overflowing supply of wheelsets is just about depleted.
Down to four and they are nice ones.
The Trouble With Tribbles is that one always knows someone that needs a Tribble, so they just hang around until gone. My collection of Tribbles is down to only a few select spares. The rest have found their way onto bikes over the past year.
Bikes: Numerous
Liked 3,084 Times
Mission Complete
.. for now.
After my next build is done (Heron Randonneur) I’ll have one road and two MTB wheels homeless.
Now what to do with the bikes ...
Likes For Spaghetti Legs:
