Asymmetric wear of tires
Old 05-21-17, 01:50 PM
dvai
Quoted: 71 Post(s)
Dear all.
I need advice.
I have a fairly new Domane S6 2017.
Came with 25" tires. I called Bontrager and they told me I can fit 28" with no issues.
So I did. I also got new (larger tubes) and a bike fit.
The bike gained a lot of comfort and performance even though I know most of it has to do with the fit.
Anyways. While Im happy with the new set-up, I have done about 100 miles so far and noticed both tires are not wearing out exactly in the center. They are slightly biased towards the left. Especially the back tire. You can barely notice the front one, but on the back one there is at least 1 mm bias.
What can cause this? Was the change in tires?
I also wonder the potential issue this can have.
Previous tires: Bontrager R1 25mm
New tires: Bontrager R3 28 mm with continental sport tubes.
Any advice is greatly appreciated.
dvai is offline
Old 05-21-17, 01:58 PM
canam73
Quoted: 5 Post(s)
First thought I have is if you are making sure your wheels are centered in the frame.
Although 1mm doesn't sound like much, also.
canam73 is offline
Old 05-21-17, 02:13 PM
seau grateau
seau grateau's Avatar
Bikes: Litespeed, IRO
Quoted: 1280 Post(s)
Liked 221 Times in 120 Posts
Don't turn left as much.
seau grateau is offline
Old 05-21-17, 02:20 PM
rpenmanparker
rpenmanparker's Avatar
Quoted: 6551 Post(s)
Liked 46 Times in 29 Posts
Who turns left? That's stupid.
Robert
No matter where I go, here I am...
rpenmanparker is offline
Old 05-21-17, 02:22 PM
WhyFi
WhyFi's Avatar
Quoted: 12505 Post(s)
Liked 2,145 Times in 1,135 Posts
Are you a track cyclist?
WhyFi is offline
Old 05-21-17, 02:26 PM
smarkinson
Quoted: 332 Post(s)
Liked 13 Times in 7 Posts
Road camber? Roads should be higher in the centre for water runoff.
smarkinson is offline
Old 05-21-17, 02:28 PM
canam73
Quoted: 5 Post(s)
That sound's like a winner.
canam73 is offline
Old 05-21-17, 03:03 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4602 Post(s)
Liked 1,182 Times in 703 Posts
I'm gonna go with this as well. On many of the high-crown roads around here, I notice having to steer every so slightly to the left just to keep going in a straight line. I don't know if it actually contributes to wear at all, but I do notice that the pattern of dirt on the tire has a wider stripe on the right side of the tire than on the left.
DrIsotope is offline
Old 05-21-17, 03:05 PM
Spoonrobot
Spoonrobot's Avatar
Quoted: 1167 Post(s)
Liked 112 Times in 79 Posts
I had the same issue, turns out mine was from a saddle that I was sitting on off-center and canting the bike to one side.
Spoonrobot is offline
Old 05-21-17, 03:08 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7161 Post(s)
Liked 686 Times in 446 Posts
Crowned Road, you are on a slight slope..
fietsbob is offline
Old 05-21-17, 03:09 PM
Succhia Ruota
in bagnomaria
Succhia Ruota's Avatar
Bikes: N+3 dependents
Quoted: 144 Post(s)
Liked 26 Times in 10 Posts
Flip the direction of the tires on your rims. After a while, problem solved. Repeat as needed.
Succhia Ruota is offline
Old 05-21-17, 03:25 PM
WhyFi
WhyFi's Avatar
BBBUT the TREAD DIRECTION!
WhyFi is offline
Old 05-21-17, 03:29 PM
dvai
Quoted: 71 Post(s)
Well, I was trying to find the cause.
dvai is offline
Old 05-21-17, 03:30 PM
dvai
Quoted: 71 Post(s)
That's interesting. So you just moved the saddle to the center?
dvai is offline
Old 05-21-17, 03:31 PM
FBinNY
Quoted: 4360 Post(s)
Liked 15 Times in 15 Posts
+1
Left side off center wear is perfectly normal in the USA because roads are crowned, so you're generally riding across a slight slope.
The wear will be biased to the right if you live and ride in the UK, Australia or other "drive left" countries.
BTW- if you don't see a slightly left side wear bias, there's something wrong, because this would mean that the bike was perpendicular to the angled road surface, and something is causing it to be off plumb.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 05-21-17, 03:33 PM
Succhia Ruota
in bagnomaria
Quoted: 144 Post(s)
Ah, well then it's over for him. Time to quit the sport, donate the bike. I'll send my address.
Old 05-21-17, 03:47 PM
dvai
Quoted: 71 Post(s)
Originally Posted by FBinNY View Post
+1
Interesting tip. Thanks!
dvai is offline
Old 05-21-17, 03:49 PM
Spoonrobot
Spoonrobot's Avatar
I got a different saddle that was built correctly and fit my anatomy.
Old 05-21-17, 04:08 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 2902 Post(s)
Liked 353 Times in 274 Posts
All this said.. I'm not sure I could notice any wear in a tire after only 100 miles, much less identify an uneven distribution of such.
Sy Reene is offline
Old 05-21-17, 07:10 PM
FBinNY
No sweat, the OP can move to England and equalize the wear pattern.
Actually Brits may be best off. They can head to France or Holland every few months and keep their tires worn evenly.
Either that, or find an equally concerned buddy who rides on the other side, and swap tires now and then.
FB
Chain-L site
FBinNY is offline
Old 05-21-17, 07:12 PM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 1,175 Times in 611 Posts
If moving to Britain for six months each year isn't convenient, flipping the tires around (assuming their is no directional tread) would work.
wgscott is offline
Old 05-21-17, 07:18 PM
rpenmanparker
Or just fuggeddaboudit. I mean who even cares?
Robert
Old 05-21-17, 07:24 PM
FBinNY
Since people notice, then post here asking about it, it's safe to assume that SOMEBODY cares at one level or another..
Like you, I don't, but then after 50 years I have no interest in looking too closely at my bike in the first place.
OTOH - it's possible that someone noticed, wondered if it was worrisome, then once understanding the why, will no longer care.
FB
Chain-L site
FBinNY is offline
Old 05-21-17, 07:44 PM
f4rrest
Farmer tan
f4rrest's Avatar
Bikes: Allez, SuperSix Evo
Quoted: 2870 Post(s)
Liked 22 Times in 18 Posts
Elves and sandpaper, probably.
f4rrest is offline
Old 05-21-17, 07:53 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 1972 Post(s)
Liked 691 Times in 425 Posts
Now I need to take out my vernier calipers and check my tires.
Shimagnolo is offline
