Rack for bikes with fenders
Old 03-03-20, 08:45 PM
Koyote
Quoted: 825 Post(s)
Liked 620 Times in 331 Posts
Hi all. Perhaps there is a better subforum for this, but I didnít see one. Iím looking for a hitch-mounted bike rack that will safely accommodate bikes with fenders. Seems like most of the good ones have the swing arm that clamps down on the front wheels (like this one) which will not be very friendly to fendered bikes.
All suggestions appreciated!
Koyote is offline
Old 03-03-20, 10:33 PM
JanMM
rebmeM roineS
JanMM's Avatar
Bikes: RANS V3 ti, RANS V-Rex, RANS Screamer
Quoted: 556 Post(s)
Liked 168 Times in 112 Posts
Yakima Two Timer works with bikes with fenders.
RANS V3 Ti, RANS V-Rex, RANS Screamer
JanMM is offline
Old 03-04-20, 07:10 AM
TomJD
Swagman G10
I bought one of these last year for exactly this reason. A short length of pipe insulation helps provide additional top tube cushioning and protection. I have used it for local as well as day long interstate trips and am quite pleased.
TomJD is offline
Old 03-04-20, 07:24 AM
Koyote
Quoted: 825 Post(s)
JanMM and TomJD :Thanks for the recommendations. I note that the rack has an arm that clamps over the top tube. Have either of you had issues with scratches or other paint damage?
Koyote is offline
Old 03-04-20, 02:30 PM
TomJD
No, that's why I place a short length of pipe insulation around the top tube where the clamp contacts it. Easy!
TomJD is offline
Old 03-04-20, 04:43 PM
Nyah
Bikes: '99 Trek 520, Konacado ('20 Kona Sutra).
Quoted: 123 Post(s)
Liked 40 Times in 29 Posts
Any reasonably stocked bicycle shop should have numerous racks that are compatible with fenders. The bicycle itself is where the incompatibility would exist, as some do not have eyelets for racks.
Nyah is offline
Old 03-04-20, 05:02 PM
mr_bill
Quoted: 1838 Post(s)
Liked 336 Times in 242 Posts
If you donít want a rack that touches the frame, look at:
Saris Superclamp family
Thule Helium Platform (?)
Fender friendly wheel clamps and no pipe insulation required.
-mr. bill
mr_bill is offline
Old 03-04-20, 08:21 PM
Koyote
Quoted: 825 Post(s)
Thule T2 family
-mr. bill
Those both appear to be precisely the type of rack that I would like to avoid: that clamp on the front wheel will damage a fender, I believe. Unless I am missing something?
Koyote is offline
Old 03-04-20, 08:38 PM
mr_bill
Read The Manual.
The clamps on the front wheel at 10:00 will NOT damage a fender. On the rear wheel, use a wheel strap.
If you don’t want to touch your tire, wheel, or frame get a rack where you remove the front wheel and clamp through the fork. If you don’t want to do that, I’m stumped.
-mr. bill
mr_bill is offline
Old 03-04-20, 09:15 PM
Koyote
Quoted: 825 Post(s)
Read The Manual.
If you donít want to touch your tire, wheel, or frame get a rack where you remove the front wheel and clamp through the fork. If you donít want to do that, Iím stumped.
-mr. bill
Are you saying the clamp will be on the tire rather than the fender? If so, that depends on the length of the fender, correct?
Or are you saying that the clamps are soft/gentle/whatever?
Koyote is offline
Old 03-05-20, 07:33 AM
mr_bill
The tire clamp goes on the FRONT tire. Instead of a tire clamp on the rear, use a wheel strap instead.
-mr. bill
mr_bill is offline
Old 03-05-20, 08:11 AM
Kapusta
Cyclochondriac
Quoted: 1365 Post(s)
Liked 525 Times in 329 Posts
-mr. bill
That does not look like the best solution to me for a fendered bike.
The front arm is pushing back, and it is completely dependent on the rear strap to pull back against it. The cradle the rear wheel sits in is tilted the wrong way. Can it be tilted forward to push back against the force from the front wheel clamp? Is the position of it adjustable so that it can be slid back behind the center of the rear wheel?
The rear wheel strap (or any wheel strap) should be just keeping the bike from bouncing out. As pictured, it is mission critical to keep the bike in the rack at all, and under a bit of tension.
Maybe I am missing something, here.
@ OP: I think for full fendered bikes, a frame clamp is the best option. They are the most flexible solution out there. They are also not thrown off by front racks.
Of course, I have never had issues with racks that contact the frame causing any damage, even after roughly 40K miles of travel with several bikes all over the country. YMMV.
Kapusta is offline
Old 03-05-20, 08:47 AM
mr_bill
Yeah, you take another look at the wheel trays in the picture. Think about why they are angled that way. The bike very simply can't "roll" out of the wheel trays if you use the wheel strap and tire clamp.
Hope you find what you are looking for. I wish you good luck in your search.
-mr. bill
mr_bill is offline
Old 03-05-20, 09:44 AM
RidingMatthew
Let's Ride!
RidingMatthew's Avatar
Quoted: 313 Post(s)
Liked 19 Times in 12 Posts
I think Mr Bill might be right but I have used a frame rack with straps holding the wheels in. I want to upgrade but I have a bike with fenders and it definitely limits some options.
"Work to eat. Eat to live. Live to bike. Bike to work." --Anonymous ||| "late & alive > early & dead." ~Steely Dan
RidingMatthew is offline
Old 03-05-20, 09:59 AM
Kapusta
Cyclochondriac
-mr. bill
Yes, I have looked and to me It looks like they are angled the way they are for use with the clamps that go over the wheels. But with a full coverage rear fender there is no clamp over the rear wheel. Thus my comment.
Does the angle of the arms lock at different positions, such as 12 or 10 oíclock?
Just curious. I assume you have one of these and have used it with full coverage fenders, so Iíll take your word for it if it has worked out well.
Kapusta is offline
Old 03-05-20, 10:50 AM
mr_bill
You use a WHEEL STRAP with the rear wheel in lieu of the TIRE CLAMP.
It locks at many different positions, they recommend setting them to either 10 or 2 o'clock for obvious reasons.
A friend has one. It works just fine with fenders. Really.
-mr. bill
mr_bill is offline
Old 03-05-20, 10:55 AM
adalah
Agree with you..
adalah is offline
Old 03-08-20, 08:07 AM
westrid_dad
westrid_dad's Avatar
Bikes: Surly Ogre, Cannondale Topstone 105
Quoted: 9 Post(s)
Liked 16 Times in 11 Posts
Several of our bikes have fenders and racks mounted, and when we were shopping for hitch-mount bike racks there were fewer options that officially supported carrying bikes with fenders. We ended up with the Thule EasyFold XT2. It isn't cheap, it isn't light, it isn't as quick and easy to attach / remove bikes, but it carries any of our bikes very securely.
https://www.thule.com/en-us/bike-rac...-xt-2-_-903202
westrid_dad is offline
Old 03-08-20, 11:07 AM
Bryan C.
nothing to see here
Bryan C.'s Avatar
Quoted: 187 Post(s)
Liked 99 Times in 53 Posts
I use a Kuat sherpa rack with a bike with metal portland design works fenders. I have transported it thousands of miles without any damage to the front fender. I do put a small microfiber cloth between the arm and the fender/fork area to protect the finish but that's it.
Bryan C. is offline
