Park Rotor Gauge on the Old TS-1 Truing Stand?
Old 05-06-20, 09:34 PM
DropBarFan
Quoted: 666 Post(s)
Liked 43 Times in 37 Posts
Most folks true their brake rotors with wheels mounted, I've had some success that way but it's a bit hard to see things even with a headband light. I'd like to try the Park DT-3 rotor truing gauge but my ancient Park TS-1 truing stand isn't drilled for it. I read one post where someone used a drill press to fit the DT-3 but I only have a light-duty hand electric drill. The TS-1 arms are quite stout--am I right to assume it would be very difficult if not impossible for me to drill them for the DT-3?
I suppose one could have a machine shop or auto shop drill the TS-1 but I'd guess that would be $100 at least, for me not worth the expense & bother.
DropBarFan is online now
Old 05-06-20, 10:03 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2388 Post(s)
Liked 446 Times in 349 Posts
Depends on your skill. Many people drawn to the mechanical side of life would have little problem doing this. It's just steel. Andy
AndrewRStewart
Andrew R Stewart is online now
Old 05-07-20, 10:02 PM
DropBarFan
Quoted: 666 Post(s)
Thanks, worth a try then I think. Also I wondered if it would be necessary to drill the TS-1 in the same exact spot as the current Park stands but since the DT-3 gauge rotates anyway I think there might be a bit of leeway allowed.
Old 05-08-20, 07:06 AM
Andrew R Stewart
I would mock up the gage with a couple of different wheels in the stand before touching a drill to the stand. Use a sharpie to mark where each wheel's best location for the gage's mounting then think about it before deciding where the hole will go. Andy
AndrewRStewart
Old 05-09-20, 09:36 PM
DropBarFan
Quoted: 666 Post(s)
Thanks--I have 622 & 559 wheels that should give a good range.
