Pedal threads - non-standard size
Old 05-17-20, 12:24 PM
KC8QVO
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 196 Post(s)
Liked 27 Times in 24 Posts
I am trying to get SPD clipless pedals on an old department store bike. The thread pitch is the same, but the diameter of the bores is a hair less. I did not have anything to measure with at the time so I do not know what the size is (I can find out).
My question is if anyone knows if there is a way to adapt pedals to work.
I would be tempted to drill and tap the crank, but from what I saw I don't think a proper size drill bit to cut the larger threads would get down past the original threads to full meat. That, and if I could, I don't have a left handed thread tap that size (I don't have any left handed thread taps period).
Replacing the crank would mean replacing the chain rings also. There again, I don't know what the BB size is. With everything else that's been "odd-ball" sized I would expect the BB to be a strange size also at this point.
KC8QVO is offline
Old 05-17-20, 12:36 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 989 Post(s)
Liked 209 Times in 164 Posts
1 piece cranks use 1/2" pedals instead of 9/16".
Reason: There isn't enough metal left in the arm if drilled for 9/16".
Get some 1/2" pedals at xmart.
Bill Kapaun is offline
Old 05-17-20, 12:38 PM
sch
Quoted: 228 Post(s)
Liked 39 Times in 33 Posts
Pedal threads are "non-standard" pitch for the diameter at 9/16x20TPI and the L sided crank is threaded L hand. In your
scenario if the pitch really is 20TPI then best bet is to find an LBS with pedal tap set and have the cranks rethreaded.
A drill out may not be needed, or only a minimal drill out.
sch is offline
Old 05-17-20, 12:52 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 977 Post(s)
Liked 245 Times in 190 Posts
I think there are adapters that screw into the 1/2 thread, and have a 9/16 thread.
This ?
https://www.ebay.com.au/itm/NEW-Bike...-/293129834400
Homebrew01 is offline
Old 05-17-20, 01:44 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2387 Post(s)
Liked 442 Times in 346 Posts
"A hair less"?? Like actually how much less is a hair? Is that a red hair or a blond one?
As others have said 1/2" pedal threading is common on cheaper bikes. But so to is poor manufacturing in general. Most SPD pedals are from manufactures that take more QC and production care then the cheapest bikes available (as in big box built for the lowest price point ones). If the threading isn't 1/2" but is 9/16" I will suggest that the crank arms were not well made, as in an old/dull tapping tool was used.
An experienced person can figure this out real fast if they are allowed to get their eyes and hands on the cranks. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-17-20, 02:05 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1052 Post(s)
Liked 409 Times in 307 Posts
I know, right? My father was a tool-and-die maker used to working to precision of 0.0005" (half a thousandth) and less, and one of his Scottish co-workers would drive him nuts asking for a "wee" drill.
dsbrantjr is offline
Old 05-17-20, 04:25 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 17831 Post(s)
Liked 1,488 Times in 1,104 Posts
This ?
...yes, they are available on Amazon and e-bay. I have a set I used to put better pedals on a Fauber crank equipped DBS bike here.
3alarmer is offline
Old 05-17-20, 04:28 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
....just look up the adapters on Amazon and buy a pair. They move the pedal surfaces out a little bit, but in many cases that's an extra bonus feature.
3alarmer is offline
Old 05-17-20, 09:01 PM
KC8QVO
Quoted: 196 Post(s)
A black pubic hair. Curly, round at the root.
Thanks for the adapter suggestion. I will look in to it.
When I found the threads were different I was prepping the bike for a ride with a friend. I didn't have anything to measure with, all I know is the pedals I was putting on are the same thread pitch and too big to screw in - not by much. Pedals were Shimano's. Same size as my regular bikes, not sure what size that is off the top of my head.
In fact... I think the pedal threads on my mountain bike (department store variety, 25+ years old) are the same threads as my regular bikes. It seems to me I had put different pedals on it at one point.
KC8QVO is offline
Old 05-17-20, 09:19 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 566 Post(s)
Liked 142 Times in 108 Posts
If it's that close I would suspect a boogered thread. Bicycle pedal threading is about as universal a standard as there is. If the cranks are aluminum: 9/16" x 20tpi. If the cranks are steel: 1/2" x 20tpi. It's been that way for about the last 35 years.
Jeff Wills
Jeff Wills is offline
Old 05-17-20, 09:28 PM
Bill Kapaun
Quoted: 989 Post(s)
1/2"-20 is a common SAE Fine thread size.
Buy a bolt at your local hardware/xmart.
See if it fits the R. arm. I'm pretty sure it will.
Lot's of 1/2" pedals here on just a couple second search.
https://porkchopbmx.com/pedals/1-2-p...-piece-cranks/
Likes For Bill Kapaun:
Old 05-17-20, 10:40 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1443 Post(s)
Liked 269 Times in 196 Posts
This well not worth your time. I would never want to be clipped in to a Wally-mart bike for fear it falls apart underneath me and I am still attached. There a bodges that will make it work sure but do you really want to do this? The pedals are probably worth more than the entire bike.
veganbikes is offline
Old 05-18-20, 06:00 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 610 Post(s)
Liked 323 Times in 201 Posts
French pedal threads are a hair less than 9/16, though I can't imagine a dept. store bike having these.
Moe Zhoost is offline
Old 05-18-20, 08:15 AM
Andrew R Stewart
Try installing the pedals from the backside of the crank arms. If the starting threads were mashed a bit form the previous pedals the back sides will be clean. A quick test. Any decent service focused LBS should have pedal taps to clean up the threads with. Be careful as many taps can be slightly tapered and one can cut the threads too much oversized if not tested after a small bit of chasing. Andy
AndrewRStewart
Old 05-19-20, 11:52 PM
frizzen
Bikes: 1955 Hercules Royal Prince Fixed Gear
How "old"? French bikes were 14 mm x 1.25, but probably not since the 1980s. Really old (1960s?) British bikes are 9/16" x 20 TPI BSC (British Standard Cycle) which are about .004" smaller than the current 9/16" x 20 TPI UNT.
frizzen is offline
