Bar end shifter refurbish
Old 05-23-20, 06:03 AM
Thruhiker
Thruhiker's Avatar
Bikes: Fuji touring, jeep hybrid.
Quoted: 24 Post(s)
Liked 5 Times in 5 Posts
Hi all
I'm working on my fuji touring bike mostly cosmetic stuff. My bar end shifter were/are pretty beat up but work fine still. I've filed and sanded the worst scratches and gouges out of them and the repainted useing automotive paint. I dont know what to do about the lever themselves. The rubber grip part has long since torn off and the past couple years I've just used electrical tape. Any other suggestions? Shrink tube does not work due to there shape. Has any one tried plastic dip? What about wrapping with string I think it's called twineing? Thank you
Thruhiker is offline
Old 05-23-20, 07:34 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1057 Post(s)
Liked 423 Times in 313 Posts
Plast-Dip should work OK but twine should look attractive, especially if you use it to end your bar tape wrap also; a layer of shellac will make it long-lasting. Self-fusing silicone tape may also be worth a try.
dsbrantjr is offline
Old 05-23-20, 08:27 AM
Crankycrank
Quoted: 269 Post(s)
Liked 72 Times in 58 Posts
This maybe. https://velo-orange.com/products/rus...-shifter-cover Also just do a search for "bar end shift lever covers" or some such thing. Microshift has readily available covers if they happen to fit. I like the Plasti-Dip idea. You might have to use 3 or more coatings for it to last.
Crankycrank is offline
Old 05-23-20, 11:20 AM
phughes
phughes's Avatar
Quoted: 393 Post(s)
Liked 169 Times in 107 Posts
Go for twining if you want something unique. For a more comfortable surface, instead of actual twine, you can use a smaller diameter thread or chord.
phughes is offline
Old 05-23-20, 03:26 PM
dsbrantjr
dsbrantjr's Avatar
Some twine ideas here: https://www.hempbasics.com/shop/Cate...ral-hemp-twine
Old 05-23-20, 07:52 PM
Miele Man
Bikes: Miele Beta, Miele Latina, Miele Suprema, Miele Uno LS, Miele MTB, Bianchi Model Unknown, Fiori Venezia, VeloSport Adamas AX
Quoted: 1011 Post(s)
Liked 567 Times in 390 Posts
What make are your barend shifters?
Cheers
Miele Man is online now
Old 05-23-20, 09:31 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2388 Post(s)
Liked 446 Times in 349 Posts
One of the common issues with dip grip and other bonding methods is the bonding won't take a bite to the lever. So besides good cleaning of the surface is essential any way to add some tooth will also help prolong the repair. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-23-20, 11:02 PM
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman
Quoted: 96 Post(s)
Liked 138 Times in 63 Posts
I have used plasti-dip on these and it works great. I had previously tried tape, tubes, and other options, but the dip works the best! The paddle is slightly tapered, so it stays put nicely. I simply cleaned the bare lever with alcohol, and did 3 coats of dip. It is more tactile and grippy than the original plastic covers, and seems more durable as well - with years of trouble-free service. You can get the dip in colors, too!
SalsaShark is offline
Old 05-24-20, 09:14 PM
Thruhiker
Thruhiker's Avatar
Quoted: 24 Post(s)
They are shimano dura ace. I think sl bs77 is the part number. I'm going to try the plasti dip. Thanks everyone.
