700 front, 27 rear
700 front, 27 rear
Old 05-24-20, 12:21 PM
kayakindude
Bikes: 1987 Cannondale SR600/BioPace, 1991 Cannondale Road Tandem,1994 Giant Iguana MB, 2009 Airnimal Chameleon, 2016 Dahon Vybe C7A
Quoted: 82 Post(s)
Liked 17 Times in 11 Posts
700 front, 27 rear
Hello, I have a 27 inch tandem that will get an electric upgrade shortly that uses a front hub system (swytch). One reason for buying the e-system was to switch it between the tandem and my wife's bike. Her bike rims are 700c. If I go 700c in the front for the tandem will it ride ok if I keep the 27 inch rear wheel?
Based on what I have read it would mean the front would ride about 4mm lower? Doesn't seem major but want some feedback. Thanks.
kayakindude is offline
Old 05-24-20, 12:56 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1063 Post(s)
Liked 434 Times in 319 Posts
I expect that she will adjust to any differences within a few hundred feet.
dsbrantjr is offline
Old 05-24-20, 01:44 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2391 Post(s)
Liked 451 Times in 352 Posts
Yes. the radius difference, for the same tire profile is 4mm. On a tandem this results in about half the very small head angle change as the wheelbase is much longer. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-24-20, 03:13 PM
kayakindude
Quoted: 82 Post(s)
Thanks everyone for the quick replies. Andy great point on the angle being even less significant because the frame is longer.
Old 05-24-20, 07:10 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 994 Post(s)
Liked 211 Times in 166 Posts
Will the rim brake pads (if equipped) adjust 4-5mm lower?
Identical sized tires? If you are running 27-1-1/4" tires, that's a 32mm tire. On paper at least, a 36mm tire would "level" you out.
Or put the heavy person on back.
Bill Kapaun is offline
Old 05-24-20, 08:22 PM
Gresp15C
Gresp15C's Avatar
Quoted: 771 Post(s)
Liked 194 Times in 141 Posts
I'll be like riding downhill all the time.
Gresp15C is offline
Old 05-24-20, 08:50 PM
Andrew R Stewart
Just like Sport, Paul Bunyan's dog. The childhood story I recall had Paul feeding Sport under the kitchen cabinets so the dog, gifted with bigger then real life size like Paul, grew it's hind quarters but it's front stayed the "normal" size. This way Sport was always "walking" down hill. Andy
AndrewRStewart
Likes For Andrew R Stewart:
Old 05-24-20, 09:50 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 343 Post(s)
Liked 113 Times in 92 Posts
You will not notice the difference in feel. The only real issue is whether you have rim brakes, and whether they can accomodate the difference.
cpach is offline
Old 05-24-20, 11:15 PM
downtube42
downtube42's Avatar
Bikes: Volae Team, '83 Bianchi Nuovo Racing v2,'74ish Windsor Carrera Sport, Priority Eight, Nimbus MUni, Trek Roscoe 6
Quoted: 190 Post(s)
Liked 265 Times in 147 Posts
For years I rode a 26" rear 20" front recumbent. The downside was what to carry on long self supporting rides. A folding 26" tire, 20" tire, neither, or both?
downtube42 is offline
Old 05-25-20, 12:05 AM
tcarl
tcarl
Bikes: Roark, Waterford 1100, 1987 Schwinn Paramount, Nishiki Professional, Bottecchia, 2 Scattantes, 3 Cannondale touring bikes, mtn. bike, cyclocross, hybrid, 1940's era Schwinn
Quoted: 25 Post(s)
Liked 5 Times in 3 Posts
For years my old Cannondale touring bike has had a 700x23 front and 27x1 1/4 rear. I don't notice a thing.
tcarl is offline
Old 05-25-20, 01:57 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 76 Post(s)
Liked 33 Times in 22 Posts
IMO, electric motors on any bicycle front wheel are a bit of a gamble.
With the overall weight and resulting strength demands of a front wheel on a tandem, even more so.
A powered front wheel on a loose surface, or wet/slippery spot is a bit un-nerving.
A front wheel motor is strictly a throttle actuated and can easily be in an overpowered mode in a turn.
Not certain, but I believe most front motors are 250 watt designs. The added weight of a tandem use might cause the
motor undo stress/torque requirements and premature burnout.
On background, I have sold electric bicycles as a factory rep.
rusty
100bikes is offline
Old 05-25-20, 06:45 AM
kayakindude
Quoted: 82 Post(s)
rusty
Thanks Rusty,
I plan to only use the motor sparingly when on the tandem, only for really hard climbing and once we are past the 20-25 mile mark as a slight assist. This first kit is mainly to help the wife when riding solo close the gap with my pace. I'm more an 18mph average and she is 14. Telling her to get in better shape seems like a bad option 🙄
I do have adjustable brakes to compensate.
Old 05-25-20, 03:40 PM
Andrew R Stewart
Originally Posted by kayakindude View Post
Thanks Rusty,
Gee do you think so?? Maybe you need to be willing to slow down when you ride together. Riding together is often like sex, it's the shared experience not the work out. And this goes for the tandem doubly so. Andy (who's on his third tandem).
AndrewRStewart
Old 05-25-20, 03:50 PM
kayakindude
Quoted: 82 Post(s)
Why Andy thanks for the advice 😁 that's what I currently do...we actually average 16 on the tandem. I was being sarcastic earlier, but no harm if a little e-assist can close the gap on longer solo rides as we head into our 50s. Agreed that whatever keeps us riding together works.
Old 05-25-20, 04:27 PM
velojym
velojym's Avatar
Bikes: 2000 Kona Jake the Snake, Surly LHT, Montague Paratrooper, Cannondale M500, Santana Arriva, Bridgestone 200, Trek 1200
Quoted: 85 Post(s)
Liked 95 Times in 60 Posts
Up front, worst case, you can get a new 700c fork. Go the cheapest (effective) route first, but on a decent tandem frame, I'd be willing to spend a bit more.
The size difference, insofar as handling is concerned, will be negligible, and easily compensated for with a slightly bigger tire, if you even bother at all.
velojym is offline
Old 05-25-20, 09:16 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1008 Post(s)
Liked 224 Times in 162 Posts
Agree with folks. Unless you're wife is a Princess (as in "The Princess and the Pea"), it will be hard for her to notice the 4mm diameter difference.
WizardOfBoz is offline
