how much are you suffering at FTP?
Old 02-12-15, 06:17 PM
greenlight149
how much suffering do you perceive when you are riding at or very close to FTP? how much is that suffering compared to how much more you can suffer?
i always thought that if you are suffering so much then you are probably going into the red, which will ultimately make you stop, but when riding at sustainable efforts ( eg. FTP), the amount of suffering that i personally experience doesn't seem to match what i read or see other peoples level of suffering.
am i just not pushing hard enough? i read that you should be super exhausted, nearly falling off your bike by the end of a FTP test, but i find if i push any harder i wouldnt be able to sustain the length of a FTP test, and if i back it off a bit then i dont feel like dying at the end ....
how much are you suffering?
greenlight149 is offline
Old 02-12-15, 06:25 PM
WhyFi
WhyFi's Avatar
Quoted: 12517 Post(s)
Liked 2,154 Times in 1,141 Posts
You're not going hard enough.
WhyFi is offline
Old 02-12-15, 06:46 PM
caloso
caloso's Avatar
Quoted: 2208 Post(s)
Liked 855 Times in 448 Posts
You should be super exhausted, nearly falling off your bike by the end of a FTP test.
caloso is offline
Old 02-12-15, 06:50 PM
greenlight149
i ride on rollers so i think its preventing me from pushing beyond a certain point, or else i will literally fall off. i dont have a turbo yet. anyone else have similar feelings on rollers?
Old 02-12-15, 07:39 PM
Bah Humbug
runner
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 5162 Post(s)
Liked 1,024 Times in 561 Posts
Just getting through the cooldown after an FTP test is a challenge (or should be). Ride harder.
Bah Humbug is offline
Old 02-12-15, 08:43 PM
kbarch
kbarch's Avatar
Quoted: 1096 Post(s)
The whole FTP thing is a mystery to me, but I find that suffering is a result, something I notice later, after I've stopped doing whatever strenuous, poisonous, or other if-it-doesn't-kill-us-makes-us-stronger thing, so my answer would have to be "none." As soon as the stress becomes an issue, the gig is up. The challenge is to prevent stress from becoming a conscious issue, to deny it, and to turn it off so you can keep going without the distraction. Pain and suffering is an opinion, and much of the time a pretty stupid one. We can entertain it at our leisure.
kbarch is offline
Old 02-12-15, 09:25 PM
greenlight149
copy that, just did a new FTP test, up by 16 watts! definitely felt it more this time around.
Old 02-13-15, 01:49 AM
Dunbar
Dunbar's Avatar
Bikes: Roubaix SL4 Expert , Cervelo S2
Quoted: 85 Post(s)
20 minutes at FTP should be hard but doable depending on how good you feel that day. During an FTP test you technically will be riding above FTP. If you're well motivated it doesn't necessarily feel any harder than regular intervals. After setting my 20 minute PR for power I had to get off my bike and sit down to prevent falling over.
Dunbar is offline
Old 02-13-15, 06:24 AM
lsberrios1
lsberrios1's Avatar
Bikes: '13 Spech Roubaix SL4 Expert
Quoted: 297 Post(s)
Are you training with hr or power? If it's hr, i may be wrong, your hr should drift with time if you are keeping the same power so if you are keeping the same hr chances are your legs are putting out less power. However, if you are training with power then it means you arent going hard enough. When i do mine i am about to pass out. From my last tt i estimate my ftp should be 270-275 given that at 53 minutes in at 269 i was able to sprint to the finish line.
Cat 6 going on PRO....
lsberrios1 is offline
Old 02-13-15, 06:29 AM
canam73
Quoted: 5 Post(s)
How much am I suffering? For the first 5 minutes not much at all. For the last 5 it's an all out fight.
canam73 is offline
Old 02-13-15, 07:15 AM
mvnsnd
mvnsnd's Avatar
Bikes: Caad10, Caad2
Quoted: 250 Post(s)
Liked 31 Times in 22 Posts
Maybe I'm wrong here, but riding at FTP is slightly different from an FTP test. The standard 20 min FTP test takes your average power over that 20 min and multiplies it by .95. That implys that the 20 min test is (should be) at a level 1.05 times your FTP. This is what dunbar is saying
Riding at FTP should be hard, but not causing one to pass out. The FTP test should be very hard, with little to no energy left.
mvnsnd is offline
Old 02-13-15, 07:56 AM
carpediemracing
Bikes: Tsunami Bikes
Quoted: 296 Post(s)
Liked 21 Times in 13 Posts
By definition if you hold a given power level for one hour and one second then you weren't at FTP. You should be absolutely wasted at one hour flat. Since that kind of pacing is hard to maintain except when, I dunno, being chased by zombies or a hungry but slow wolf, people do the 20 minute effort. The worst part of the FTP test is pushing yourself hard enough to make the test somewhat accurate. There are shorter efforts as well.
Typically a 40km time trial is used as a "full FTP test". It'll take normal fit racers an hour to do that distance, 50 minutes for the fast ones, and maybe 1:10 minutes for the slower ones (I'm closer to 1:10 than 50 min). Average power in that kind of effort is usually pretty close to actual FTP.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Old 02-13-15, 08:37 AM
Wesley36
Wesley36's Avatar
At least on the Wattage forum, Coggan's notion of FTP is considerably more fuzzy than that. If I have some time later today I can try to dig up some of his comments, but he generally takes a 40km TT as his reference (which should be ~ 1 hour for most people).
Wesley36 is offline
Old 02-13-15, 08:56 AM
greenlight149
Let me clarify, im using trainer road to see how much I'm improving in terms of power, not necessarily absolute power. And yea the 20 min test was done at above my actual ftp. I don't think I'll be able to go as hard on the rollers as a turbo to the point of almost passing out, or have nothing left in the tank, for the risk of falling over.
Old 02-13-15, 09:06 AM
topflightpro
topflightpro's Avatar
Quoted: 1509 Post(s)
Liked 234 Times in 156 Posts
It also can take some practice to get good at actually doing FTP tests. If you're not used to trying to go hard and steady for 20 minutes, going out and doing the test can be a challenge in an of itself, and it sounds like you are struggling a bit to find the proper balance of effort over the duration of the test.
topflightpro is offline
Old 02-13-15, 10:03 AM
caloso
caloso's Avatar
+1
caloso is offline
sdmc530
27
03-30-18 10:35 PM
FlashBazbo
Training & Nutrition
28
02-07-17 11:19 AM
plantrob
"The 33"-Road Bike Racing
51
03-13-13 08:25 AM
ancker
33
08-22-12 10:53 AM
dhale50
13
02-05-10 01:33 PM
