Pitbull Pedal is back
Quoted: 14 Post(s)
If you are talking about the 2" diameter area by 1/16th" thick that is our lead to engage the system. Simply put your foot against the side and push forward and you will automatically engage. As far as comical that doesn't seem like the right word but whatever works for you works for me. In person on the bike it all blends in.
To me, that's going to unnecessarily limit your potential customer base. I'd personally be much more likely to consider it if that wasn't present.
That's just how I feel, not that my opinion has any bearing on your business.
Quoted: 38 Post(s)
Liked 12 Times
Thanks for your opinion, no opinions will upset me either good or ill. Everyone is entitled to their own thoughts. In this case the 2" guide washer could easily be removed if the customer liked how easy it worked but wanted it to appear smaller. It would maybe be a $25 job at a machinist to put it in a lathe and remove it. I have actually been riding previously on an old set that had the glass filled nylon. One of them broke so I intentionally broke the other off so it would look the same. The pedal worked perfectly fine and it didn't cause any issues at all. So cosmetically it could be up to an individual to keep it or get rid of it.
Quoted: 14 Post(s)
Quoted: 3949 Post(s)
Liked 7,295 Times
2. Back to opinions, we do believe that there is room for another pedal. Especially one that works as easy as ours does. Not necessarily how fast it is but how easy it is to engage. Anyone getting into road bikes should pick our pedal as it should fit everyone's needs and the pricing will be super competitive as our overhead is almost zero and we're not trying to make the big bucks. Just having some fun.
Shimano SPD pedals are also really easy to engage and they can be purchased new for under $35. As a bonus, they're really easy to walk in when they're used with mountain biking shoes.
Your overhead may be low, but Shimano's volume is enormous. Can you reduce your present production cost by a factor of 50? That's what you'd likely have to do to compete with Shimano on price.
If the guide washer can't be removed using ordinary tools, it's effectively a permanent part of the pedal. Consumers are not going to seek out a machine shop to have their pedals modified.
5. As far as the cleats wearing out, I think that they should last as long as any of the other molded cleats. I personally walked 2 miles on them with an aggressive pace and they still worked perfectly fine. I cannot imagine how long they would last if you were on your bike, get off at a coffee shop, walk maybe 100 feet, stop at a store to get a gatorade, walk a little bit. At that rate they should last many many months and they would be extremely inexpensive from us to replace.
As a fellow product designer, prototyper, and small volume manufacturer, if you need help sourcing parts or tooling at any level, let me know. I live for this stuff and am lucky enough to also make my living doing it.
Quoted: 38 Post(s)
Liked 12 Times
Shimano SPD pedals are also really easy to engage and they can be purchased new for under $35. As a bonus, they're really easy to walk in when they're used with mountain biking shoes.Your overhead may be low, but Shimano's volume is enormous. Can you reduce your present production cost by a factor of 50? That's what you'd likely have to do to compete with Shimano on price.
With regards to the lead washer, the person below had mentioned it. We could offer it without the lead if people wanted it very easily. It could even be a direct order from us.
I am a little confused about the cleat wear issue. One reviewer expressed concern about wear when using prototype aluminum cleats and you suggested that a steel cleat was in the works to combat this issue (paraphrasing here). Now you seem to be going the opposite direction with an injection molded plastic cleat. Honestly, the latter seems like a terrible idea given the design of the cleat but perhaps you have done testing that proves it is durable enough. Here’s hoping you have or at least will before investing in injection molding tooling.
Thank you for the offer for the help, fortunately my partner is a machinist/mold maker. This is no get rich scheme like I had said, it is just a couple of old bucks having some fun. If you could sell ten or 20 sets a week or month across the entire US we would probably be satisfied. Thanks again for the offer of assistance.
Liked 7,295 Times
(You realize that many people use SPD-style pedals on road bikes, yes?)
bike whisperer
Quoted: 1528 Post(s)
Liked 718 Times
I'd suggest that aside from the 360 degree engagement, the biggest potential selling point is the minimalism, which is totally spoiled by the huge flange. It looks a bit rough at the outside end too; could that bit be more spherical?
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Quoted: 38 Post(s)
Liked 12 Times
You're claiming the main attribute of your pedals is easy engagement, which will appeal to a beginner cyclist. If that beginner cyclist walks into a bike shop and asks about easy-to-use pedals, the shop is likely going to steer him/her towards a bunch of two-sided pedals, including SPD and other mountain bike pedals. So, like it or not, you most certainly will be competing with mountain bike pedals.
As far as the flange, I personally think that it looks ok. Since we would be a new pedal that people would be ordering from us, we could offer it with the flange removed. Yes the outside could be more spherical. But we thought with the large blunt end with slight radii it would have the largest flat spot in case it did hit you or another cyclist.
Liked 7,295 Times
We're just trying to offer a new model that is extremely easy to use for a beginner or a weekend warrior. As if you are riding in a group ride and you happen to be in the front of the group, you will simply pull away from everyone and they will all have to catch back up to you.
If you are in the middle, you won't miss the pedal and cause a slow speed crash with the guy behind you.
Also yes I am familiar with many different road and mountain bike pedals, I just think that roadies want to be known as roadies and not roadies with mtb shoes. Just my thought.
Most beginners couldn't tell you the difference between road shoes and MTB shoes.
Quoted: 38 Post(s)
Liked 12 Times
So, these pedals will allow beginners to drop a group by clipping in a split-second faster, rather than say ... pedaling harder? Awesome.
If someone crashes into me because I didn't clip in fast enough, that's not the fault of my pedals -- it's the fault of the doofus that crashed into me.
SPDs are just one example of a two-sided pedal. Some are MTB pedals but many are road pedals. They are all, in general, very easy to clip into and some are very inexpensive. Like it or not, you will be competing with them.
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
I agree that the pedal looks a bit unfinished. I think some more gradual curves as well as removing the plate on the inside would go a long way towards making the pedals look better.
Quoted: 20810 Post(s)
Liked 9,456 Times
Again, this doesn't strike me as a good idea. Cycling shoe fit is so highly personal and so incredibly variable that I can't see a small player doing anything but flush their money down the drain with this kind of endeavor. Even if you or one of your partners happened to be an expert in the field of foot mechanics, you'd have to consider the number of shoes you'd hope to sell vs production considerations while factoring in availability in multiple sizes, etc.
Likes For WhyFi:
Quoted: 38 Post(s)
Liked 12 Times
I don't know. I understand that it isn't a horrific problem, but I do have to say that it is a problem. If we can make them as inexpensive as it appears that we can, I think that we may be onto something. In a lot of the GCN videos they talk about missing their clip in as they are taking off. I'm not trying to save the world, I'm just trying to make a simpler system to operate and make it totally re-buildable.
Likes For Pitbull pedal:
Liked 9,456 Times
But, oh well, flush away.
Quoted: 18883 Post(s)
Liked 10,646 Times
I don't think occasionally missing clipping in is a problem. I do think walkability is a problem. I've seen people fall in road shoes on smooth floors, like at lunch or water stops.
I used SPD pedals for years and recommend them to new cyclists when they ask, ease of use and walkability being the main reasons. I only switched to legitimate road pedals to get a power meter.
Likes For Seattle Forrest:
The Pitbull pedal is very similar to the Aerolite pedals as previously pointed out. I liked them quite a bit, and they were easy to use. I used them for all my riding including commuting, touring, racing, and winter commuting. Riding in the rain caused problems as the water mixed with the road grit and created a friction element that wore out the cleats every year.
I had been using Look pedals for many years and never replaced the cleats. To this day I still use the old Look Delta cleats and pedals. Cleats are replaced every 5 or 6 years, and the pedals simply last forever without need to rebuild.
OP is wise not to chase the big players. Online sales will be their only hope to start as bike shops will likely be unwilling or unable to support the unknown brand. Venders like QBP or J&B will be in the same boat. A very well designed webpage and sales portal will be absolutely necessary, and a very well put together social media platform essential to get the word out. I am sure you all know the drill. Good luck, my friend!
Likes For TiHabanero:
Quoted: 38 Post(s)
Liked 12 Times
I may be able to get Bernard and Greg to use them, but I doubt they'd be the same people you are talking about.
Rhapsodic Laviathan
As far as the refinement on the pedals, I really don't know exactly what you mean. Maybe in your opinion the simplicity of the pedal isn't visually catching your eye. But as far as refinement they are a perfectly machined stainless steel outer core. They couldn't be any more refined.
They could have sealed bearings...
