CAAD 10 max rim width?
Old 08-19-22, 12:35 PM
procrit
carbon is too light
procrit's Avatar
Bikes: Yes.
Quoted: 103 Post(s)
Liked 250 Times in 160 Posts
Built up my old CAAD 10 with Sram Red and need to get some race wheels for it. Does anyone know the max tire and rim width combo I can run? I'm fairly sure I'm limited to 25mm tires, but just not sure what width rims I can get squeeze in there.
Thanks in advance.
procrit is offline
Old 08-19-22, 01:53 PM
Phatman
Quoted: 129 Post(s)
Liked 97 Times in 51 Posts
Thanks in advance.
I had a 2014 CAAD10 and I was able to run 28’s on it. I then got cocky and tried to put a set of Michelin 28s on that measured something like 30mm, and those rubbed the chainstay. That was with Easton’s R90SL rims, which are 19.5/24mm internal/external I believe.
With that said, I’ve read that on the earlier years, the rear brake bridge is a bit too low to fit 28s, the tire rubs the bottom of the caliper. I had Dura Ace 7800 brakes on mine with no issues though.
Phatman is offline
