Addiction XXXX8
#1676
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Heal well, Mr. @Trsnrtr. Chicks dig scars, especially if you whip up a good story. That looks like a shark bite to me, perhaps received just as you whisked a baby harbor seal from icy waters?
I'm not in much pain but i am awful tired. Been resting all day. May try a bike ride tomorrow.
Keep the chain tight!
#1677
Administrator
Quoted: 11971 Post(s)
Liked 6,652 Times
No, really.
#1678
Stand and Deliver
Bikes: Cannondale R1000, Giant TCR Advanced, Giant TCR Advanced SL
@Trsnrtr - Wow, nasty one. I'm sure you're probably thinking, how long will this keep me off the bike. Hopefully not too long. Hope all heals well.
#1679
Coffin Dodger
Quoted: 794 Post(s)
Liked 292 Times
https://m.youtube.com/watch?v=8hwLHdBTQ7s
problem solve-ed
#1682
Peloton Shelter Dog
Di2 upshot: it's so old my LBS doesn't have the diagnostic box anymore.
This is the part where Glenn eBays the old bike crap on eBay (if it works 99% of the time, that meets the eBay definition of 'working') and then they install 11 speed on my old bike. I figure the upgrade might cost $1500ish. WhatEVER. The Zipp wheels are 11 speed already, I just take the spacer off and slap on a new D.A. cogset.
I ride those bikes an awful lotta miles yo.
https://www.cotsiscad.com
#1683
Quoted: 6556 Post(s)
Liked 58 Times
How about some plumbing advice? I just replaced the flapper in a toilet. Almost all's well. Almost. Now I notice that when the tank is nearly full, the fill speed slows down so much that the fill takes forever to shut off. I don't think there is a leak anywhere, but if I don't lift the float arm with my finger, the fill seems to never shut off. The water flow is so slow that I need to put my ear right over the tank to hear the sound. The bowl refill hose stops flowing long before this stage.
I have the float as far away from the valve as possible without it hitting the tank wall in order to get as much leverage on the valve as possible, but no luck. Even after say 5 minutes I don't get the "thunk" sound telling me the valve is completely shut. Is my fill valve faulty and needing replacement?
Any thoughts from the experts here?
#1684
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,530 Times
#1685
Mostly Harmless
Liked 4,530 Times
#1688
Liked 58 Times
Yeah, I thought about that. But wouldn't that just change the position of the cut off due to the float having to be more submerged to get the necessary buoyant force, rather then elongate the shut off process by slowing the fill down and drawing it out.
#1689
Quoted: 20810 Post(s)
Liked 9,456 Times
Do you really need the extra leverage? That could be giving you the fine-grained control that's resulting in a gradual shut-off. I'd try the float at a couple other positions a little further in on the arm. If that doesn't do it, a new valve will cheap and a lot faster than continued trouble-shooting.
#1690
Liked 58 Times
#1692
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Not sure. Try bending the arm to the float down so it has more pressure as it tries to float. Also some times the flapper valves wear out or just get dirt on them.
#1693
Mostly Harmless
Liked 4,530 Times
#1694
Mostly Harmless
Liked 4,530 Times
#1695
Bikes: 2016 Giant Propel Advanced SL 1
Quoted: 1668 Post(s)
Liked 6 Times
Try bending the float down. That will put more pressure as the water rises. Make sure you don't have any leaks. Try putting some petroleum jelly around the bottom of the flapper valve where is seals against the drain at the bottom of the tank. Replace the fill valve.
Buy a new terlet.
Buy a new terlet.
#1696
Liked 9,456 Times
#1698
Administrator
Liked 6,652 Times
#1699
Peloton Shelter Dog
I learned I was riding my Foil around with the QR levers loose. Mattie Davitt (formerly Fatal Lightning on these boards) pointed out this safety faux pax when I was @ Piermont Bicycle Connection earlier. I told him not to bore me with his technical mumbo jumbo and briefly wondered how I didn't get killed riding that bicycle down hills like that @ 40 mph. Pcad lives on the Velo friggin EDGE.
