Crank problems
Crank problems
Hey what's up guys/gals. I'm having trouble with my Rotor crank. Not sure what the problem is but when I push forward the crankarm on driveside pops a bit same deal when I pull back. The arm shifts very little.
Any ideas? Thanks.
Any ideas? Thanks.
Quoted: 514 Post(s)
Liked 448 Times
Does it do it when you push on the crank on the other side?
Likes For oldbobcat:
Quoted: 1303 Post(s)
Liked 1,910 Times
Check the chain ring bolts for tightness. Easiest way is to put a drop of oil one each one sucessively around the ring and try after each application. It will likely be one of the bolts. Smiles, MH
Likes For Mad Honk:
Quoted: 514 Post(s)
Liked 448 Times
Remove the crank from the spindle. Re-read the instructions carefully. Re-insert the crank onto the spindle according to the instructions. Be sure to align the splines on the spindle with the notches on the back side of the crank, and press. Now tighten the crank bolt, making sure the splines are still sliding into the notches. If everything still lines up and the crank is no longer wobbling, tighten that bolt firmly--push hard but don't break your arm. If not, send photos and take it apart.
I've never installed Rotor cranks before in my life but I looked very carefully at the parts in their online catalog. Let us know how it goes.
Took it apart an this is as far as I got. The face plate is what seems to move a bit
