Wheelset bearing
Wheelset bearing
Old 06-30-20, 06:44 AM
Wenmtuz
Quoted: 17 Post(s)
Wheelset bearing
HI, I'm using shimano rs 010 wheelset. As I known this wheelset using ball bearings. If I wanna change the bearing to seal bearing if it possible?
Wenmtuz is offline
Old 06-30-20, 07:23 AM
TakingMyTime
Bikes: Trek 7.4 FX
Quoted: 1022 Post(s)
Liked 907 Times in 531 Posts
If you mean cartridges... no.
TakingMyTime is offline
Old 07-01-20, 05:12 AM
Wenmtuz
Quoted: 17 Post(s)
so all I can do is change the ball bearing in the cartridge yeah not into seal bearing
Wenmtuz is offline
Old 07-01-20, 05:39 AM
Robius
Robius's Avatar
Bikes: Felt AR2 Di2
Quoted: 9 Post(s)
Liked 13 Times in 5 Posts
It's possible for Campagnolo/Fulcrum hubs which use ball bearings but not possible for Shimano hubs.
Robius is offline
Old 07-01-20, 08:00 AM
TakingMyTime
Bikes: Trek 7.4 FX
Your hubs use loose bearings in a cup and cone configuration. They do no contain or accept "cartridge" bearings. You can disassemble them, clean the cup, cone and bearings, and at that point you can decide if you want to replace the bearings or use the old ones.
