What is the fascination with Torx?
Quoted: 1438 Post(s)
Liked 1,092 Times
Those square drive fasteners are called Robertson or Scrulox: https://en.wikipedia.org/wiki/List_o...ives#Robertson
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 565 Times
One issue I have come into with Torx was the bolts securing a rotor to a hub. Bent the shaft of the driver bit, and rounded out the screw heads. Not sure any other screw type would have made a difference, but for sure Torx did not offer any advantage with those 6 bolts.
I'm all for weight savings, generally speaking. But not at the expense of appropriateness to the application. Not when serviceability is part of the utility.
JMO
Bikes: 80's Schwinn High Plains, Motobecane Ti Cyclocross
Quoted: 108 Post(s)
Liked 30 Times
I understand why they did it. BMW don’t focus on making their bikes convenient for a shade tree mechanic. They often use three or four parts where a Kawasaki might have one, as well, and they have more sensors and computers. But you can always tell that there’s a reason they did it that way, and the result is better. The expense is expensiveness.
But then, they never leaked oil either.
Likes For TGT1:
I have used square drive screws for decks and cabinetry and can say they take some serious torque loads without rounding out of the head. I assume that is the reason for using them. The head can also be made very small in relation to the screw shaft size.
Yea but Roberson screw head type never went anywhere as far as common use, outside of Canada..
T25 Torx head 5x0.8 mm machine screws are what the bike industry has chosen to affix brake discs.
Options Shimano Centerloc hubs & discs ... Rohloff uses 4 chainring bolts to fit discs on those hubs on the rear..
Or, buy hex head bolts for your bike , if that pleases you... 8mm wrench used on heads of 5mm bolts..
Likes For woodcraft:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
maybe so, but I only ever get one of those when I buy a set, whereas I have at least half a dozen T25 Bits because that’s what comes in a box of screws
Genesis 49:16-17
Genesis 49:16-17
It surely would be better if everything was Torx. Specially on the smaller bolts. Not sure why allen enjoyed more popularity, but it's not surprising considering Phillips screws are so popular and are a piece of crap.
Quoted: 241 Post(s)
Liked 232 Times
Last edited by Siu Blue Wind; 07-10-20 at 10:10 PM. Reason: Wrong length on the T25 bit
Quoted: 6196 Post(s)
Liked 4,810 Times
I've had allen set screws and counter sunk allen socket head cap screws crack in the corner of the socket. Makes them pretty near impossible to remove without a lot of cussing. Any torque applied with the allen wrench to remove them will spread the crack open and the sharp edge is amazingly effective at biting into the steel or aluminum hole it's in and preventing it from turning.
Never had it happen with a torx, but certainly we didn't have a lot of torx set screws used in the same application. Torx at the time was and probably still is rare for a headless set screw.
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Correct me if I'm wrong, but aren't those lever band bolts notorious for stripping easily? And yes, I know they are hard to get to from the proper angle, but don't many people prefer the earlier ones that are allen/hex?
Eklind tool company makes folding tools... I have 2 for allen* & 2 for Torx..
*1 fractional ,1 metric set.
https://www.eklindtool.com/
Likes For fietsbob:
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Only because Peter Robertson refused to give Henry Ford exclusive rights to the design.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
...I share your frustration toward the proliferation of driver patterns.
With Torx in particular, you can't really tell the difference visually between a T15 and a T20, or between T20 and T25,
and the same fastener in different lengths might take different driver sizes.
I regularly deal with, and often carry in my pocket, T15, T20, T25, T30, PH2, PH3, S1, S2, S3, square/phillips combo, 1/4", 5/16' nut drivers, SAE and metric allen key sets, and 1/4" and 3/16" slotted screwdrivers.
Likes For fietsbob:
Quoted: 241 Post(s)
Liked 232 Times
Likes For RGMN:
Quoted: 1814 Post(s)
Liked 923 Times
My worst is servicing plumbing trim with set screws of unknown size that are facing down and cannot be seen, recessed up to an inch, and 1/4" from the wall. Even after finding the correct size from among 6 or more SAE, metric, (or even slotted) by feel, the key has to be refitted for every 1/8 turn of the screw.
Quoted: 1109 Post(s)
Liked 1,200 Times
Torx drive is more resistant to "cam-out" than slotted or Phillips heads, and more resistant to stripping than hex drive. https://en.wikipedia.org/wiki/Torx
I suspect that they tolerate use with worn drivers better than hex, Torx kind of makes sense when reading the numerous posts on this forum asking for help with stripped-out hex drive fasteners.
Not sure of the mistake the mechanic made, so help me and others understand and explain the mistake. Thanks.
Quoted: 1188 Post(s)
Liked 1,154 Times
Then just to confuse the issue are JIS screws, which look just like philips (but are hopefully marked with a punch mark near the cross) but are mauled by a philips screwdriver. A JIS screwdriver in a JIS screw is firm as you can turn by hand. I use all Vessel brand JIS screwdrivers now. They work better than a philips driver in philips anyway!
Quoted: 241 Post(s)
Liked 232 Times
Much more convenient than standard "L" wrenches.
Torx is fine, but when you encounter a "security torx" and realize your torx bit isn't the security type, then you've been screwed. (pun intended / Dad joke).
Quoted: 108 Post(s)
Liked 30 Times
Glad I never misplaced a bolt!
Liked 341 Times
From a strength and fatigue standpoint, Whitworth was a superior thread - much superior to the National Standard thread from (NS had sharp thread roots, Whitworth is rounded).
