Cant get the RD to go to the smallest cog
Old 07-08-11, 08:26 AM
pallen
Descends like a rock
pallen's Avatar
Bikes: Scott Foil, Surly Pacer
Quoted: 7 Post(s)
Liked 16 Times in 8 Posts
This one has me confused. I installed a new derailleur (7800), set the limit screws to get it in-line with the small cog without the chain on and shifted to the far gear. Put the chain on and it ran great in the small cog.
Then, I put the cable on, and fine-tuned the tension. Now it wont go down to the small cog. I can loosen the tension the point that there is very noticeable slack and it still wont go down to the small cog. I can see that the limit screw is a millimeter or two away from touching, so I know the limit screw is not interfering.
I took the cable off and it will drop down all the way to the small cog, but if the cable is on, even with tons of slack in the line, it wont. What's up with this?
pallen is offline
Old 07-08-11, 09:16 AM
jsharr
You Know!? For Kids!
jsharr's Avatar
Bikes: '05 Trek 1200 / '90 Trek 8000 / '? Falcon Europa
Quoted: 38 Post(s)
Liked 25 Times in 20 Posts
Here is a good tutorial. Go through it step by step and see if it helps you out.
https://www.utahmountainbiking.com/fix/rshf-tun.htm
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Originally Posted by colorider
Phobias are for irrational fears. Fear of junk ripping badgers is perfectly rational. Those things are nasty.
jsharr is offline
Old 07-08-11, 09:28 AM
FBinNY
Quoted: 5756 Post(s)
Liked 2,524 Times in 1,395 Posts
I suspect that your problem may be related to housing friction. Shift to the second sprocket then back to high gear, where it's hanging up. Firmly pluck the bare gear wire away from the downtube like a guitar string. If that's enough to complete the shift, it confirms my guess.
You might also consider trying to shift from high to the next sprocket and back by pulling the wire from the frame, rather than the lever. If that works even if you release the tension slowly, the friction problem is in the handlebar to frame section of housing, if it only shifts with a quick snapping of the wire, then the problem is likely in the chainstay to RD loop.
FB
Chain-L site
FBinNY is offline
Old 07-08-11, 12:39 PM
Marc7200
Ex Fat Guy
This happened to me after I changed the cables on my bike. After messing with it for a few weeks I discovered that I installed the cable clamp tabbed washer in the wrong position. The tab on the washer hit the derailleur hanger preventing the RD from moving all the way to the right. Check the attached tech doc under the Stroke adjustment and cable securing section. Refer to the illustration under step 2 where it says make sure the cable is securely in the groove. Make sure the washer with the tab is in the right position.
HTH and good luck.
https://techdocs.shimano.com/media/te...9830612494.pdf
Marc7200 is offline
Old 07-09-11, 09:19 PM
pallen
pallen's Avatar
Quoted: 7 Post(s)
Thanks! Some good things to check here that I haven't thought of. I'll let you know what I find out.
pallen is offline
Old 07-09-11, 09:52 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1523 Post(s)
Liked 716 Times in 508 Posts
Further to FB's diagnostic checks, see if you can just manipulate the derailleur itself into top gear - you may be able to figure out the source of the issue by feel that way.
Kimmo is offline
Old 07-11-11, 08:43 PM
pallen
pallen's Avatar
Quoted: 7 Post(s)
HTH and good luck.
This was the problem. I had the tab in the wrong position. As the deraileur moved toward the small cog, the tab would interfere with the cable. Perfect shifting now, THANKS!
pallen is offline
bobbyl1966
Bicycle Mechanics
4
10-24-15 02:02 PM
larwyn
Bicycle Mechanics
13
02-18-12 07:20 PM
ahson
Bicycle Mechanics
7
08-01-11 08:16 AM
ElMono
Bicycle Mechanics
5
05-20-11 10:22 PM
mr,grumpy
Bicycle Mechanics
8
03-01-10 12:41 AM
