The Definitive (But Wildly Inaccurate) Guide to Brake Cable Pull Ratios
Resurrecting to add some data points (measured pivot radius and calculated 20° lever travel cable pull)
Campagnolo Chorus 11 (2016)
- 24mm
- 8mm
- 18mm
- 6.25mm
- 18mm
- 6.25mm
- 36mm
- 12.5mm
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Thanks for updating, @joejack951!
I'm not sure about the 5800 data. I've got a set of those levers, but they're hooked to disc brakes without a simple release that would give me complete access to the relevant points, but as I recall the reasons I didn't include that were (1) the cable attach point was such that the measurement wasn't easy to perform accurately, and (2) the lever is designed such that it wraps the cable around an irregularly shaped surface.
The second point here is the relevant one. Anyone better at measurement than I am (which is almost everyone) can address (1), but (2) is an intrinsic issue with how this lever pulls able. That is, the method I was using depends on measuring the radius of the circle being traversed by the cable, but with the 4700/5800/6800/9000 levers this radius is variable so the lever pulls cable at a different rate at different points in its motion.
Note that this corresponds to what Shimano says about the change in cable pull from the 4600/5700/6700/7900 ("New Super SLR") to the 4700/5800/6800/9000 ("SLR EV"), which is that the cable pull is compatible but that it pulls at a different rate.
So, as a sanity check, our measurements should indicate that the cable pull rate of a 5800 lever is very similar to the cable pull rate of a 5700 lever. I'm not saying that the measurements shouldn't be the final word, but I am saying that if the measurement is significantly at odds with expectations (which yours is) then it should be double-checked.
My Bikes
My Bikes
If I get a chance in the near future, I'll swap calipers between the bikes and see what sort of change it makes as well as attempting to figure out a way to accurately compare degrees of lever travel and the resulting cable pull.
Quoted: 4806 Post(s)
Liked 3,931 Times
I like the second setup sop much I duplicated it on my good bike. Yes I do pay some penalty braking hard on the hoods but I just see that as a reminder to ride as the coaches taught us 40 years ago - when the riding gets dicey, ride the drops.
In exchange, the huge plus - wonderful handles when out of the saddle!
Ben
Bikes: Yes
Liked 3,868 Times
I just did a quick check with my 5800 levers, and I think I know what's going on. The cable attaches at a point near the front of the lever (the red arrow below) which is indeed 36mm from the pivot, but it is suspended above the plastic for a length over which it can change its angle, so the effective attachment point for purposes of this calculation is the point at which the cable's movement becomes constrained by the inner structure of the lever (the green arrow below) and that's closer to 21mm from the pivot.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
Here's a slightly more visual explanation (motivated by my own efforts to convince myself that what I said in my previous post was correct).
The model I was using to calculate cable pull based on the pivot radius is assuming that the amount of cable pulled is approximately the same as the distance traveled by the anchor point. I mentioned in post 18 where I introduced this method that the cable pulled was actually the chord cut across the virtual circle traveled by the pivot point but for most levers that's a pretty good approximation. This assumes that the pivot point is near the top of the virtual circle. (See Figure 1 on the attached image.)
If the cable is anchored significantly left of the top (relative to the cable exit) of the virtual circle, the approximation would break down, as seen in Figure 2. Here the amount of cable pulled is actually the difference in the distance from the original anchor position to the exit point and the distance from the final anchor position to the exit point, assuming nothing restricts the cable's freedom of movement within the virtual circle.
However, the geometry of Shimano levers since the 5700/6700/7900 series is more complicated. These levers have the cable anchored toward the front of the virtual circle, but the cable rests on a "shelf" that is near the top of the virtual circle. The result is that the cable pull is actually determined by the travel of the resting point, not the travel of the anchor point. Figure 3 attempts to illustrate this idea. You can see there how the inner circle interferes with the movement of the cable and makes the original approximation good, if based on the inner circle rather than the outer circle.
The fact that the cable rests on a shelf rather than a single point complicates this a little bit more. If you imagine a flat shelf extending along the blue line in Figure 3 and then rotating with the circle, you'll see that the effective diameter of the inner circle (i.e. where it pushes against the cable) will increase as the lever rotates, meaning that it would pull more cable later in the motion of the lever. And if that's not enough to confuse you, I believe the Shimano levers don't use a flat "shelf" but rather a curved one so that the rate at which the effective inner circle radius changes is reduced.
In any event, this is a fine tuning effect and the simple approximation based on the inner circle tells you enough to understand approximately how the brake will respond.
My Bikes
My Bikes
Bikes: Yes
Liked 3,868 Times
The engineer wanted to know how many BTUs the stove produced, what the expected ranges of air temperature and barometric pressures were, how pure the water to be boiled was going to be, how much water was to be boiled, how much time was available to boil the water and so on.
The physicist made some assumptions, looked up the specific heat of water and proceeded to perform some calculations.
The mathematician poured a pot of water, put it on the stove and without so much as turning on the stove declared, "QED!"
My Bikes
My Bikes
I posted earlier that campag has a 24mm pivot for all 10 speed but I just measured an older 2nd gen 10 spd lever (with the rounded hood top) and it measures about 19mm. This is curious as it implies that campag changed the ratio between 2nd and 3rd (current shape) levers without publicizing it or changing the calipers -or perhaps the skeleton calipers are a slightly different ratio?
Note both levers are Ultra shift veloce but I'm almost certain all the levers of the same shape share geometry. Of the the current 11 spd, I'd say they are the same as the 3rd gen 10 spd as the skeleton calipers have remained similar since inception.
Bikes: Bottecchia Campione del Mundo, 00 Rocky Mountain Element TO, 92 Trek 1400, '13 Public R16/Bionx; (Recent: '90 Specialized Allez Epic, '87 Trek 560EX, Kona Explosif, '18 Elephant National Forest Explorer, '08 Look 585, 75 Motobecane GR 650B)
Do you know if Tiagra 4700 has this same "Servo-Wave" action you so excellently described the 105 and above seem to have?
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
If that's what you're asking. If not, carry on.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
find the volume of a red rubber ball
The physicist dipped the ball in water and measured its displacement
The mathematician measured the diameter and calculated the volume
The engineer looked it up in his Red Rubber Ball Volume Table
Genesis 49:16-17
Genesis 49:16-17
Liked 3,931 Times
The best setups I have ever ridden are Tektro V-brake levers and Shimano dual-pivot brakes and the same levers with old Shimano cantis (the ones with Mafac geometry). I love V-brake levers for their huge hoods. I also view too much braking power as bad. I see (and have experienced) far more crashes from skidding and loss of control from too much brake than from hitting things because I simple could not stop in time.
I do not do much of my braking from the hoods as I was taught by the veterans in our club that we were to always be on the drops where there might be surprises; potholes, contact with other riders, situations that might require hard braking, etc. That the drops were, quite simply, the safest place to be, safety being very closely tied in to fewer crashes and less lost training time. And this was when every race bike came with seat belts that you were required to use. 1985, the seatbelt law was repealed. - Non-aero brake cables, sticking up from the brake hoods. They kept your hands on the hoods when you hit the pothole you didn't see. No one talked about them and we all rejoiced when aero brake levers came along and we could finally use that coveted palms over the hoods we had dreamed of for years, but ... we all jammed our thumb crotches hard against that damn cable at least once and every one of those jams was a crash that didn't happen.
My V-brake lever/powerful caliper setup won't give me enough braking power from the hoods for steep descents and wet weather. But it is all there from the drops. (Wet downhills do require real hand strength and riding the miles of gravel descent at the Oregon Trail Gravel Grinder, I had to stop and rest my hands I also had to refocus my brain so it may well have been for the good.)
Ben
Liked 3,931 Times
Ben
I didn't really follow all the technical explanations but I went through this a couple years ago and found out that Tiagra 4700 derailleurs were designed to be compatible with the new generations of 105 and Ultegra re: cable pull.
Thanks KRS!
That's great to know because I just found out today that I find Tiagra hydraulic levers to be extremely ugly. Dealbreaker for me XD
I also since believe I've seen that Shimano's compatibility charts confirm your statement.
New Super SLR is slightly different from SLR-EV. By Andy's measurement EV seems to have more initial cable pull and about 10% more final mechanical advantage than "New".
When mixing and matching lever and brakes, the added flexibility might be handy.
Unfortunately Shimano's product page lists the 4700 as both "EV" *and* "New". Argh!
This thread deserves to be kept going. The XT BR-M732 cantilevers setup with Shimano 125mm link wires work best with BL-6401 levers, which have a pivot radius of 18mm. As I understand it, these were 1st generation SLR. Unfortunately hoods are unobtanium. I don't have a set of BL-6402 to compare, but the BL-6403 are labeled "Super SLR" and have a larger, harder to measure, radius.
Shimano BL-6401 (1988-1990)
- 18mm (Pivot radius)
- 6.3mm (20deg pull)
Likes For fliplap:
SRAM Apex 10s "DoubleTap". I suspect this is the same as the SRAM S500 lever. Likely the same as other SRAM 10s DoubleTap levers as well. Rival, Force, Red.
- 24mm (Pivot radius)
- 8.37mm (20deg pull)
bobotech
Bicycle Mechanics
10
10-29-12 04:14 PM
wearyourtruth
Bicycle Mechanics
6
12-10-10 03:46 AM
